eldoradoCoupe Posted October 10, 2015 Share Posted October 10, 2015 Hi, just getting ready for paint stage with my gte and I stopped to look at the wee drain hole at the top of the Swan neck. Seems like a terrible idea to have water drain down through the Swan neck. Has anyone else done anything with it. I was contemplating using seam sealer to fill it and bring the level up so water drains off the inside of the rail. Good idea or not? Quote Link to comment Share on other sites More sharing options...
mantaray Posted October 10, 2015 Share Posted October 10, 2015 Thats what I do, it's the main reason the chassis rail rots. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 10, 2015 Share Posted October 10, 2015 Yep i seal them up as well. Quote Link to comment Share on other sites More sharing options...
Rapierdave Posted October 10, 2015 Share Posted October 10, 2015 As above, seal em up its a crap design fault & the reason swan necks rot from the inside out. Quote Link to comment Share on other sites More sharing options...
mikemanta Posted October 10, 2015 Share Posted October 10, 2015 pour waxoil down the chassis leg first through the hole this is the best way to get it into the swan neck where its needed then seal it up. 1 Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted October 10, 2015 Share Posted October 10, 2015 Weld it up. Same with sunroof drains that go into sills. Don't let water in Quote Link to comment Share on other sites More sharing options...
®evo03 Posted October 11, 2015 Share Posted October 11, 2015 Use a small grommet, with seal sealer, to get easy access should i need it! 1 Quote Link to comment Share on other sites More sharing options...
