DiscoDave Posted June 17, 2018 Share Posted June 17, 2018 Hey Chaps, My Manta A with C20LET puffs out a cloud of smoke when slowing down and just before stopping, & only when hot. She has the wing type sump, and I was thinking maybe it has too much oil. The oil might be getting thrown forward and preventing the Turbo oil return pipe from draining freely, or the oil is getting up into the cylinders. Can anyone tell me me does the wing type sump require less oil? I’m using the original dip stick and have oil just above minimum. Thanks in advance Dave Quote Link to comment Share on other sites More sharing options...
IanMc Posted June 17, 2018 Share Posted June 17, 2018 Sounds like your valve stem oil seals might be passing. Quote Link to comment Share on other sites More sharing options...
DiscoDave Posted June 17, 2018 Author Share Posted June 17, 2018 That’s what I was thinking too, as it appears to be getting slowly worse. One thing I have noticed, is that the two breathers on the rocker are not connected to anything. I might plumb them in and create a negative pressure in the crank case which appears it doesn’t have. Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted June 17, 2018 Share Posted June 17, 2018 Are you using the Manta 1.8 dipstick and tube? Quote Link to comment Share on other sites More sharing options...
DiscoDave Posted June 17, 2018 Author Share Posted June 17, 2018 Hey Danny. No, it’s the original that was on the C20LET. Why, what’s you thoughts? Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted June 17, 2018 Share Posted June 17, 2018 You’re best using the 1.8 dipstick and tube off the Manta engine. I do have one for sale so PM me if interested Quote Link to comment Share on other sites More sharing options...
®evo03 Posted June 17, 2018 Share Posted June 17, 2018 You can use a redtop dipstick if you measure it against a 1.8, from memory think the tube and dipstick is longer, regardless think it is 4.5l with filter every change, will check this could, search 1.8 dipstick, think there is a photo on here somewhere, 2.0 and 1.8 side by side. Quote Link to comment Share on other sites More sharing options...
DiscoDave Posted June 18, 2018 Author Share Posted June 18, 2018 7 hours ago, Danny D114BCW said: You’re best using the 1.8 dipstick and tube off the Manta engine. I do have one for sale so PM me if interested Does it bolt straight on or do I have to modify it? Quote Link to comment Share on other sites More sharing options...
robah Posted June 18, 2018 Share Posted June 18, 2018 I have both versions 1.8 & Redtop in my shed. I have roughly measured them and there is a slight difference. If memory serves me well, the dipstick tube on the 1.8 is smaller and so is the dipstick. The breather pipe length is also smaller and would need modifying. I will endeavour to take some pictures today of both setups together to show the difference. That is if I can remember as I have a lot of other work to do today and my short term memory is not the best Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted June 18, 2018 Share Posted June 18, 2018 Breathers need to go to a tank of some sort or just pop a filter on but be prepared to keep cleaning around it Quote Link to comment Share on other sites More sharing options...
DiscoDave Posted June 18, 2018 Author Share Posted June 18, 2018 3 hours ago, robah said: I have both versions 1.8 & Redtop in my shed. I have roughly measured them and there is a slight difference. If memory serves me well, the dipstick tube on the 1.8 is smaller and so is the dipstick. The breather pipe length is also smaller and would need modifying. I will endeavour to take some pictures today of both setups together to show the difference. That is if I can remember as I have a lot of other work to do today and my short term memory is not the best That’s fantastic. Id really appreciate that. I have the oil level at the point where it just touches the RedTop dipstick. I’m not completely convinced it’ll sort my problem. Quote Link to comment Share on other sites More sharing options...
robah Posted June 18, 2018 Share Posted June 18, 2018 (edited) Lets see if I can explain and add pictures editing while I go along The Blue dipstick is the 1.8 setup the other is Redtop At a rough gestimate their is a 40mm difference (the 1.8 is deeper lower item) Tried to show if fitted to block Measurements on dipsticks, one next to the rule is 1.8 dipstick Difference in bung height when both the dipsticks are level from the picture above. Maybe a cut down on the extension tube of the redtop setup by 40mm (approx.) would keep the redtop dipstick in play and remark the upper and lower limits as per 1.8 setup. Only a suggestion and not gospel or correct science as I have to work this out myself in the future. Edited June 18, 2018 by robah Aligning pictures to text 1 1 Quote Link to comment Share on other sites More sharing options...
DiscoDave Posted June 18, 2018 Author Share Posted June 18, 2018 38 minutes ago, robah said: Lets see if I can explain and add pictures editing while I go along The Blue dipstick is the 1.8 setup the other is Redtop At a rough gestimate their is a 40mm difference (the 1.8 is deeper lower item) Tried to show if fitted to block Measurements on dipsticks, one next to the rule is 1.8 dipstick Difference in bung height when both the dipsticks are level from the picture above. Maybe a cut down on the extension tube of the redtop setup by 40mm (approx.) would keep the redtop dipstick in play and remark the upper and lower limits as per 1.8 setup. Only a suggestion and not gospel or correct science as I have to work this out myself in the future. This is fantastic info! Thank you so much for going to the bother of checking this out. This makes total sense. Shortening the tube sounds like a simple enough adjustment. If it doesn’t work out, it won’t be the hardest thing to revert. I’ll be sure to keep you posted for your own knowledge, and upload some pics. 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted June 18, 2018 Share Posted June 18, 2018 Great photos! Couldnt ask for more if you tried, has to be worth the membership cost alone! 1 Quote Link to comment Share on other sites More sharing options...
robah Posted June 19, 2018 Share Posted June 19, 2018 Maybe if the plug can be moved, move it up towards grip handle approx. 40mm, probably cheaper and easier to replace the dipstick? It is another one of those jobs to add to the "to do" list Quote Link to comment Share on other sites More sharing options...
DiscoDave Posted June 19, 2018 Author Share Posted June 19, 2018 4 hours ago, robah said: Maybe if the plug can be moved, move it up towards grip handle approx. 40mm, probably cheaper and easier to replace the dipstick? It is another one of those jobs to add to the "to do" list Ehhh that was very obvious, Ha. In my head I was planning to shorten the tube. Moving the plug would be a lot easier in theory. Hopefully get a look at it this weekend when I get home from work. 1 Quote Link to comment Share on other sites More sharing options...
