hoobby Posted July 8, 2018 Share Posted July 8, 2018 I need a set of springs for an exclusive and see lowering sets for b's as the exclusive was lowered at production would this lower it further or where they fitted with shorter uprated springs anyone out thier changed Thiers how did it turn out.also the bottom turn on my front springs go straight for he last couple of cm's to seat into the lower arm is this the same with b springs.due to one of the fronts snapping this is the only thing keeping me off the road after nearly ten years and already harvested one of my wife kidneys to pay for the welding. Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted July 8, 2018 Share Posted July 8, 2018 Could you not buy a set of springs off eBay? If you got the ones with the least drop you should be okay. At least it will be usable. The standard springs are rubbish anyway. Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 8, 2018 Author Share Posted July 8, 2018 I can't get away with a 40mm drop as will never get it off the drive due to a slope and checked return policy and if fitted no refund that's why I need to know. Quote Link to comment Share on other sites More sharing options...
garymanc Posted July 10, 2018 Share Posted July 10, 2018 From what I can gather from years of reading this forum it's a lottery how low the springs will sit from whatever supplier you get them from even if the the advert say -40 MM. For example 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 11, 2018 Share Posted July 11, 2018 As Gary so rightly says you never know.when you say you need a set I assume you need a front set only .im sure someone on here will have some or there are plenty standard ones on ebay. Especially if yours is a 2 litre The lowered ones if you realy need to go that way are a slight gamble unless someone can recommend some they have fitted and can give you the heights when fitted The lowered ones if you realy need to go that way are a slight gamble unless someone can recommend some they have fitted and can give you the heights when fitted the straight end section is for positive location in the seats.all gm originals have that feature so I would expect good quality aftermarket to be similar Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 15, 2018 Author Share Posted July 15, 2018 Just to finish this subject off this is how an exclusive looks with a kilen 40mm lower spring set only problem is rear springs will come unseated if the axle is allowed to drop so will need shorter travel shocks.is it me or does it look a bit higher now ?. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 15, 2018 Share Posted July 15, 2018 To be honest that doesnt look low at all . That looks very similar to my cav with standard springs . I would have thought an exclusive would appear lower .problem is (although i dont like lowered cars anyway) that any lower and i wouldnt be able to drive mine anyway.speed humps already catch the exhaust as it is .and mines standard springs and standard exhaust. I take it that is a before and after picture of yours now with new springs in ? Looks fine to me ! Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 15, 2018 Author Share Posted July 15, 2018 Pics are front then back wheel didn't do a before shot as was all up on axle stands when i found three broken springs probably sat lower then.i was looking for around standard height anyway and the kit lowers a b by 40 mm may get a 60mm kit with shocks next year as all out of cash and kidney's. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 15, 2018 Share Posted July 15, 2018 Seeing as that looks similar height to standard b ( more or less)then it looks like those springs are firmer / uprated. Meaning less turns of a thicker or stronger material . Thats why they dont open up as much and could come unseated. So long as you are happy with the ride quality then yes you will need some shorter dampers.original exclusive springs or (technically correct) springs would open up to an acceptable snd contained length within standard damper length. However if you find the car a bit hard ( and it wasnt before ?) then you will need normal exclusive springs. if its only the rears you are having trouble with at least they are the easy ones to swap !. Best regards 1 Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 15, 2018 Author Share Posted July 15, 2018 I would love to put standard springs in but no one lists springs for an exclusive only b's up to 88 and I have read a few posts of people getting springs to find they have gained a few cm's.pic of old rear and 40mm lowering spring Quote Link to comment Share on other sites More sharing options...
Monaco Blue Posted July 15, 2018 Share Posted July 15, 2018 4 hours ago, cam.in.head said: To be honest that doesnt look low at all . That looks very similar to my cav with standard springs . I would have thought an exclusive would appear lower .problem is (although i dont like lowered cars anyway) that any lower and i wouldnt be able to drive mine anyway.speed humps already catch the exhaust as it is .and mines standard springs and standard exhaust. I take it that is a before and after picture of yours now with new springs in ? Looks fine to me ! I'd agree with your thoughts re the cars stance. If anything, it looks higher than a standard GTE or Exclusive. Are we sure that the OEM springs on the Exclusive's were different to say an 87MY GTE? I don't recall there being much difference between them to be honest. Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 15, 2018 Author Share Posted July 15, 2018 Again even springs advertised as gte springs state 1970-1988.unless someone knows for sure which springs I need I'm not going to get any as rapidly running out of money Quote Link to comment Share on other sites More sharing options...
garymanc Posted July 15, 2018 Share Posted July 15, 2018 just googled opel manta exclusive images and i reckon your ride height looks about correct Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 16, 2018 Share Posted July 16, 2018 I’d agree .ride height looks fine to me too. So long as you are happy with ride quality you definately need to fit some shorter shocks. If not then keep your shocks and fit different rear springs . ( you dont want any chance of springs coming out) original rear spring even gte ones as far as I know do look very similar to your original spring with a thin last turn on each end and a short straight locating section. Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 16, 2018 Author Share Posted July 16, 2018 Just fitted the rear springs I got from garymanc and has lifted the rear by 15mm so the kilsen catalogue is correct and will lower a gte/exclusive by 15mm.its probably me even when I first got the car I thought could do with being a bit lower. will be getting shorter shocks next year many thanks for the help and advice. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted July 22, 2018 Share Posted July 22, 2018 (edited) Hows it sitting! Creating a modified manta, and doing several things to front and rear of car to get it sitting damn low, oval exhaust says it all! Edited July 22, 2018 by ®evo03 missed a s! Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 23, 2018 Share Posted July 23, 2018 You must have good roads by you with no speed humps ! ! My two cavs catch and theyre standard ! Quote Link to comment Share on other sites More sharing options...
