CalCol Posted June 4, 2019 Share Posted June 4, 2019 June 26- more new parts added to the top of the list, sold parts moved to the bottom. Inside lock slider with chrome knob, as used on Mantas up to the 1986 model year. GM number 09289313, Opel 1 34 953. £12.50 Left side inside door pull with black handle for all Ascona B / Manta B up to model year 1984. GM number 90123255. Opel 1 34 238. £12.50 Right side inside door pull with black handle for all Ascona B / Manta B up to model year 1984. GM number 90123256. Opel 1 34 239. £12.50 Left side door pull surround in chrome for all Ascona B / Manta B/C. GM number 09287173, Opel 1 36 335. £15. 1 sold! Left side door pull surround in grey for Manta B/C from 1986 model year. GM number 90238436, Opel 1 36 382. £7.50. I also have the right side in grey, also for £15. Right side inner trim for door pull surround in grey for all Manta B/C. GM number 90238429, Opel 1 36 377. £5 I also have one only of the left side of this (unobtainable now) - GM number 90238428, Opel 1 36 377. £12.50. Left side inner trim for door pull surround in black for all Ascona B / Manta B/C. I have one only and this is no longer obtainable. GM number 08978533, Opel 1 36 362. £12.50. Right side inner trim for door pull surround in black for all Ascona B / Manta B/C. GM number 08978534, Opel 1 36 363. £5 Chrome escutcheon for door lock on Manta B Berlinettas up to 1980 model year (i.e. the door panels with the fake wood trim). Very rare. GM number 09297258, Opel 1 36 541. £25. Ignition coils for Manta C with electronic ignition (i.e. 1.8S or 2.0E). Also good for cars with a 2.2 injection conversion or a 3.0 Monza engine conversion). This is the coil only, use your existing ignition module. GM number 90140186, Opel 12 08 034, Bosch 1 227 020 009. £40 each. 1 sold. New left side front wing for a Manta B/C, genuine Opel panel. GM number 09286215, Opel 11 01 100. £400. Jetex rear silencer for a Manta B/C coupe. This silencer is the later type with the 3" round chromed tailpipe. £90 Left and right side front spoiler halves for a Manta B with chrome or black plastic bumpers (1975 - 1981) £225 for the set (includes the plastic mounting nuts you'll need too) Part numbers: left: GM number 90123211, Opel 17 19 115, right: GM number 90123212, Opel 17 19 116. Plastic nuts that hold the spoiler to the front valance are available separately if you need them. GM number 09278277, Opel 11 04 971. £3 each Bumper carrier (metal part behind the bumper) for Manta C with the painted airdam-style bumper. GM number 90124221, Opel 14 05 003. £45. 1 sold I also have the rubber anti-squeak strip that runs along the upper flange of the bumper carrier if you need it. GM number 90158372, Opel 14 05 700. £12.50 Side skirt, right, for a Manta C GT/E. GM number 90008113, Opel 17 19 007. £75 Plastic mounting nuts are available from Edelschmeide if you need them: https://www.edelschmiede.com/shop/einbausatz-frontspoiler-asc-b Water pump and gasket for a Manta C GT/E (2.0E engine and a clutch fan). GM number R1160011 (equivalent to 90156352), Opel 13 34 097. £75. Right side upper wishbone, complete with bushes. GM number 90017466, Opel 3 10 129. £160. 1 sold Long mounting screw (through bushes and front crossmember) available if you need them. GM number 11078451, Opel 20 00 645. £8 each. 2 sold Front spring set for a Manta C with the 2.0E engine, white paint marking. GM number 90093577, Opel 3 12 188. £100. Gaskets for the pop-out windows on all Mantas, GTs, Monzas. All the cars I've bought have leaked here until I changed them so I have a few of them in stock. Each window uses two pieces - inner and outer. GM part number 09288083, Opel number 1 46 355. £2.50 each. 16 sold Roll pins that hold the pop-out window handle to the bracket screwed to the window, again same for all Mantas, GTs, Monzas. You have to drill these buggers out when you change the handle or the pop-out window gasket, so a new one makes sense. GM part number 03437757, Opel number 1 46 085. £1.50 each. 12 sold Left side door triangle for Manta B/C with internally adjustable door mirrors. GM part number 09283987, Opel number 1 49 209. £15. Right side door triangle for Manta B/C with door mirrors that aren't internally adjustable. GM part number 09283986, Opel number 1 49 207. £15. Left side door triangle for an Ascona B for cars with door mirrors that aren't internally adjustable. Useful if your Ascona doesn't have a passenger side mirror yet... GM part number 09283981, Opel number 1 49 200. £15. Velvet track for the rear of the door windows on a Manta B/C coupe or hatch. GM 09283012, Opel 1 48 191. £7.50. 4 sold I also have the front track (but no photo) for £15. 4 sold Black Opel badge for the boot lid on a Manta B coupe, suits cars pre-1982 (chrome or black plastic bumpers). The originals supplied on the cars were metal, the later ones were plastic (although it's the same part number, Opel just decided to make it in plastic rather than metal), this is a plastic part. I have two for sale. GM number 90034364, Opel 1 77 748. £7.50 each. 1 sold. Right hand (driver's) door handle for 1982 and later ("Manta C") cars. The handle itself is smooth, earlier ones (pre-1982) were ribbed. GM 90052471, Opel 1 38 117. £30. 1 sold I also have a left side one available, same price (1 sold), and some early type (in black) with the ribbed handle, both left and right side. Right hand (driver's) door lock for Manta/Ascona B/C and Monza/Senator A - the bag is still sealed so I didn't want to take it out even for the photo! GM 07997332, Opel 1 34 022. £45. Trim clips for the side trim on cars up to 1982, both Manta B and Ascona B. The side trim was chrome coloured with a rubber centre strip to fend off other folks' doors and was fitted as standard to Manta Berlinetta and Ascona Berlina (probably others too). I have quite a few of these, so let me know how many you need. GM 03467531, Opel 1 74 820. 50p each, 10 for £4.50, 25 for £10. Spare wheel strap (rubber part) for Manta / Ascona B/C. GM 08983248, Opel 14 18 624. £10. 1 sold Velvet track for the rear windows on a 4-door Ascona B, I have two of these. If you want to match it up to your car, these are 131.5 cm long and have one pre-cut corner (top right on the photo). GM 09282825, Opel 1 48 192. £20 each. Weatherstrip for the back of the engine bay on a Manta B/C or Ascona B, goes just above the heater on the cowl flange and stops you getting oily engine smells in the car. GM 90228391, Opel 1 04 177. £5 each. all sold! Door window glass stop (goes inside the door) for Manta B/C. GM part number 09286723, Opel number 1 50 355. £5 each. All sold Right side door triangle for Manta B/C for cars with Englemanns mirrors. GM part number 09282952, Opel number 1 49 203. £20. Sold! Rear silencer for a Manta B/C GT/E coupe. This is the later type with the ROUND CHROME TAILPIPE, not the black oval. GM number 90297683, Opel 8 52 282. £80 Sold! 2x right side full chassis rails for Manta B/C. GM number 90160005, Opel 2 12 025. £650. Both chassis rails sold. That's all for now, but I have a lot of NOS parts that I'm going to be selling off. If you need something for your restoration, PM me, I may just have what you're looking for. Cheers, Nick Quote Link to comment Share on other sites More sharing options...
Irmscher Man Posted June 4, 2019 Share Posted June 4, 2019 Hi Nick, PM Sent! Quote Link to comment Share on other sites More sharing options...
KAA Posted June 4, 2019 Share Posted June 4, 2019 PM sent Nick. Thanks. Quote Link to comment Share on other sites More sharing options...
nilen Posted June 15, 2019 Share Posted June 15, 2019 Pm sent 😃 Quote Link to comment Share on other sites More sharing options...
MSGManta Posted June 18, 2019 Share Posted June 18, 2019 Hi Mate, do you have oblong headlights for manta GTE, if so please pm me price, I need one for RH side and must be for UK roads, I can get the German ones but no good for beam deflection in wrong direction as we drive on LHS Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 18, 2019 Author Share Posted June 18, 2019 Hi Mike, I'm showing at least a pair of new RHD goldfishbowls in stock but to be honest I don't remember seeing them. I'll take a look in the next day or so and let you know. Cheers, Nick Quote Link to comment Share on other sites More sharing options...
Berlinetta Posted June 21, 2019 Share Posted June 21, 2019 I’m interested in a pair of Headlamps too please Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 22, 2019 Share Posted June 22, 2019 Could that wing be sold to the club for reproduction? Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 22, 2019 Author Share Posted June 22, 2019 @Berlinetta I'm only showing one set of new lamps in stock, plus one single and to date I've found only one side anyway. I'm away for the weekend, but I'll take a look on Monday and see what I really have. @Sutty2006 It's not a simple panel to reproduce (three pressings) but I guess there would be plenty of takers for it. I have a few pairs of wings in the US that I'm going to be bringing back so there's a pair the club could have to use for repros. I guess Paul Brennecker is the man to ask. I have a pair of repro front wings in stock as well as these genuine ones, I guess that means whoever was making repros in the past has stopped? Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 23, 2019 Share Posted June 23, 2019 Aye. Can’t get repo wings, or genuine ones for a decent price anymore. Last repo wing I bought cost 50 quid, was happy with that but sad they didn’t have a matching pair. It’d be good for the club to be able to have some wings knocked up, as they are a fairly common part to need changing. Not sure how bad a repo of a repo would be.... probably fit a Mk3 fiesta by the time it’s been copied a few times 😂 1 Quote Link to comment Share on other sites More sharing options...
garymanc Posted June 23, 2019 Share Posted June 23, 2019 Hi nick you wouldn’t have a sunroof seal in your vast collection of parts thanks Gary Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 23, 2019 Author Share Posted June 23, 2019 Yup, got a few kicking around the place, Gary. There were a bunch of different types, though: - Vinyl roof or no vinyl roof - Ascona or Manta - Early (chrome or black bumpers) or late? Let me know what the combination is and I'll see if I've got something that will work. I may have to send it over from the US when I get back as I don't have all the Manta parts here yet. They're light so they won't cost much to send over though. Cheers, Nick 1 Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted June 23, 2019 Share Posted June 23, 2019 (edited) Hi Nick I would also be interested in a sunroof seal for a manta gte exclusive if you have any. Thank you Mick Edited June 26, 2019 by Mickfrad Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 23, 2019 Author Share Posted June 23, 2019 It's a two-part seal, Mick. I have quite a few of the rear part (15 of the various types) but few of the front. Let me take a look tomorrow and see what I can sort out. Cheers, Nick Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 24, 2019 Author Share Posted June 24, 2019 (edited) @Garymanc - Got sunroof seals that will fit all years of Manta without vinyl roof - I only have the rear seal for Mantas with a vinyl roof. @Mickfrad - I have a pair for the GT/E too. I'm afraid they're not cheap - German sellers know they're rare and so charge for them: Front seal (either 90109294 / 1 91 346 or 90165771 / 1 91 334) - £55 each Rear seal (90197198 / 1 93 823) - £20 each I also have the rear seal (grey strip that fits on the rear part of the sunroof panel (90127793 / 1 91 159) - £8 each Cheers, Nick Edited June 24, 2019 by CalCol Quote Link to comment Share on other sites More sharing options...
garymanc Posted June 24, 2019 Share Posted June 24, 2019 Hi nick it’s a exclusive so I need both parts if I only end up with the back piece I i would be happy sounds a good price for both anyway since I’ve been looking for years let me know payment details when you get chance thanks Gary Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted June 24, 2019 Share Posted June 24, 2019 Hi Nick Once Gary's parts have been sorted I have put my order in. Pm sent thanks again Mick Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 24, 2019 Author Share Posted June 24, 2019 No problem @garymanc, one front and one rear seal are yours. I'll weigh it tomorrow and let you know the price to post it to Manchester, should be cheap as I have some jiffy bags just the right size.. Can you PM your address please. Cheers, Nick Quote Link to comment Share on other sites More sharing options...
Wheelybin22 Posted June 24, 2019 Share Posted June 24, 2019 Can I ask would you have any NOS tail lights? thank you Quote Link to comment Share on other sites More sharing options...
garymanc Posted June 24, 2019 Share Posted June 24, 2019 19 minutes ago, CalCol said: No problem @garymanc, one front and one rear seal are yours. I'll weigh it tomorrow and let you know the price to post it to Manchester, should be cheap as I have some jiffy bags just the right size.. Can you PM your address please. Cheers, Nick Pm sent thanks Gary Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 24, 2019 Author Share Posted June 24, 2019 30 minutes ago, Wheelybin22 said: Can I ask would you have any NOS tail lights? thank you Nothing spare, I'm afraid Darren, I have one pair for myself and that's it. They dried up a few years ago and it's just one seller in Germany that shows stock, but you can never get anything out of him at all, so effectively there aren't any unless you're lucky at the VBOA parts jumble or something like that... Cheers, Nick Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted June 26, 2019 Share Posted June 26, 2019 Seals arrived this morning, Great service thank you Nick. 1 Quote Link to comment Share on other sites More sharing options...
garymanc Posted June 26, 2019 Share Posted June 26, 2019 On 24/06/2019 at 22:47, Wheelybin22 said: 13 minutes ago, Mickfrad said: Seals arrived this morning, Great service thank you Nick. Mine too thanks again Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 26, 2019 Author Share Posted June 26, 2019 Glad they arrived safely. Thanks for letting me know. Cheers, Nick 2 Quote Link to comment Share on other sites More sharing options...
400PEL Posted June 27, 2019 Share Posted June 27, 2019 Hi Nick, I'll take the passenger side chrome door pull surround if you still have it . Do you have any window winders ( black with chrome)? Thanks Allan Quote Link to comment Share on other sites More sharing options...
