execman Posted July 6, 2020 Share Posted July 6, 2020 I'm getting poor pressure on my Frontera fuel rail, with little or no fuel getting to the injectors. I've replaced the pump with a Senator B 3.0 one, and I can hear it running on startup, but the engine starts but not run after a few seconds. I suspect the regulator but not sure; question: is the fuel line input just under the regulator on the Frontera rail, or is it the one on the rear of the rail wtith the 17mm bolt? the Haynes manual I have is for the GTE but i'm running the Frontera rail on a 2.2 Carlton head with big valves, sitting on a 2.7 bottom end. its doing my brain in, so need advice, PLEASE.. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted July 6, 2020 Share Posted July 6, 2020 If your working from the gte manual the feed and return are the wrong way round in the diagram. So worth checking Quote Link to comment Share on other sites More sharing options...
Buz Posted July 6, 2020 Share Posted July 6, 2020 I have a frontera with the engine in if you need photos Also have this Quote Link to comment Share on other sites More sharing options...
Buz Posted July 6, 2020 Share Posted July 6, 2020 It includes roadside repairs which will be handy 😂 1 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 6, 2020 Share Posted July 6, 2020 3 hours ago, execman said: I'm getting poor pressure on my Frontera fuel rail, with little or no fuel getting to the injectors. I've replaced the pump with a Senator B 3.0 one, and I can hear it running on startup, but the engine starts but not run after a few seconds. I suspect the regulator but not sure; question: is the fuel line input just under the regulator on the Frontera rail, or is it the one on the rear of the rail wtith the 17mm bolt? the Haynes manual I have is for the GTE but i'm running the Frontera rail on a 2.2 Carlton head with big valves, sitting on a 2.7 bottom end. its doing my brain in, so need advice, PLEASE.. Just to keep it simple, the pump supplies the rail direct and the pressure reg should be on the outlet returning to the tank. What pressure are you getting at the rail? Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted July 7, 2020 Share Posted July 7, 2020 I agree, you need a test gauge to check pressure...I have a fitted gauge under the bonnet, which help with roadside breakdowns such as blown fuel pump fuses etc 1 Quote Link to comment Share on other sites More sharing options...
execman Posted July 7, 2020 Author Share Posted July 7, 2020 so the fuel in is the 17mm nut end end of the rail with the return under the regulator, on the Frontera, Snowy? i'll purchase a guage asap thanks. and yes Buz, please provide photos of the rail with fuel lines attached. cheers and thanks Mick, i tried swapping round the flow and return pipes under the bonnet, but it made no difference. Quote Link to comment Share on other sites More sharing options...
Buz Posted July 7, 2020 Share Posted July 7, 2020 Hope these help . Let me know if you need any more . The manual says pressure should be approx 3 bar Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 7, 2020 Share Posted July 7, 2020 2 hours ago, execman said: so the fuel in is the 17mm nut end end of the rail with the return under the regulator, on the Frontera, Snowy? i'll purchase a guage asap thanks. and yes Buz, please provide photos of the rail with fuel lines attached. cheers and thanks Mick, i tried swapping round the flow and return pipes under the bonnet, but it made no difference. Does this help? Ignore it says Bosch D. Quote Link to comment Share on other sites More sharing options...
execman Posted July 9, 2020 Author Share Posted July 9, 2020 much appreciated Buz and Snowy; I have something to go on now. 2 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted July 9, 2020 Share Posted July 9, 2020 Also there should be a valve on the fuel rail for a test gauge...looks like a tyre valve... 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 9, 2020 Share Posted July 9, 2020 Thats number 9 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 9, 2020 Share Posted July 9, 2020 On a real picture: You can find it on the left side of the fuel pressure regulator: Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted July 9, 2020 Share Posted July 9, 2020 The Frontera fuel rail set up is so much superior to the standard Manta one and safer in regard to leaks over a hot exhaust manifold ! 2 Quote Link to comment Share on other sites More sharing options...
execman Posted July 14, 2020 Author Share Posted July 14, 2020 fantastic picture H; much appreciated. one drawback of the rail compared to the Manta one, is you cant replace the regulator with an adjustable type like a Sytec/FSE. Quote Link to comment Share on other sites More sharing options...
