Paul Barrett Posted November 27, 2021 Share Posted November 27, 2021 As above from manual car Link to comment Share on other sites More sharing options...
Trooker Posted November 27, 2021 Share Posted November 27, 2021 GM6 has one but it’s more than I want to spend & am in no hurry https://gm6spares.com/Flywheel-CIH-Opel-Monza-GSE-Senator-A-3-0-12v-for-9-or-9-5-clutch-GM-90090415-p281305403 I’ve been keeping an eye out for a while but would settle for a 8.5” GTE one. Link to comment Share on other sites More sharing options...
Sutty2006 Posted November 27, 2021 Share Posted November 27, 2021 Pretty sure I might have what you’re looking for….. 1 Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 27, 2021 Author Share Posted November 27, 2021 Here’s sutty, that would be bonza 1 hour ago, Trooker said: GM6 has one but it’s more than I want to spend & am in no hurry https://gm6spares.com/Flywheel-CIH-Opel-Monza-GSE-Senator-A-3-0-12v-for-9-or-9-5-clutch-GM-90090415-p281305403 I’ve been keeping an eye out for a while but would settle for a 8.5” GTE one. Yeah too expensive for a used flywheel that will need a grind too. Link to comment Share on other sites More sharing options...
611 Posted November 27, 2021 Share Posted November 27, 2021 Ooh, that is expensive! What clutch are you going to fit to it? Andy Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 27, 2021 Author Share Posted November 27, 2021 1 hour ago, 611 said: Ooh, that is expensive! What clutch are you going to fit to it? Andy Was just going with 2.2 or maybe re-drill for an XE one Link to comment Share on other sites More sharing options...
611 Posted November 27, 2021 Share Posted November 27, 2021 1 hour ago, Paul Barrett said: Was just going with 2.2 or maybe re-drill for an XE one Is that skimmed flat for both? Link to comment Share on other sites More sharing options...
Sutty2006 Posted November 27, 2021 Share Posted November 27, 2021 Yeah I’ve got a 9 inch clutch at home. It’ll need skimming as it’s got storage corrosion on it… Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 27, 2021 Author Share Posted November 27, 2021 1 hour ago, Sutty2006 said: Yeah I’ve got a 9 inch clutch at home. It’ll need skimming as it’s got storage corrosion on it… What you want for it mate? Link to comment Share on other sites More sharing options...
Sutty2006 Posted November 27, 2021 Share Posted November 27, 2021 7 minutes ago, Paul Barrett said: What you want for it mate? Do you still have a good B series bonnet? Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 27, 2021 Author Share Posted November 27, 2021 2 hours ago, Sutty2006 said: Do you still have a good B series bonnet? Went couple weeks ago Link to comment Share on other sites More sharing options...
Sutty2006 Posted November 28, 2021 Share Posted November 28, 2021 Bugger 😢 Link to comment Share on other sites More sharing options...
rutts Posted November 29, 2021 Share Posted November 29, 2021 For not much more you could buy a TTV billet flywheel. Bedford cf 2.0 cih flywheel is the one required 6 bolt cover same as 400. Will look what flywheels I have sold last monza one for £50 to big cliff. 3 Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 30, 2021 Author Share Posted November 30, 2021 17 hours ago, rutts said: For not much more you could buy a TTV billet flywheel. Bedford cf 2.0 cih flywheel is the one required 6 bolt cover same as 400. Will look what flywheels I have sold last monza one for £50 to big cliff. Would a 2.3 cf flyweel work? Link to comment Share on other sites More sharing options...
rutts Posted November 30, 2021 Share Posted November 30, 2021 5 hours ago, Paul Barrett said: Would a 2.3 cf flyweel work? Different pcd on crank. Larger in size also Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 30, 2021 Author Share Posted November 30, 2021 Just now, rutts said: Different pcd on crank. Larger in size also Thanks for confirming, I did think so. Link to comment Share on other sites More sharing options...
