mantacrazy22 Posted December 31, 2021 Share Posted December 31, 2021 Hi guys I'm looking at a set of deep dish rims 4x100 et25 7j and center bore 70mm does any one know if they will fit without any mods I'm currently running a standard suspension setup thanks in advance matt Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 31, 2021 Share Posted December 31, 2021 ET25 is a bit too much I think at 7J mate. the spigot would not be an issue as you can get adapter, but they would sit right on the arch lips. You might get away with it, if not get the lips rolled Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted December 31, 2021 Author Share Posted December 31, 2021 Nice one mate ill scrap the idea of thoes👍what et would you say is perfect for the manta not too much poke so it catches arches and not to recessed Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 31, 2021 Share Posted December 31, 2021 ET30 with 7J, depending on tyres ofc, safe is ET35, I am currently ET32 with 7.5Jx17 and 215 tyres at the limit of clearance on front Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted December 31, 2021 Author Share Posted December 31, 2021 Nice one mate thanks for that info the ones I saw where 15s but don't fancy modifying arches or stretched tyres to accommodate 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 31, 2021 Share Posted December 31, 2021 Here is pic, 7.5 front(215) and 8" rear (235) you get idea of clearance to lip then 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted December 31, 2021 Author Share Posted December 31, 2021 What's the profile on thoes Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 31, 2021 Share Posted December 31, 2021 40 mate. 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted December 31, 2021 Author Share Posted December 31, 2021 Cool that gives me a good idea what to look for sweet looking berlinetta BTW mate 1 Quote Link to comment Share on other sites More sharing options...
evo3000 Posted December 31, 2021 Share Posted December 31, 2021 i echo the above et35 7.5j is perfect on the manta without any strut or arch contact but you have to factor the springs in if your going down the lowering route that is👍 However i have often thought if we leave things as GM intended life would be so much simpler👍 1 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted December 31, 2021 Author Share Posted December 31, 2021 My intention was to leave it as gm intended but it's to tempting to throw in a few mods don't think I'll be lowering but will see what it looks like when I eventually get new wheels cheers and all the best 1 Quote Link to comment Share on other sites More sharing options...
evo3000 Posted December 31, 2021 Share Posted December 31, 2021 34 minutes ago, mantacrazy22 said: My intention was to leave it as gm intended but it's to tempting to throw in a few mods don't think I'll be lowering but will see what it looks like when I eventually get new wheels cheers and all the best nice one mate mine is actually on 40mm spax springs and its about right but borderline without rolling the arch. Happy new year to you and all...jase👍 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 31, 2021 Share Posted December 31, 2021 49 minutes ago, evo3000 said: nice one mate mine is actually on 40mm spax springs and its about right but borderline without rolling the arch. Happy new year to you and all...jase👍 My silver 1.8 coupe in the pics is on -40mm but that was from the original 1.8 ride height, that I think is +25mm higher than STD GTE. And it's about right as it looks great. 1 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 1 Share Posted January 1 I've run 7x15 ET25 wheels and they are fine even on a lowered car, infact i'm currently running 7x16" et25 on my hatch too. Have a look at https://www.willtheyfit.com and you can see just how much more there is inboard/outboard with different widths and offsets. Very useful to visualise it. From memory the BMW crosswire 7x15's that many people ran at one point are et25 7x15's, they fill the arches nicely but do not rub. Think i even have a set in my wheel pile still. With et25 on a 7" rim the outer edge is 3.65mm further out than the et35 7.5" example of evo3000 above. So if they fit well the narrower 7" will also work with the lower number offset. The 7.5" rim is 12.7mm wider than the 7", 6.35mm of that is each side if the offset was the same et25 as the 7" wide one. But the offset is et35 which pushes the whole wheel inboard 10mm. So that outer edge would then be 3.65mm in from the outer edge of the 7" et25. The inner edge of the 7.5"et35 is 16.35mm further in than the 7"et25 Oh and for reference if you use the willtheyfit site the standard GT/e alloys are 6x14" et30 with 195/60/14 tyres so you can see what a different tyre size will do to your speedo accuracy at the same time as width for clearance. 2 Quote Link to comment Share on other sites More sharing options...
rutts Posted January 1 Share Posted January 1 15x7 et 25 fit great with 205 50 15 tyres no modification needed. Run them no problem. The hatch is now running 15x8 et30 205 50 15 no touching with a 40mm drop. 3 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted January 1 Author Share Posted January 1 Thanks for the info guys all good to know really like the et25 wheels I've seen but didn't want to shell out a load of money for wheels that don't fit Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted January 2 Share Posted January 2 My Ronals are et25 and fit perfectly. 3 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted January 2 Author Share Posted January 2 1 hour ago, Danny D114BCW said: My Ronals are et25 and fit perfectly. Looks sweet on those wheels 1 Quote Link to comment Share on other sites More sharing options...
evo3000 Posted January 2 Share Posted January 2 Forgot to phone home guys ..my et is 25 not 35 as previously stated on 7'5 rims with 40mm spax lowering springs.will try to find a pic so you can see how she sits but she is still waiting for new paint so looks no where near as good as Dans sadly👍 2 Quote Link to comment Share on other sites More sharing options...
evo3000 Posted January 2 Share Posted January 2 Also just to add they are sixteens.😍😉 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted January 2 Author Share Posted January 2 Thanks mate sits nice on thoes I had 15s on my old coupe but couldn't remember what et they where I lowered it 40mm on spax and bilstien shocks looked awsome 1 Quote Link to comment Share on other sites More sharing options...
