Coolex Aluminium Radiators
les87GTE
I've seen these rads on eBay and wondered whether anyone has had dealings with the company or bought an ali rad from them? They look the part but looks can be deceiving. Also, is there any real advantage in fitting the 70mm version over the 55mm version on a standard 2.0GTE road car?
https://www.ebay.co.uk/itm/401482399714
https://www.ebay.co.uk/itm/403908741211
Any feedback would be welcomed 😁
Bit shoddy from my experience. Have one fitted in the Silver coupe. Paid fir it to be painted black, they packed it with paint still wet so card was stuck to the paint on delivery, contacted customer service who wanted me to pay for it to be sent back to them. The dude tabs are also the wrong length.
Quality wise average, but guess they are cheap enough
Edited by Jessopia74
Add pic
I have one ready to install, bought at the NEC restoration show at a decent discount, so if you can afford to wait until March, do so. I can’t comment on performance or fitting but looks ok, as Jessopia suggests it fits the price bracket. I’ve found Coolex a decent company to communicate with, they did a great job refurbishing my heater matrix
I have one in my 400r turbo, rad works great. Only issue to mention when it turned up it was very dull and marks where it had been welded, when i mentioned this to them they said it should of been buffed/polished, i could of sent it back but to much hassle so polished it myself
16 hours ago, seanpren said:
I am having one made by grp4 fabrications in Ireland at the moment. Fantastic to deal with and top quality
Sounds good, may I ask what the overall cost is to have one made and delivered. Have you asked for a like for like size etc. ?
It's approx €370 to have it made. They've made some for manta b with c20xe before so have all the correct dimensions. Still in production at the moment so can't comment on the actual item yet but have seen first hand the quality of all their other stuff and it's top notch
  • Thanks 1
Thanks Sean,
Sounds good. A little more than Coolex, but sounds like a better overall product and a little less than can be bought from Germany with similar feedback. I would be very interested in your thoughts once you have received it and tried it out on your car. 🤔
5 hours ago, les87GTE said:
Thanks Sean,
No probs I'll post about it when I get it 👍
3 hours ago, seanpren said:
Fits perfect in standard mountings and quality is top notch. Very happy with it
That is well worth the extra, very good job. I like how the top mount tabs are spaced to hold it properly. On the coolex they are not and it can move left/right pivoting on lower fixing
only trouble is TO ME  they all look homemade and spoil an otherwise good looking engine bay. same  as fuel tanks and swirl pots and pointless catch tanks.  !
radiator wise ,as far as im aware you can get a 3 layer recore done to the original end tanks which doesnt look out of place.
  • Thanks 1
I did this with my GSI, a radiator restorer fitted the same core as my "400" in a std. Manta radiator. Had to pay 180€ for it.
  • Thanks 1
All looks very nice indeed Sean, good luck with it 👍.
Re; cam.in.head & H-400 - I hear what you say and part of me agrees but, like with every other part of our cars, it's all a matter of preference by the individual. Some will stick to original spec no matter what and others will modify until there is nothing left to change, with the rest of us somewhere in between. As always, it's good to hear other peoples opinions and I thank you for taking the trouble to post. 😁
I have never had an issue with my recored original radiator with my XE. I heard folk were buying up ally rads left right and centre so I asked a good friend who recored mine, and runs Applied Radiators in stoke. He said that aluminium doesn’t disperse the heat as effectively as the original copper core rads (or brass, I forget which) so decided to stick to original. But if they work and do the job, and look shiney, there’s nothing lost!
