C20XE Manta radiator hoses
seanpren
As above lads...
What ye all using for coolant hoses? I've contacted JS Performance and they've stopped making the set for manta b with XE unfortunately (unless there was a large group buy)
Would like to keep the hoses looking tidy so I'm open to any suggestions on hoses that may fit.....failing that I'll just make up some with some flexible hose and joiners
Cheers
I haven't got around to looking for hoses yet, the ascona I bought came without an engine so no old hoses to go off but was going to ask some of the rally suppliers when the time came as I'm sure the mk2 escort hoses for xe conversions would do the job. Just the heater hoses would be nice if a kit was available of shelf to save any messing
Try Retropower. That’s who supplied my kit years ago. I think the top and bottom hoses are similar to 1.8 ones but the heater hoses are different. Retropower used to have a lot of stuff for XE conversions, I have their clutch kit and manifold on my hatch.
Will update here when I get them but got the XE hoses for mk2 escort off grp4 fabrications here in Ireland. Will need to make a joiner with a t piece for the heater but other than that should be all good. Will let you all know when I receive them and try them out
  • Thanks 1
To update Sean I have spoken with JS performance and they are willing to make some sets as a bulk buy.
Will have further chats with commitee on our next meeting and see what we can do with costings for-
standard set
xe conversion set
th y have confirmed they can do without branding also which is good.
  • Like 7
  • Thanks 1
Hi lads,
Can confirm that the top and bottom hoses I bought off GRP4 Fabrications for XE into MK2 Escort fits fine.
The only issue is the bottom hose is a single piece so will have to be cut to allow a joiner with T piece in it if you're running a heater.
Top quality anyways
Hope this helps
  • Like 4
18 hours ago, seanpren said:
Hi lads,
Top quality anyways
Hope this helps
Good info, Ty
  • 3 months later...
  • 1 month later...
On 15/07/2023 at 20:43, Greg w said:
did any of these hose sets get made or what is available??
No idea Greg but mk2 escort xe hoses work fine. You just need to split the bottom hose and fit in some T's if running a heater
Got mine off grp4 fabrications in Ireland
  • Like 4
