Devil Fish Posted October 23, 2008 Share Posted October 23, 2008 Great stuff Chris,- at least its nowhere near as bad as mine! Is that a vent panel in the inner wing/foot well? Quote Link to comment Share on other sites More sharing options...
Christ Posted October 23, 2008 Author Share Posted October 23, 2008 It shouldn't be too bad the ammount of welding I had done to it a few years back Yes that is a vent on the inner wing. As I've got the polo heater all boxed in along the bulkhead and the scuttle panel vent blocked off (for cosmetic reasons mainly but it also stops water getting in) I need somewhere for it to pull fresh air in from - well that's the idea anyway, whether it does any good is another matter Quote Link to comment Share on other sites More sharing options...
Christ Posted December 1, 2008 Author Share Posted December 1, 2008 It's alive again!!!! Decided last week it was time to drop it back on it's wheels (first time in quite a few months) and get it fired up...... First problem the batery wasn't holding enough charge for long enough - even charging it up overnight the next day it could only turn the engine over for a limited period so I had to buy a new one The petrol's been stood in the tank for a few years now is probably past it's best but as there wasn't much I just added a gallon of fresh, disconnected a fuel line and ran the pump to clear them of old stuff. Then emptied the carb fuel bowls and regulator filter of old fuel and cleaned all the jets just in case they had become gummed up. After a while trying to start the engine I figured something wasn't right - took the plugs out and they were wet so assumed there was no spark. Checked the ECU was plugged in then noticed the earth wire wasn't connected Fixed that but still nothing from the engine. Checked for spark and it was very weak so cleaned the plugs but that didn't help - think it was something to do with them coming into contact with too much petrol while trying to start it (sure there's some technical term for it - not flooded). So I swapped them with some old plugs and it fired virtually straight away, slightly rough, with no oil pressure and then there was a pop it and stopped...... oops The O ring between the oil pump and oil cooler take-off plate had failed Sorted that out by taking the take-off plate out. Tried again and it fired up, stayed running and with good oil pressure. It obviously needs the carbs balancing as the whole car is shaking on idle but I'm happy it's running again One step closer to MOT.... Quote Link to comment Share on other sites More sharing options...
midasmesh Posted December 1, 2008 Share Posted December 1, 2008 Thats good news Chris. Makes me think i should get mine back on the road next year. Quote Link to comment Share on other sites More sharing options...
Christ Posted December 3, 2008 Author Share Posted December 3, 2008 Just a couple of videos to add (just click on the pics) First off trying to get it started.... and then later with it running a bit better.... although I'm struggling to get the carbs balanced and mixture just right - thinking the cold air can't be helping Quote Link to comment Share on other sites More sharing options...
Christ Posted December 3, 2008 Author Share Posted December 3, 2008 Quote Link to comment Share on other sites More sharing options...
garymanc Posted December 3, 2008 Share Posted December 3, 2008 sounding and looking good,straight out off mad max what a the carb's/throttle boddies or whatever there called from,sorry bit thick in that department Quote Link to comment Share on other sites More sharing options...
Christ Posted December 4, 2008 Author Share Posted December 4, 2008 they're just a good old fashioned pair of weber 45 DCOEs with fancy ally ram pipes Quote Link to comment Share on other sites More sharing options...
Devil Fish Posted December 4, 2008 Share Posted December 4, 2008 Still looking as mean as ever! Quote Link to comment Share on other sites More sharing options...
midasmesh Posted December 5, 2008 Share Posted December 5, 2008 It does look moody and mean like its going to to eat cats and spit em out again. (sorry to cat lovers just a phrase) Quote Link to comment Share on other sites More sharing options...
Christ Posted December 14, 2008 Author Share Posted December 14, 2008 A few pics of the bodykit coming together. Originally the arches overlapped the rear bumper and the skirts fitted over the top of the bottom of the arches, it looked OK but it was a bit of a bodge so to tidy it up I've cut the arches into several sections. On the rear the top section bolts to the rear quarter, the bottom rear section is bonded to the back bumper and the bottom front section is boned to the end of the side skirts - it's much the same at the front except there's nothing attached to the front bumper. Where i've cut the arches I've fibreglassed over the end to give a bit more rigidity to them and I've also had to do some filling where they were bolted to the car as they've sunk over the years. Arches attached without sideskirt Other side with sideskirt Front bumper after a bit of fibreglass/filler to blend the new lower part Although the bottom of the S15 bumper fits well I'm thinking the sticky-out bits in front of the wheels may be a little too wide - even with the planned 9" wheels in place, so I'm going to have to trim them down a bit. Quote Link to comment Share on other sites More sharing options...
garymanc Posted December 14, 2008 Share Posted December 14, 2008 looking good,love the front bumper........... beware off speedhumps Quote Link to comment Share on other sites More sharing options...
Christ Posted December 18, 2008 Author Share Posted December 18, 2008 yeah, I love speedbumps - although it's not as low as it might look, I can still get the toe of my boot under there ....... 9x16" Borbet T - fill the arches out a little better Quote Link to comment Share on other sites More sharing options...
fjz400 Posted December 18, 2008 Share Posted December 18, 2008 I flicked down your pixs and my first thought of the last one was 'what the uck as he shuvved on the roof of that poor car' Then I noticed its the end plate from the rear spoiler. Looking good now realy coming along will she be heading down to Billing?? Quote Link to comment Share on other sites More sharing options...
Christ Posted December 19, 2008 Author Share Posted December 19, 2008 I don't know - it should be done by then, but I didn't build it to sit motionless on a show field all weekend Quote Link to comment Share on other sites More sharing options...
Christ Posted October 22, 2009 Author Share Posted October 22, 2009 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 22, 2009 Share Posted October 22, 2009 Gotta say i am loving the new boot spoiler i think it just looks so right on the car Quote Link to comment Share on other sites More sharing options...
Mantaray80 Posted October 23, 2009 Share Posted October 23, 2009 Ducktail Chris? Didn't Baz suggest that one? lol Still, looks good but must have the rear view of a Countach, lol On a personal note, Kyle has bought a Nova and together we are going to get both cars sorted for next year. Welder coming this weekend so I can start doing the Manta's floor Quote Link to comment Share on other sites More sharing options...
Christ Posted November 8, 2009 Author Share Posted November 8, 2009 A few people did suggest a ducktail but I wasn't sure until seeing this S13, so thought I'd have a go at making one. good luck with the welding and the nova Gotta say i am loving the new boot spoiler i think it just looks so right on the car It has come out better than I expected, suprising how something so subtle actually works on this car. I'm in the process of blending it into the boot and spraying it - it looks good in metal from the pics but it was far from perfect Quote Link to comment Share on other sites More sharing options...
opel2000 Posted November 9, 2009 Share Posted November 9, 2009 Hello mate, nice to see the old bus taking a shape on again, I must say though that the years you have had that car this must be one of the longest ongoing Manta projects of all time ever, like we used to say............. It's never finished Quote Link to comment Share on other sites More sharing options...
Mantaray80 Posted November 9, 2009 Share Posted November 9, 2009 Hello mate, nice to see the old bus taking a shape on again, I must say though that the years you have had that car this must be one of the longest ongoing Manta projects of all time ever, like we used to say............. It's never finished Hrumph!!! Clive, mines been ongoing for 15 years...... Well, 22 if you include the time I had it on the road! Quote Link to comment Share on other sites More sharing options...
Christ Posted November 10, 2009 Author Share Posted November 10, 2009 I must say though that the years you have had that car this must be one of the longest ongoing Manta projects of all time ever, like we used to say............. It's never finished don't know what you mean - only bought it 14 years ago like to think of it as more of an evolution over the years, hopefully getting better each time and no, it'll never be finished....... Quote Link to comment Share on other sites More sharing options...
Christ Posted March 7, 2010 Author Share Posted March 7, 2010 Quote Link to comment Share on other sites More sharing options...
czwh42 Posted March 8, 2010 Share Posted March 8, 2010 I guess there's no need for words when it comes to your car. You could have washed it though I love the boot spoiler Chris. Top job. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 8, 2010 Share Posted March 8, 2010 The ducktail rear end looks the biz!! Quote Link to comment Share on other sites More sharing options...
