SENNA1 Posted January 20, 2011 Posted January 20, 2011 (edited) Hi all! I'm about to replace my Vauhall Cavalier's mk1 rear window due to rear element heater that has been 'worn' out . So, a new window is ready to be installed. I'm planning to put the same window seal on because i haven't found a new one to replace.The seal looks as new though! Are there any precautions or anything else to have in mind when fitting the new window on?(e.g. silicon e.t.c.) Thanks to all P.S. Also,what if i'll need to replace the window seal-where can i find one? Edited January 20, 2011 by SENNA1 Quote
andyc Posted January 20, 2011 Posted January 20, 2011 If you can blag a lump of Tyre Soap from your tyre shop that will help with fitting, also a lenght of nylon cord. Just take your time and make sure the screen is lines up before you start to install Andy Quote
Brown Job Posted January 20, 2011 Posted January 20, 2011 If you can blag a lump of Tyre Soap from your tyre shop that will help with fitting, also a lenght of nylon cord. Just take your time and make sure the screen is lines up before you start to install Andy Is it a saloon? Am assuming it is, but obviously this affects fitting, availability of seals etc. Opel Ascona B seal will fit Cav 1 saloon. Occasionally these can be had from European suppliers - or someone breaking a Scone. BJ Quote
mantadoc Posted January 20, 2011 Posted January 20, 2011 If you can blag a lump of Tyre Soap from your tyre shop that will help with fitting, also a lenght of nylon cord. Just take your time and make sure the screen is lines up before you start to install Andy I tend to use elctrical flex / wire as the smooth outside doesn't mark the rubber. I also would have avoided any soap except for getting the shiny or black insert in and instead used some non setting windscreen sealer / mastic as available at motor factors to use in a mastic gun in the rubber the sreen goes in and on the flange that sits on the car. Opel used a more rubbery sticky matic on both places on later cars and Exclusives Quote
opel2000 Posted January 20, 2011 Posted January 20, 2011 I tend to use elctrical flex / wire as the smooth outside doesn't mark the rubber. I also would have avoided any soap except for getting the shiny or black insert in and instead used some non setting windscreen sealer / mastic as available at motor factors to use in a mastic gun in the rubber the sreen goes in and on the flange that sits on the car. Opel used a more rubbery sticky matic on both places on later cars and Exclusives Top post there, totally agree with Mantadoc. I've found the filler strip more of a nusicance thanactually fitting the screens and seals, there is a little tool availbe for spreading the rubber to allow the filler strip to sit in the screen seal nicely, they were widely available, must get myself one again. Quote
SENNA1 Posted January 21, 2011 Author Posted January 21, 2011 Thanks guys for your quick replies! Also,as i asked before,from where could i buy a new seal if i eventually need one? Quote
Julian Posted January 21, 2011 Posted January 21, 2011 Top post there, totally agree with Mantadoc. I've found the filler strip more of a nusicance thanactually fitting the screens and seals, there is a little tool availbe for spreading the rubber to allow the filler strip to sit in the screen seal nicely, they were widely available, must get myself one again. I bought one of these a couple of months ago, and it done the job. No Bother http://cgi.ebay.co.uk/WINDSCREEN-RUBBER-CHROME-TRIM-FITTING-TOOL-EYE-SET-/310277524661?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483dfb4cb5 Quote
mantasrme Posted January 21, 2011 Posted January 21, 2011 I bought one of these a couple of months ago, and it done the job. No Bother http://cgi.ebay.co.uk/WINDSCREEN-RUBBER-CHROME-TRIM-FITTING-TOOL-EYE-SET-/310277524661?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483dfb4cb5 Yeah having a tool is sooo much easier than faffing around trying to get the trim in without one If you can get one a tool with a built in roller is even better, like this Took me all of 1 minute to fit all 4 on a coupe Last time i tried without the right tool took me about an hour (and some swearing ) Quote
opel2000 Posted January 22, 2011 Posted January 22, 2011 Yeah having a tool is sooo much easier than faffing around trying to get the trim in without one If you can get one a tool with a built in roller is even better, like this Took me all of 1 minute to fit all 4 on a coupe Last time i tried without the right tool took me about an hour (and some swearing ) Yup that's the one Dave..... Had one of these ready to fit the filler strip into the V8 and couldn't find it come the time to fit the strip, and ended up using a screwdriver and swearing and damaging the window seal and a couple of areas of paint Quote
Retro Power Posted January 22, 2011 Posted January 22, 2011 When you come to do that on yrs clive we have one of those here u can borrow Quote
SENNA1 Posted January 24, 2011 Author Posted January 24, 2011 That's very helpfull guys but what about the actual seal? From where can i find it? Thanks. Quote
Brown Job Posted January 24, 2011 Posted January 24, 2011 That's very helpfull guys but what about the actual seal? From where can i find it? Thanks. Like I said, try the Opel suppliers in Europe for an Ascona B saloon rear seal. Other than that, ask your local factors what they've got filed under "hens' teeth". BJ Quote
SENNA1 Posted January 25, 2011 Author Posted January 25, 2011 Thanks BJ! Locals don't have one-better to try from somewhere else... Quote
Julian Posted January 28, 2011 Posted January 28, 2011 Thanks BJ! Locals don't have one-better to try from somewhere else... There's a used one on ebay. Quote
SENNA1 Posted January 31, 2011 Author Posted January 31, 2011 There's a used one on ebay. Well,i replaced it at last! Seal wasn't bad at all Thanks again guys Quote
