Robert1234 Posted July 6, 2013 Share Posted July 6, 2013 Well today it's boiling hot, so I thought I'd have a crack at removing the steering column so the car can go for blasting. Here's an extract from my haynes. "Remove the column lower mounting bolt by drilling a hole in its centre (3mm) and unscrew it with a screw extractor" Where can I get a screw extractor from? Also, the grab handles on the roof and the sun visor brackets, how do you remove the blanks from them in order to remove their fixings? Thanks Rob Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted July 6, 2013 Share Posted July 6, 2013 I just ground the security bolt head off and unscrewed it out from the engine bay side with vice grips. I wouldn't bother with an extractor as its not likely you'll be putting the security bolt back in. Quote Link to comment Share on other sites More sharing options...
rutts Posted July 6, 2013 Share Posted July 6, 2013 cut a groove across and use a straight edge screwdriver. Quote Link to comment Share on other sites More sharing options...
stradacab Posted July 6, 2013 Share Posted July 6, 2013 cut a groove across and use a straight edge screwdriver. Seconded! Use a grinder and one of those really thin metal cutting discs. And like has already been said, you ain't putting a shear bolt back in! Quote Link to comment Share on other sites More sharing options...
mantasrme Posted July 6, 2013 Share Posted July 6, 2013 I've tried various screw extractors with no success, the slot and screw driver works sometimes but some are very seized in and won't undo. The only method i use now requires a welder (but if you're shipping it off for blasting you've probably got one as you'll need it when it comes back ) I keep meaning to take pictures of how i do it as its harder to describe than show. But basically put a few blobs (at a good power setting so they bite in) on to the centre of the head to build out a sort of tower. Most of the time thats enough for a pair of mole grips to get old of and undo the bolt, the heat from the welding helps break it free. If its a very seized/stubborn bolt drop an M8 (or M10) nut over the tower then plug weld the nut to the tower. A socket can then be used to undo it, if you just snap the tower off the stud you need to turn the power of the welder up and try again. This method has never failed me and i've removed an awful lot of columns now. Same goes for the shear bolt that holds the ignition lock onto the upper column. 1 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted July 6, 2013 Share Posted July 6, 2013 Cold chisel. And about the re-use. No point putting the old one back in but they are freely available. I always use a new shear bolt. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted July 7, 2013 Share Posted July 7, 2013 What would the reason for Opel fitting a shear bolt in this position anyway? I understand the reason for the one on the ignition barrel but never understood why one was fitted at the bottom. I've always hated removing them Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted July 7, 2013 Share Posted July 7, 2013 another method i have succeeded with is put a center punch mark in the side of the head of the bolt ,then with the punch at an angle drive the head of the bolt round, making more punch marks as you move the head round. Presumable Opel reasoned that if a thief couldn't get the steering lock assembly off the column then the thief would try and remove the whole column, just how the thief would then drive off can't be explained! Quote Link to comment Share on other sites More sharing options...
mantadoc Posted July 7, 2013 Share Posted July 7, 2013 It's obvious why but will not say in a public forum Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted July 8, 2013 Share Posted July 8, 2013 You got me thinking on that, mantadoc... and now i see why Quote Link to comment Share on other sites More sharing options...
Robert1234 Posted July 10, 2013 Author Share Posted July 10, 2013 Thanks guys, a mate of mine with a welder popped round and we had it out in 5 mins. Quote Link to comment Share on other sites More sharing options...
