One For Rick Manta
Oh noooooooooooooooooooooooooooooooo! This would be perfect for me and I bought the 1.8 hatch a couple of months ago, so wouldn't be able to afford this :( There's me struggling with a differential (which is remedial and not restoration) and the ideal car comes along, ah well lives and learns don't ya!?
Thanks for the link Dave, I will be watching it regardless
.......anyone want to buy an Anthracite Berlinetta hatch? :D
You don't need to remove the pod. The light holders pop out and are small 5 w festoon bulbs IIRC.
You could replace them for LEDs
How much improvement in lighting will you get with the LEDs Kevin, as you know the dash lights have never been that good. What is the part number of the LEDs by the way? Thank you.
You need the T5 type 286 LED globes for the Manta from the looks of it.
$_35.JPG?set_id=8800005007
http://www.ebay.co.uk/sch/i.html?_trksid=p2053587.m570.l1313.TR11.TRC1.A0.H0.Xled+286&_nkw=led+286&_sacat=0&_from=R40
LED globes vary greatly, I have had fantastic results where your old dimly lit 80's dash glows like a Modern cars, and some very average results where the light pattern given off by the globes only lights a small portion of the dash , don't buy the real cheap ones, as the quality is not good and they tend to blow quite regular, which can be a pain
Edit: I would probably go for this style as they give a better spread of light on your dash rather than the single LED versions
Edited by GTREA
Do these bulbs fit straight into the back of the Manta dash? And why is the number late lamp mentioned?
you can get better light lust by removing the paper covering the light on standard bulb holders in the dash.
LEDs give better light and you can get different shades of white. Just get a cheap pair ( or 10 ) of 12v LEDs and solder them into standard bulb holders
Hell, give me your address and I'll send you a couple to play with. Just note the + and - on each before soldering
I added LEDs to my keyboard and soldered then into the ' scroll lock' button on the keyboard, now I press scroll and hey ho illuminated keyboard.
I like LEDS, I've just replaced the under cupboard florescent lights in the kitchen for LEDs too
Take care Kev,
Sounds like you could be easily LED!!!
  • Like 3
Thanks for replys lads. Won't get to the car till monday, but I'm guessing I need to reach behind the clocks to get the bulb holders out? Sorry if i'm being daft, just trying to picture it .
Nope
The bulb holders pop out from the top inner under top part of the clock cowl
