Volvo Calipers
brianm
Volvo 240 vented and sierra xr4x4 discs redrilled and middle opened out to fit the back of the manta hub, piping them up is fun and you get loads of travel and then lock up unless you use a bigger ms.
As Paul said, better brakes are available. I like cally t or vectra v6 calipers with cossie 2wd discs
Bmw 3 Series E30 Type, 4 Stud Discs Fit Straight on.
Same P.C.D. as Opel,4x100.So no Redrilling Needed
But on the Manta front brake discs bolts to the back of the front hub and they have a mounting PCD of 92mm
If you fit a 100mm pcd disc onto the front of the hub over the studs your caliper will be a couple of inches away from lining up :unsure:
Will calibra turbo calipers and carleton 2.2 disc combo work or do I need the cossies discs
Cheers brian
No you need cossie discs if you have 284mm calipers
Right sizes of disc and caliper should match to within a couple of mm
Calipers:
Late Calibra turbo turbo/4x4 288mm discs
Early Calibra/cavalier turbo/4x4 284mm discs
Volvo 4 pot 263mm
Astra 16v 256mm
Carlton 2.2 246mm vented discs
Manta B 246mm solid discs
Discs that have the correct offset as standard to fit the manta hub
Rwd cossie 283mm vented
Audi 80 256 vented
Carlton 246 vented
Manta 246 solid
You can also get a spacer made and run fwd vauxhall discs but that is more expensive
That allows 288 discs and calipers
So what works
early calibra and cossie
astra 16v and audi
carlton 2.2 and carlton 2.2
Volvo 4 pots can be used with 256mm discs but there is a bit of pad overhang. Personally don't like that idea but if you check them regularly and remove the overhang or get the chamfered edge pads then its ok as many people do run them.
Only the manta and carlton discs bolt on without modification, all the others need new mounting holes drilling and the centre bore opening up
All the calipers listed above just bolt on with no mods
