Best Carb Upgrade
Den83
32/36 dgv (manual choke) worked well for me .
that one needed a conversion base gasket to make it fit . i'm not sure if all the webers are like that ?
check bonnet clearance just in case , as it all ends up half an inch higher .
Edited by dynamytedan
  • 3 weeks later...
whats the best carb upgrade to replace the varajet  in my manta 1.8?
Something that  would improve the power and that is relativity easy to fit?
It looks as though you have a carb that Snowy wants, and Snowy has a carb that you want :D
Definately need an adaptor plate. Not sure on the jetting. An XR2 is similar power to a 1.8 OHC engine so may be somewhere near.
Go for the 32/36 DGV like I have. Just had it set up on the rolling road. The 2L pinto set up is much closer to what you need that the 1600cvh.
Thanks
What about air filter?
What are the adaptor plates made from? Ally?
Cheers
Air filter is personal choice. There are so many choices for the weber carbs. I will adapt the standard 1800 one to fit in the next few weeks.
I made my own adapter plate out of 5mm thick aluminium plate.
Would you mind sending a photocopy please?
A photo copy of what sorry?
If you mean the adapter plate you just use a manta gasket and a weber gasket overlaid. You will need both anyway.
I would have to strip my engine to take a copy of it for you now. But I can take some pictures tomorrow.
Not exactly thriĺled about the prospect of throttling an untested 30yr old 80k car on a rolling road for a few BHP???
D
It doesn't have to be throttled to check the mixture through the rev range. If you want it set up for power then yes. But no matter which carb you buy you'd need to get it set up properly. So you don't have much choice???
Including the parts that were changed it was £120 for the session.
But I had made certain before I took it in that there were no issues with the install at all. A lot of money is wasted on the rolling road when the operator is fixing the problems you should have sorted before you arrive.
Thanks
Edited by Snowy
