halley cockburn Posted April 24, 2016 Share Posted April 24, 2016 I am just getting a chance to work on my manta again today and still could not get the window winder handle off , I pull it towards me and all i can see is a plastic sort of grey large washer but cant see any spring washer to remove, if anyone could give me a little bit more advise as dont want to break it lol thanks again Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 24, 2016 Share Posted April 24, 2016 (edited) The clip will be between the handle and washer. Thanks Edited August 18, 2017 by Snowy Quote Link to comment Share on other sites More sharing options...
611 Posted April 24, 2016 Share Posted April 24, 2016 you can also get a small flat head screwdriver and push it from the clip open end as you should be able to get the screwdriver in the slot the clip runs in and just pop it out. Easy when you have done it once :-) If your still stuck let me know and i can take a pic of the winder as i have a spare one up in the loft. Looks a lot like this. Quote Link to comment Share on other sites More sharing options...
H-400 Posted April 25, 2016 Share Posted April 25, 2016 This is a picture of the tool we use: found this picture on internet (edelschmiede) and it is easy to make it yourself. Quote Link to comment Share on other sites More sharing options...
halley cockburn Posted April 25, 2016 Author Share Posted April 25, 2016 thanks for all your help hopefully will manage this cheers Quote Link to comment Share on other sites More sharing options...
®evo03 Posted April 25, 2016 Share Posted April 25, 2016 Just be careful, as its springy, it can travel miles, or get stuck in your hair. Once it goes, it goes, never to be found again. 1 Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 26, 2016 Share Posted April 26, 2016 10 hours ago, ®evo03 said: Just be careful, as its springy, it can travel miles, or get stuck in your hair. Once it goes, it goes, never to be found again. Yep. I've done loads of them springs and even so a couple of weeks ago I took one off and it headed for the moon never to be seen again Quote Link to comment Share on other sites More sharing options...
