scottboyd Posted September 9, 2018 Share Posted September 9, 2018 Hi folks, I got full front suspension / cross-member from the excellent Mr Carlos, I'm rebuilding it while my E-reg B coupe is away for welding. I'm really struggling with the poly-bushes. The ones I got are from Strongflex and they list two different for the front and rear: Front: http://www.strongflexuk.co.uk/front-lower-wishbone-front-bush-sport.html#.W5TEPvl9iM8 Rear: http://www.strongflexuk.co.uk/front-lower-wishbone-rear-bush-sport-1311.html#.W5TEdPl9iM8 Btw, I'm not looking for super-hardness so opted for red for the rest (80SHA) but the lower wishbone bushes are only available in yellow (90SHA). The fitting instructions said remove the old bush / leave the sleeve which I have done. Problem I have is that the sleeves have a lip on one side in the front and the back. That suits the rear bush listed above but there's no way the front bush (typical two part poly) is going in thru the front lip (would be easy enough on the non-lipped side). I *think* my car wants the front bush in the style of the rear i.e. push in from one side. I've read practically every thread I could find relating to poly bushes (and seen some excellent work / learnt all a lot), best I can work out is some cars will take the two part front (no lip) and others need the rear-style for the front. Anyone have any ideas? I'll point out too, there's people on here doing some amazing work, that ain't me but I'm doing my best. And at the risk of hijacking my own thread, the rear bush is a nice fit until you push in the inner sleeve, this seems to swell it enough to start to pull out to such an extent that there's no way it's squeezing onto the out-rigger, am I not pushing hard enough? I'm using a vice and it's really pushing, just seems there is too much material when the inner sleeeve is fitted, causing the bush to push itself longways. If the bush was a couple of mm shorter it would be perfect. I don't mind buying alternative bushes if that's the best way forward. Well, I don't mind *much*, nothing good comes easy I guess. Very much appreciate any advice, thanks. Scott Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted September 9, 2018 Share Posted September 9, 2018 Not sure about Strongflex but the ones I got from TJM on here (Superpro I think they were) I had to cut that sleeve out and the new bush came with a new sleeve to press in iirc. If you can stick a pic up of your problem I'm sure someone will point you in the right direction. Quote Link to comment Share on other sites More sharing options...
scottboyd Posted September 9, 2018 Author Share Posted September 9, 2018 Thanks Biffy. Do we just drag files to display pictures? Here goes: Front bush - no lip side Front bush - lip side Rear bush - single pice, goes straight in / butts up to the lip My mate thinks the solution is to ream off the lip, that way the shoulder of the bush will be against the side of the wish-bone, same as it is on the non-lipped side. Think I'm gonna try that :-) Quote Link to comment Share on other sites More sharing options...
IanMc Posted September 9, 2018 Share Posted September 9, 2018 Alternatively, put the bush in a lathe and reduce the thickness of the larger diameter by the same thickness as the piece that extends from the arm. That has to be easier than trying to hold the arm horizontal to the milling cutter. Also that way you still have a standard arm, if that even matters... Quote Link to comment Share on other sites More sharing options...
scottboyd Posted September 10, 2018 Author Share Posted September 10, 2018 Thanks Ian, I think if I reduce the diameter of the bush to clear the lip it will then be slack in the sleeve. I'm maybe confusing the issue with the bottom picture, that's a different issue. Very much admire your progress btw, not just the quality but the steady easy going nature of it. Despite being way old enough to know better I still get overly upset when I'm at the same thing for days, crying like I've just been dumped. Shoulda learned by now.... Gonna try filing off the lip, it's the lip of the sleeve so worst case scenario if that doesn't work out I'll have to remove the old sleeves, like yeti's thread below mine, and get bushes with sleeves. I'll keep you posted :-) Quote Link to comment Share on other sites More sharing options...
IanMc Posted September 10, 2018 Share Posted September 10, 2018 42 minutes ago, scottboyd said: I think if I reduce the diameter of the bush to clear the lip it will then be slack in the sleeve. No that’s not what I meant mate, I meant if you reduce the thickness of the larger diameter on the bush it will move further into the arm and allow you to assemble it into the subframe. If the sleeve in the arm was protruding, say 3mm, reduce the larger diameter on the bush by that same amount. Do you follow? Thanks for your kind words regarding my resto thread by the way, much appreciated. I don’t always stay calm by the way, but I do talk a good job Quote Link to comment Share on other sites More sharing options...
Bonga Posted July 1, 2020 Share Posted July 1, 2020 I know this is an old thread but how did you resolve this Scott. I'm having the same difficulties with mine. Strong flex bushes also. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 1, 2020 Share Posted July 1, 2020 42 minutes ago, Bonga said: I know this is an old thread but how did you resolve this Scott. I'm having the same difficulties with mine. Strong flex bushes also. In those pictures, it looks like the sleeve of the old bush is still in. Quote Link to comment Share on other sites More sharing options...
scottboyd Posted July 2, 2020 Author Share Posted July 2, 2020 I did get them fitted, by carefully hacksawing off the lip showing in the picture. Bush was super difficult to push in, with the benefit of hindsight I suspect that Jess is right, that I have the poly bush inside the sleeve of the old rubber bush. All back together now and is pretty firm so I don't imagine I'll be taking apart anytime soon but I'd defo follow Jess's view that the issue is the sleeve still presnt. I gained so much experience putting my car back together in that I seldom got anything right first time and had to redo, even the engine went in, eventusally got fired up then had to come back out because the buckled rear cover plate was interfering with the flywheel. Almost everything was done twice or three times, it was pretty uphill, at my lock-up on my own. That's why I have no build thread, I'm much too slow, at times I was pretty broken by it all, but I'm super-pleased to have it made it this far, I've had the car for over 20 years 🙂 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 2, 2020 Share Posted July 2, 2020 I might have some pics of my front suspension, but a different brand used. Will have a dig through my phone as not much in my silver coupe thread Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted July 2, 2020 Share Posted July 2, 2020 I used powerflex bushes on my lower wishbones and they looked the same as the strongflex ones above. I spent ages removing the old bush making sure I left the sleeve in place only to find the ones I had fitted without the sleeve. So after removing the sleeves they fitted perfectly. It appears there are different types on the market so depends which you have. 2 1 Quote Link to comment Share on other sites More sharing options...
Bonga Posted July 2, 2020 Share Posted July 2, 2020 Thanks guys spent more than an hour tonight getting one of four of the little feckers out. Bush fits nice now. Just another 3 to go 😮 2 Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 3, 2020 Share Posted July 3, 2020 Hi Billy, look at my topic "Swan neck" page 2, thats how I did this. Succes! 1 Quote Link to comment Share on other sites More sharing options...
jamie077366 Posted July 5, 2023 Share Posted July 5, 2023 Old thread, but, just to clear, there’s a sleeve and on this type of bush in Scot’s pictures the outer sleeve needs removing and the new bush just putting in hole? sorry, I’m sure obvious, but, learn as you go and all that 🙄 Quote Link to comment Share on other sites More sharing options...
Pedro 127 Posted February 24 Share Posted February 24 Good afternoon First of all, please excuse my English. I mounted about 7 years ago on my Manta the whole Strongflex system. I ran into the same problem, of having to remove the bushing and mount the bushes without bushing. I mounted it and thought it was fine, probably worked for a while. This year, it was the fifth trip to the Nürburgring with it, and checking the car in the workshop (I always like to make a severe inspection before a trip) I noticed a serious problem of looseness in the bushing. I have now disassembled the whole front end, and I am going over each and every one of them, and I have come to the conclusion to mount the originals with bushing instead of remounting something like Strongflex. To verify this clearance, I checked it with the car on the lift, and from below turning the steering from stop to stop with inertia, it's scary honestly. I will try to post video of it if required. Best regards! 1 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted February 25 Share Posted February 25 Thanks for the information @Pedro 127 . I did wonder how long these poly bushes would actually last, so knowing you ha ve done a fair few trips with them is encouraging Quote Link to comment Share on other sites More sharing options...
Pedro 127 Posted February 25 Share Posted February 25 (edited) Hace 2 horas, Jessopia74 dijo: Gracias por la información@Pedro127. Me preguntaba cuánto durarían realmente estos casquillos de polietileno, por lo que es alentador saber que ha hecho algunos viajes con ellos. La verdad es que de los demás no tengo quejas (hasta el momento). Con ellos habré hecho unos 30.000 kms aproximadamente. 4 viajes a Nurburgring, incluidos 2 viajes con salida desde Barcelona y recorriendo Europa (5400 kms en 2022). Best regards! Edited February 25 by Pedro 127 5 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted February 25 Share Posted February 25 Great photos 🍻 Quote Link to comment Share on other sites More sharing options...
