GTEPETE Posted January 24, 2021 Share Posted January 24, 2021 https://www.ebay.co.uk/itm/Opel-Manta-Gte-Kadett-C-CARLTON-1-9E-2-0E-CIH-Fuel-Injector-Block-And-Seal-Kit/293955462308?hash=item44711c64a4:g:C7oAAOSwwLBgAHNB 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 24, 2021 Share Posted January 24, 2021 Superb, look like they may be anodised too. Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted January 24, 2021 Share Posted January 24, 2021 Great bit of kit. I've used a few of these now. Much better seal with the o ring instead of paper gasket. Fantastic seller too. 1 Quote Link to comment Share on other sites More sharing options...
moodoo Posted January 24, 2021 Share Posted January 24, 2021 Brain fog...What are the 4 large O-rings in the picture for? The underside of those blocks look like they need thin o-rings for the 'oval' shaped grooves where the blocks meet the inlet manifold? Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 24, 2021 Share Posted January 24, 2021 10 minutes ago, moodoo said: Brain fog...What are the 4 large O-rings in the picture for? The underside of those blocks look like they need thin o-rings for the 'oval' shaped grooves where the blocks meet the inlet manifold? They are what the clamp sits on to the injector body as per pic. Quote Link to comment Share on other sites More sharing options...
moodoo Posted January 25, 2021 Share Posted January 25, 2021 ah,yes,thanks...brain fog! Does that kit on ebay come with the o-rings for sealing to the inlet manifold? 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 25, 2021 Share Posted January 25, 2021 1 hour ago, moodoo said: ah,yes,thanks...brain fog! Does that kit on ebay come with the o-rings for sealing to the inlet manifold? You might need to message the seller as it does not show Orings in pic, but he dies state; Quote 1 x full set of new reproduction rubber seals for holding injectors and sealing in the holders Quote Link to comment Share on other sites More sharing options...
Buz Posted January 25, 2021 Share Posted January 25, 2021 Looks like o rings and bolts maybe in a bag in the top right corner of the photo 1 1 Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted January 31, 2021 Share Posted January 31, 2021 Yes everything comes in that kit. Nuts, bolts, o rings, seals etc.. everything you need. Great kit. 2 Quote Link to comment Share on other sites More sharing options...
Wardmar Posted January 27, 2023 Share Posted January 27, 2023 (edited) I can't get that ebay listing anymore. Does anyone know if he still sells them or if there's a comparable one ? Edited January 27, 2023 by Wardmar Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted January 28, 2023 Share Posted January 28, 2023 On 27/01/2023 at 16:44, Wardmar said: I can't get that ebay listing anymore. Does anyone know if he still sells them or if there's a comparable one ? If your on Facebook pm Alastair Macaulay he's been having a bit of a clear out and doesn't sound like he plans to re stock any itmes 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 28, 2023 Share Posted January 28, 2023 https://www.edelschmiede.com/shop/adapter-einspritzventil-cih-jetronic You can order them as a set for 4 & 6 cyl. engines with O-rings and clamps but also the injector base. Made of alu and black eloxiert Quote Link to comment Share on other sites More sharing options...
Wardmar Posted January 28, 2023 Share Posted January 28, 2023 Thanks to you both. I've messaged Alastair and if he doesn't have them I'll be on to that company. Quote Link to comment Share on other sites More sharing options...
