Help needed to identify front modified brakes
Jonnh
Hi i need some help identifying the front brakes on my Ascona . The cars been in storage for a while and im now starting to work through the jobs to get it all sorted .It looks like the  previous owner has fitted bigger 4 pot calipers but not uprated the discs as you can see the discs  are too small .Can anyone identify what the brake calipers are and what car they are off as ill need to order parts and brake pads . Also can anyone help what brake discs and back plates i will need to get ,hope this makes sense .Thanks in advance
Edited by Jonnh
  • Jonnh changed the title to Help needed to identify front modified brakes
3 minutes ago, Paul Barrett said:
Princess I think
Thanks Paul ,Princess ? i cant open the link or look at your posts so i guess i need to  join as a member  to accesses them
Yeah look like volvo 4 pots although the pics are a little small to be sure, to check you can take a brake pad to your local motorfactors. They should still have brake pad reference books which have scale drawings of brake pads in the back with dimensions.
The volvo 4 pots are meant for a 260mm disc and the standard manta disc is a solid in 246mm diameter. There is also a carlton disc that gives you a vented version in 246mm. Can't tell from your pictures if its a vented disc or solid. From memory i think they did a 4pot for solid discs as well as the more common vented caliper.
Posted (edited)
On 27/04/2023 at 22:30, Rick-Manta said:
I don't think he meant Austin Princess, but was instead insinuating you were a camp homosexual! :lol:
Thanks for all the great reply’s guys and info  ,they are looking like the Volvo ones that Pete mentioned .When I look again ill post an update 👍
Edited by Jonnh
If you want a relatively simple upgrade, depending what size wheels you have, Ford Cosworth 2WD front vented discs are are match for the Manta disc but believe are 280mm diameter. The centre hole needs machining and stud holes spacing changed to Manta one, and a bracket to space the Volvo or Cosworth caliper..
https://www.ebay.co.uk/itm/165939223076?hash=item26a2bf9a24:g:-MMAAOSwfApj5BIq&amdata=enc%3AAQAIAAAA0Jwnf4LXQlwe3S2pBKXzZqskrS1d5R9YL83kc%2FmJoL9rpCnmMlQo3VF2rJla4cpwyhsqQ%2Bs5nqM5XdGH4Wrnrr2SMDzjemjvhjWrxBqtvYIoIVgFobwX3t32TKtkbQ8hnska61oRCfdah25ONCLLG45MoSfibctiMMg1Kt1kngQcGN6EsVkMr91AZ7gkkVU1cwslJnJAFj1w2vbZdk%2BMTYe6PJmDOR6zyy3abQ5YA5dz7sH1qj5loIN4Yg%2BTLVnKEa8VccIQfMtQ%2FZ5BG6nqJTg%3D|tkp%3ABk9SR_jQq8L5YQ
FORD SIERRA escort rs COSWORTH 2wd FRONT CROSS DRILLED BRAKE DISCS PAIR 283mm - Picture 1 of 1Picture 8 of 8Picture 6 of 8Picture 1 of 8
Recon volvo calipers available at brakes international.  Bought a pair last year. Not expensive either.  They have pads and fitting kit to.
