manscoob Posted August 20, 2009 Share Posted August 20, 2009 im just looking some help, im about to go collect a 2.0l gte coupe to do as a project, but first my wife wants rid of the calibra i have in the drive!!! wot i'd like to know is, im gonna use the engine and loom which is the c20 xe 16valve, but is it worth keeping anything else, the likes of the front and rear brakes etc, will anything else be useful for the manta????? cheers john Quote Link to comment Share on other sites More sharing options...
manta88 Posted August 20, 2009 Share Posted August 20, 2009 I used the radiator cooling fan from a Calibra,just needs 4 small brackets making and it will fit to the standard Manta radiator, but you will have to wire in a thermostat and relay to run it. Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted August 21, 2009 Share Posted August 21, 2009 Possibly the front brakes. I have some on my 1.8S which I only know as '16v brakes' as they were done by someone else and it's an area I usually don't bother modding , however someone else told me my brakes look like calibra V6 jobbies. Assuming your calibra is four stud like my old one was then the wheels fit. Did you manage to get hold of the gearbox, sump and other bits you'll need for the swap? Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 21, 2009 Author Share Posted August 21, 2009 Possibly the front brakes. I have some on my 1.8S which I only know as '16v brakes' as they were done by someone else and it's an area I usually don't bother modding , however someone else told me my brakes look like calibra V6 jobbies. Assuming your calibra is four stud like my old one was then the wheels fit. Did you manage to get hold of the gearbox, sump and other bits you'll need for the swap? Hi Rick, no i havent started lookin for parts yet, i need to get everything because the manta is a 2.0gte, i'll pull all the brakes off to have them anyway, pull the cooling fan. the wifes giving me grief, and i still need to get the manta over yet, (she has'nt seen it, that will be a surprise, the arches etc have gone). Quote Link to comment Share on other sites More sharing options...
mantasrme Posted August 21, 2009 Share Posted August 21, 2009 Definatly keep the front brake calipers As your calibra is the 16v it should have 256x24mm discs which gives you the ideal calipers to upgrade your manta (if they're bigger still keep them as the same applies but with different discs). All you need then is a set of the right Audi 80-100 discs to get modified and fit with your calipers. The correct discs were only fitted for a couple of years to the Audi's, you need the ones that are 256x22mm disc's and an offset of 56.5mm (standard manta was 57mm) rather than most which are around 30mm offset. The centre bore needs opened up and 4 new mounting bolt holes drilling by your local engineering place (or one of a couple of people on here can sort that for you if required ) Oh and while the wheels would bolt on they have the wrong offset for the manta. Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 21, 2009 Author Share Posted August 21, 2009 Definatly keep the front brake calipers As your calibra is the 16v it should have 256x24mm discs which gives you the ideal calipers to upgrade your manta (if they're bigger still keep them as the same applies but with different discs). All you need then is a set of the right Audi 80-100 discs to get modified and fit with your calipers. The correct discs were only fitted for a couple of years to the Audi's, you need the ones that are 256x22mm disc's and an offset of 56.5mm (standard manta was 57mm) rather than most which are around 30mm offset. The centre bore needs opened up and 4 new mounting bolt holes drilling by your local engineering place (or one of a couple of people on here can sort that for you if required ) Oh and while the wheels would bolt on they have the wrong offset for the manta. I work for vw so i'll check for thoes sizes! Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted August 21, 2009 Share Posted August 21, 2009 Cut the roof off around the far egde of the sunroof, you can graft it onto the the manta in place of the rusty manta one. If the manta has a rusty sunroof? Covers for the bottom of the seat belts. seatbelt extension on b post Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 21, 2009 Author Share Posted August 21, 2009 Cut the roof off around the far egde of the sunroof, you can graft it onto the the manta in place of the rusty manta one. If the manta has a rusty sunroof? Covers for the bottom of the seat belts. seatbelt extension on b post oh yea, the sunroof and where the drains run in the roof are bad, so do you think the roof is a similiar shape to weld in?? Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted August 21, 2009 Share Posted August 21, 2009 Yes, i've done it See how here.... http://forums.mantaclub.org/topic/11226-mancona-hatch/page__st__20 Quote Link to comment Share on other sites More sharing options...
lepo5 Posted August 22, 2009 Share Posted August 22, 2009 might be an idea to sell on the f20 box as well as other bits and pieces from the car, as the conversion parts you will need (sump and engine mounts) are not cheap, try www.migweb or club calibra, as you might just have the part that someone has been looking for? Quote Link to comment Share on other sites More sharing options...
keith1200 Posted August 22, 2009 Share Posted August 22, 2009 I was speaking to a Dutch guy at the billing, and he's fitted the glass calibra sunroof to his coupe, it look the "dogs dangly bits". Alot cheaper option than replacing the roof skin. GL and looking forward to picture's Cheers, Keith Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 22, 2009 Author Share Posted August 22, 2009 hey kev, that does look well, think i'll start pulling the calibra apart today! i think i'll just cut the complete roof off the calibra, then when the manta's here start cutting it to make it fit. i'll see if i can get a good big angle grinder. if anyone wants the fuel tank or anything, let me know? the cars going to the scrappers nxt week!! Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 27, 2009 Author Share Posted August 27, 2009 started today !!!! the engine is out of the calibra, headlining out, ready for the complete sunroof to come out!! tomorrow im taking the loom and ecu out. gonna cut the roof tomorrow. does anyone know if you can fit the electric window motors and reg in the manta???? Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted August 27, 2009 Share Posted August 27, 2009 started today !!!! the engine is out of the calibra, headlining out, ready for the complete sunroof to come out!! tomorrow im taking the loom and ecu out. gonna cut the roof tomorrow. does anyone know if you can fit the electric window motors and reg in the manta???? Cut the seat belt material out as they make fantastic slings for putting engines in and out. Come and have a look at my car to see how i did the roof transplant if you want to. Remove all the roof wiring and switch before you cut into it and cut just inside the roof bar connection point on the calibra roof. Also remove the rear brace as this fits the inside of the manta roof perfectly and supports the back of the sunroof. Window regs, i tried the calibra ones but they didn't work, they were too big and the window didn't wind down, i got a pair from mickappy that he got from eBay. i think they are ford motors? mk4 granada? standard manta regs with a bit added to the end to take the motor. Also you will need to cut the roof off 2 calibras to do 1 manta roof replacement as you need a top from one, cutting the bottom off it by drilling and grinding spot welds and the bottom from another by grinding the top away. Cheers Kev Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 29, 2009 Author Share Posted August 29, 2009 hi kev, the calibra is now completely stripped, ive cut the roof and the rear support out... ive taken the 2 doors off, i wanna use the solenoids ets for central locking. ive a few ideas going round in my head. i need ideas for the rear lighs too, if you think of any. the biggest problem i have at the min is getting the manta from blackburn to home in preston!!! Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted August 30, 2009 Share Posted August 30, 2009 I have an 'a' frame if you want to borrow it,also a recovery dolly too and a 2.5 turbo volvo to pull it, on condition you join the club Plus the £250 refundable deposit Back lights, keep the bulbs, chuck the rest. Iv'e seen it done and it's an abomination Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 30, 2009 Author Share Posted August 30, 2009 I have an 'a' frame if you want to borrow it,also a recovery dolly too and a 2.5 turbo volvo to pull it, on condition you join the club Plus the £250 refundable deposit Back lights, keep the bulbs, chuck the rest. Iv'e seen it done and it's an abomination hi kev, i was member of the club when i lived back home at belfast, who do i contact again about up-dating and payin the fee mate??? cheers john Quote Link to comment Share on other sites More sharing options...
Snowy Posted August 30, 2009 Share Posted August 30, 2009 Drawing of a standard manta disc. Useful for when you want to get your alternative discs machined. Quote Link to comment Share on other sites More sharing options...
manscoob Posted August 30, 2009 Author Share Posted August 30, 2009 Drawing of a standard manta disc. Useful for when you want to get your alternative discs machined. cheers snowy! john Quote Link to comment Share on other sites More sharing options...
manscoob Posted September 6, 2009 Author Share Posted September 6, 2009 just got the manta today!! now the project starts, i'll add it to 'projects' just as soon as i can work out how to put the pictures on!!! still need to decide on a mancona 400 or a rep manta 400????? just dont know? Quote Link to comment Share on other sites More sharing options...
