Paul Barrett Posted January 15, 2014 Author Share Posted January 15, 2014 (edited) Hoorah bearings have arrived Means I can get in a bit more now at the weekend, chunk of 10mm plate is for the caliper brackets Edited January 15, 2014 by Paul Barrett Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 4, 2014 Author Share Posted February 4, 2014 some progress pics, cracking on with rear diff carrier and uprights, pressed in the old bearing as have more work to do on the uprights offerd up the shafts, both will need shortening 40-30mm managed to suss a way of hanging the diff in the frame, in the end used the E30 subframe mount as before but with some bushes in the mix rear mount took some more thinking.... 285/4017 mahoosive rubber had it lobbed on one of the rims been getting with building a blast cabinet with an old opil drum its further on than this now, just need some glass and flanges to mount some gauntlets, hinges and latch for the door rear mount sussed using a hockey puck! shaved down to suit 2 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 8, 2014 Author Share Posted February 8, 2014 Blast cabinet is nearly done. Few pics Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 16, 2014 Author Share Posted February 16, 2014 got cracking with the wishbones for the rear end this weekend, very time consuming cutting the fishmouths on the tubing to ge them fitting tight, they will be getting a centre diagonal brace of some sorts, but until I source some coilover units I don't know how i want to do it few pics for the toe adjusters, had to slice the tubing to fit the threaded inserts I have, came out well enough all looks a bit rough atmo but will all be getting dressed etc and then blasted up for some epoxy coating comments are criticism welcome! all helps Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 16, 2014 Author Share Posted February 16, 2014 to add, I've tracked down some e46 solid rear discs 10mm thick, correct PCD and look to be same centre bore to the hub I have too, means I can use some Vauxhall astra alloy rear callipers I have sat around as they use 10mm thick discs, and have cable operated parking break function much like vw golfs. Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 17, 2014 Author Share Posted February 17, 2014 (edited) Picked up the new power plant today, stripped it of its auto kept the essentials, bell housing and flex plate for the starter ring. As for gearbox several options to go for- -supra r154 -supra w58 -maybe getrag 265? -bmw 530d box ( will require welding) cheapest option and one I was considering even with the original Saab idea Edited February 17, 2014 by Paul Barrett 2 Quote Link to comment Share on other sites More sharing options...
tony g Posted February 18, 2014 Share Posted February 18, 2014 Nice one paul, you got onto the 8 quick . Just a thought on flywheel. ive learnt that a toyota 3sgte flywheel from a turbo MR2 or celica GT4 can be used. Very slight pcd difference which can be milled to suit. The ring gear on the 3s flywheel will work with V8 but the teeth need a bit of fettling. The starter comes in from the other side on the V8 so the tooth profile at the edges need to be copied onto the 3S. This will make clutch choices a lot easier. If R154 box is used (very expensive) the 3s turbo clutch plate works and If W58 is used the non turbo Mr2 clutch plate will work. I may be able to get a flywheel if you want one. If a whole getrag would work with a bell housing adapter you may invent the next best solution I have a very clever guy near me that can mill and turn anything and Ive used him to make adapter plates and even complete flywheels if you need help here just give me a shout mate. Tony Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 18, 2014 Author Share Posted February 18, 2014 Yeah uve seen the 3sgte is an option, is a route I think I will go down tbh. git the guy down to 300 all in. he has a r154 bix with all flywheel etc but as you say silly money, I have other stuff to get fir the rear end atmo like coilovers. That engineer fruend of yours like an awesome contact! Quote Link to comment Share on other sites More sharing options...
tony g Posted February 19, 2014 Share Posted February 19, 2014 Did you get ecu and loom for that too? Bargain Tony Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 19, 2014 Author Share Posted February 19, 2014 yes I did indeed, he couldn't be bother to remove the autobox as I just wanted the bellhousing! I have spotted a3sgte flywheel on ebay for £50 posted, would you say that's a fair price? Quote Link to comment Share on other sites More sharing options...
tony g Posted February 19, 2014 Share Posted February 19, 2014 Prob a bit dear. Leave it with me for a while. theres plenty you can do first Tony Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 20, 2014 Author Share Posted February 20, 2014 found this earlier of a guy using what looks like triple plate with just the original back plate from the auto setup? Quote Link to comment Share on other sites More sharing options...
tony g Posted February 20, 2014 Share Posted February 20, 2014 Wow, thats a definate no no. The flex plate is normally supported by the converter. That set up is an explosion waiting to happen. Dont do it. Tony 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 20, 2014 Author Share Posted February 20, 2014 That's what I was thinking! Quote Link to comment Share on other sites More sharing options...
tony g Posted February 20, 2014 Share Posted February 20, 2014 Can you send the link where that pic came from? Tony Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 20, 2014 Author Share Posted February 20, 2014 http://www.lextreme.com/forums/showthread.php?t=15257 Quote Link to comment Share on other sites More sharing options...
tony g Posted February 20, 2014 Share Posted February 20, 2014 cant believe no one questioned the set up, maybe they were put off by the 6k price lol Tony ps i saw a W58 for 250 at my mates today Quote Link to comment Share on other sites More sharing options...
GTREA Posted February 21, 2014 Share Posted February 21, 2014 Well this looks familiar I am keeping mine auto for now, but if I do convert to manual down the track I want to run the W58 box, and was just going to pick up a fitting kit such as this http://www.ebay.com.au/itm/1uz-1uzfe-toyota-Bellhousing-W58-W55-W56-W57-G52-gearbox-Free-ship-/271388388944?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f30022e50&_uhb=1 If you are not running PS and AC the belt you need is this one http://www.ebay.com.au/itm/Goodyear-6PK0780-V-Ribbed-Belts-/111268988156?pt=AU_Car_Parts_Accessories&hash=item19e82604fc&_uhb=1 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 21, 2014 Author Share Posted February 21, 2014 (edited) Haha, I must admit I have pinched you idea! I think the w58 is the route I'm going to take, as bang for buck it's the best option, Thanks for the belt link, saves me some research time . Tony, Is that box alone or shifter etc, been offered a bare box for the same monies Edited February 21, 2014 by Paul Barrett 1 Quote Link to comment Share on other sites More sharing options...
simon p Posted February 21, 2014 Share Posted February 21, 2014 I'm liking the look of this engine swap, i'll follow it with interest. 1 Quote Link to comment Share on other sites More sharing options...
tony g Posted February 21, 2014 Share Posted February 21, 2014 Haha, I must admit I have pinched you idea! I think the w58 is the route I'm going to take, as bang for buck it's the best option, Thanks for the belt link, saves me some research time . Tony, Is that box alone or shifter etc, been offered a bare box for the same monies Paul its the complete box with shifter but no bell housing (which you prob wont need) Tony Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 21, 2014 Share Posted February 21, 2014 Great project. I love the fab and the rear axle looks great. Wow those tyres! :-) Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 21, 2014 Share Posted February 21, 2014 Great project. I love the fab and the rear axle looks great. Wow those tyres! :-) 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted February 21, 2014 Author Share Posted February 21, 2014 (edited) Thanks kev! Tony, I may well go for that box, as the Beemer option is looking trickier for not a lot more gain for what I want to achieve initially. Edited February 21, 2014 by Paul Barrett Quote Link to comment Share on other sites More sharing options...
Retro Power Posted February 22, 2014 Share Posted February 22, 2014 found this earlier of a guy using what looks like triple plate with just the original back plate from the auto setup? I'm pretty sure (though not certain of course!) that the flexplate is only there to mount the ring gear on. I think there may be a machined boss in the centre to hold the clutch, with the flexplate centre machined out and fitted to that boss Quote Link to comment Share on other sites More sharing options...
