Manta A Series V8 Supercharged
Paul Barrett
Many thanks for the praise guys but I'm just a mere amateur.
Bit if a downer on the project front at the moment having hit several issues.
1- having to redo the gearbox mount
2- the steering rack issue us giving me a headache
3- I've now found the tilton throw out bearing isn't going to work as the bearing face is too small for the clutch finger contact
Grrrrr.
I think I'm going to take a break from the chassis/drivetrain side of things for a bit to collect my thoughts, will get the workshop all tidied up and tools cleaned down etc. And maybe just then concentrate on cutting the shell floor pan ready to drop on the chassis. that'll be a big motivational push indeed and probably highlight even more issues!
I've seen cars with a spacer between the thrust bearing and clutch fingers for exactly that reason. But do you have enough room for a spacer?
Hhhmm I has crossed my mind, would be dead easy to turn up a flanged ring ooooeeer!
I do need to lose the mounting plate that is actually for bmw fitment and turn up a sleeve to site the HRB and then securing tab or two, so that would gain me loads more clearance for a spacer ring
paul, that gearbox mount is overkill for the power you are making, even when throwing excess of 700hp through tko 600 trannys there is only one bushing with two bolts in horizontal plane holding it and we have never broken one off yet, even at the dragstrip, and the crossmember is 1"  .230" wall! if you google 700 r4 trans mount you will see it, we use a urethane one but they are all the same for th350, 400  r4's etc, check out this pic, this is a 650 hp big block powering this and look at the trans crossmember!
http://lowdownhotrods.smugmug.com/What-we-do/Chassis-and-Frames/1139774_MHktr8#!i=53116858&k=sxjJCgV&lb=1&s=A
i was doing this a while ago when i worked there
Yeah it is OTT but it's staying, or do you think a single bobbin mounted direct to fanned gearbox bracket would be sufficient, it's quite light really,
The whole member itself is to tie the rails together and give me a mountig for the tunnel Structure etc. Cheers for the info guys but too late lol
Well got it on, few issues to address
Need to cut out inner arches fully at the rear and will need to flare the outers to achieve what I want and to provide some clearance to remove the wheels.
Bonnet will need a slight bulge, mk1 capri it will be as I like the look.
Really pleased how it's progressing!!
946B60A5-7F03-464A-B563-19CA82F61E5A_zps
94121328-BF47-49CE-A00F-EAA8D0DFDF4E_zps
B14B6E64-B2B3-4632-B1FF-2EA2731B3446_zps
0089DFCC-C3D9-4955-ABB3-18E185DAC14A_zps
0DBEA8CE-F95B-4BAA-B624-97298727C93F_zps
Happy with shifter position too, rear seating will be a no no, but I'll put a bench in anyway,
You don't have a choice with those monster rear rubber!
I don't know mate before even with the rubber blown to the right psi they where still tucked in the arches but I want to raise her some more but dip the front :D but needs to get over speed bumps lol
  • 4 weeks later...
bit of cut and paste from another forum.......
Bit more done, been notching the subframe and doing lots of trial and error for other bits and pieces, bolted the coilovers in too with machined spacers, will need some heavier poundage springs for sure, prob 350lb I guess,
A6B244D8-BB32-4E85-94D1-377832D4B404_zps
01C55E13-9B57-4AFD-8B96-AA27E8E7C9EC_zps
C4C08589-E0F6-4A49-93D7-E9937934B83C_zps
FE66DF07-F700-41BE-84C6-4DC3DAFAA4E8_zps
Also noticed that now I've setup the gas with additional flow meter like the tig setup my welds are much better.
Had a little play with the stock steering rack positioning, made up a mounting bar for rack then go it in the closest position position possible, looks like I can make it work
4AC5BB15-BD24-4E2E-9250-43AD40BFAB24_zps
45298F20-175E-41D6-92D8-1AD0E8BDFF80_zps
67B67E97-458B-4E2B-994A-085AB645A85D_zps
I will need to fabricate new steering arms though, that is for sure to effectively move the rod end forward and down accordingly
Squeezed an hour in tonight
Turned up the stepped clutch bearing spacer to allow better contact with the pressure plate fingers
71EE3D74-E084-4A45-B668-F5873A92123C_zps
E168A3B0-9DD3-4B96-B0C4-51206E4E147E_zps
Picked a bargain box load of bar offcuts, a small fortune here if I were to buy separate
A639C1E5-0CBE-4C5B-93BC-D54A97101C7B_zps
Been giving the steering arms lots of thought too.
It wouldn't be too hard to fabricate some bolt on extensions using the existing balljoint hole and one of the bolts on the upright,
suggestion from the drifting community gave me ideas of offset rack spacers.....
This design looks achieve able with the tools I have
55E6467E-BCB6-4B0C-81CA-31C14AD53264_zps
I like this design of ball joint bump correction, meant for Porsche application but could be easily copied for the manta, I like the cage adding more stability to the long bolt through
On another note did get some done this weekend
Turned up some stock for making some relocating mounts
EAB93E04-A4CC-4290-AE25-E71828EBAA6F_zps
2D1CAB5B-80EC-42E8-B6EE-8A1DE0B13309_zps
A1D2C9D2-D34D-49A5-B78D-4031D6E15B1A_zps
E94EDF14-757F-4B33-9601-A682B14F5D14_zps
9E8D7DC1-D2FB-4678-83ED-F02C59A81B69_zps
crush tubes in new location
C1589BE8-A00E-436E-BEF2-2709D98A3840_zps
It's mounted up now and clears sump etc. next is to sort the tie rods Ackerman angles etc, I'm settling on using some offset Rack spacers which I will machine up myself, and some adjustable tie rods look likely. It's all a lot more work than I wanted to do and a lot of compromises but, should be worth it hopefully.
Another dilemma I have is tube size for the headers, I have sourced some 1 1/4" ss bends quite cheaply but u feel they are too small., all the guys who build up the lexus motors use tube matched to port size around 1 1/2 inch or more. I have a few cast as bends from an old turbo manifold build from years ago this is the difference
4BC2B9A4-F4FA-4E94-B1AE-12437033AE3A_zps
Using the smaller would be a lot easier for the tight space I have but harder to weld with its thinner wall thickness, but on the upside a lot lighter. But will it restrict my future plans to supercharge the lump, decisions decisions, any guidance from v8 gurus much appreciated
Got a bit done this weekend, got the rack spacers done after a lot measuring and couple of failed trial ones this is what I have, I will be fabricating a further pair of assemblies to lower the balljoints on the steering arms too that will achieve the exact position of the stock geometry.
5CC1D347-0D42-4B43-8107-4AC9CCAEAC3C_zps
Made a start in the sump and oil pickup too, it's all very tight but should work
DD781C6A-1901-4B5F-90D9-8D09246E7F0A_zps
will be much like a manta 1800 sump in shape, with a baffle or two :)
