Just Bought But Is It Worth Saving
D16PJM
I have just bought a manta that has been sat in a barn for the last 15 years, it is running a redtop and had quite a bit done to it but will require a full restoration including lots of welding, I don't mind welding and also do a bit of painting so going to try most on my own, here are a couple of pictures of when I first pulled it out from its resting place
is it worth saving .
Pete
no pictures of the underside at present, boot floor needs work on the seam where it joins the valance, drivers floor pan small hole, seals are good, maybe front swan neck chassis rail as feels a bit soft, under the bonnet it needs welding both sides near battery tray and same on the other side.
it has red top, twin 45s, been cam'd, brake bias box, front has been seem welded, was rolling roaded at 190 bhp many years ago, I don't mind the welding under the bonnet as sheet metal is cheap and its just time fabricating the plate.
basicly what everyone else has said, give it a clean weld it up and drive it.
alot of the hard work has been done for you engine wise which saves you alot of time,also the body kit is also another good thing that has been done for you.
sounds like a good car.
O.K so my next question is regarding parts for these cars, I also have a V8 rover and parts are readily available but the manta seems a little more difficult to get parts, are chassis rails, body parts available, looking around I may need to learn German as most parts seem to be across the water, how do you guys source parts.
Pete
There is a parts section on here if you become a full member with suppliers. There is also a user on here called Opel Parts Greece and they stock all sorts of parts for your rebuild. There is also a Parts Wanted section and not to mention the Project bit where you can put your project up and people will advise you along the way.
Hope you get your questions answered.
Cheers,
Jack.
it's had a clean. I have made plenty of holes and now need to repair, after speaking to the previous owner he tells me it used to be white but he had it painted Guards red to match his 911.
Edited by D16PJM
