Thebishop Posted October 14, 2017 Share Posted October 14, 2017 Hi guys just a quick Q I have a 2.0 gte 8v and I want to get rid of the air box and replace with k&n cone filter. How can this be done with the air meter etc. Any help greatly appreciated Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted October 14, 2017 Share Posted October 14, 2017 (edited) Hi The K&N filter has an adapter to bolt on to the air flow meter instead of the air box. Probably easier to see here http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=271327231394&category=44187&pm=1&ds=0&t=1504864940000&ver=0&cspheader=1 Edited October 14, 2017 by Mickfrad Quote Link to comment Share on other sites More sharing options...
Thebishop Posted October 14, 2017 Author Share Posted October 14, 2017 Ok thanks can I ask is your a k&n or ram air as there is a huge difference in price. Also does it help the car? Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted October 14, 2017 Share Posted October 14, 2017 Mines a K&N filter which was already fitted to the car so how much difference it makes I don't know, I should think the small hole on the original air box is quite restrictive. The ram air one on eBay was the only one I could find on a quick search. A good listing as it shows the adapter sizes. Quote Link to comment Share on other sites More sharing options...
Thebishop Posted October 15, 2017 Author Share Posted October 15, 2017 https://photos.app.goo.gl/bdmRTXacOztv5tRK2 Need to tidy up engine bay any suggestions Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 16, 2017 Share Posted October 16, 2017 I've got a spare adaptor kicking around for the airbox to fit a normal round air filter onto. You'd need to make your own bracket to hold the airbox and filter up but thats not hard, the K+N piece is just a bent bit of metal from memory Oh and the K+N adaptor is for a square fitting air filter which i believe limits you to the K+N only Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted October 17, 2017 Share Posted October 17, 2017 Pug 205 GTi had the adaptor as standard and fits the manta airflow meter Quote Link to comment Share on other sites More sharing options...
Thebishop Posted October 17, 2017 Author Share Posted October 17, 2017 On 10/16/2017 at 09:01, mantasrme said: I've got a spare adaptor kicking around for the airbox to fit a normal round air filter onto. You'd need to make your own bracket to hold the airbox and filter up but thats not hard, the K+N piece is just a bent bit of metal from memory Oh and the K+N adaptor is for a square fitting air filter which i believe limits you to the K+N only How much you want for the adapter mate. Quote Link to comment Share on other sites More sharing options...
H-400 Posted October 17, 2017 Share Posted October 17, 2017 I still use the standard air/filter box, but I replaced the airfilter with one of K&N. Changed the small air intake tube with a self-made one (bigger diameter) and made sure the airbox could get fresh cold air from the front: 4 Quote Link to comment Share on other sites More sharing options...
Snowy Posted October 17, 2017 Share Posted October 17, 2017 11 minutes ago, H-400 said: I still use the standard air/filter box, but I replaced the airfilter with one of K&N. Changed the small air intake tube with a self-made one (bigger diameter) and made sure the airbox could get fresh cold air from the front: This is the proper way to do it. The cone filters are only good if you can get a decent cold air feed. That's not very easy in a GTE engine bay. Quote Link to comment Share on other sites More sharing options...
H-400 Posted October 17, 2017 Share Posted October 17, 2017 Next to the radiator on (your) the drivers-site there is a hole in a panel where the small air-intake goes. The big air-intake is fitted in there (will take a picture of it...) and the red hose is connected with the air intake of the bumper. Just got to be sure my mixture is not to lean when I drive at higher speed so got to check it with a exhaust gas tester... As Snowy wrote: Cold air! Quote Link to comment Share on other sites More sharing options...
H-400 Posted October 20, 2017 Share Posted October 20, 2017 As promised the pic, you all can see the inlet tube is much bigger than the original one. Quote Link to comment Share on other sites More sharing options...
tom child Posted April 1, 2018 Share Posted April 1, 2018 On 17 October 2017 at 18:27, Snowy said: This is the proper way to do it. The cone filters are only good if you can get a decent cold air feed. That's not very easy in a GTE engine bay. Hi just sorting this out on mine your air box has a nice round tube off yours mines seems to be oval is there different air box bottoms cheers Tom On 17 October 2017 at 18:27, Snowy said: This is the proper way to do it. The cone filters are only good if you can get a decent cold air feed. That's not very easy in a GTE engine bay. Quote Link to comment Share on other sites More sharing options...
tom child Posted April 1, 2018 Share Posted April 1, 2018 18 minutes ago, tom child said: Hi just sorting this out on mine your air box has a nice round tube off yours mines seems to be oval is there different air box bottoms cheers Tom Quote Link to comment Share on other sites More sharing options...
H-400 Posted April 2, 2018 Share Posted April 2, 2018 Hi Tom, I gleud a plastic rain pipe in the bottom of the airbox, one of 80mm that makes a curve. I didn't cut complete the oval pipe away, let the top part to press the rain-pipe in with a hose clamp while the gleu was drying. Used the same "construction-gleu" to close the splits and painted after drying with a spray-can. Will look for other pics, grts, Herman Quote Link to comment Share on other sites More sharing options...
tom child Posted April 2, 2018 Share Posted April 2, 2018 Thanks looks spot on if you have more pictures that would be great cheers tom Quote Link to comment Share on other sites More sharing options...
tom child Posted April 3, 2018 Share Posted April 3, 2018 Thanks looks spot on if you have more pictures that would be great cheers tom Would like to see the inside if you have pics Quote Link to comment Share on other sites More sharing options...
H-400 Posted April 3, 2018 Share Posted April 3, 2018 Thought I had some more pics, will take some other pics to answer your question. Inside & outside. Grts, Herman Quote Link to comment Share on other sites More sharing options...
tom child Posted April 3, 2018 Share Posted April 3, 2018 Many thanks that's a class job you've done Tom Quote Link to comment Share on other sites More sharing options...
tom child Posted April 3, 2018 Share Posted April 3, 2018 Hi sorry to be a pain can you take a picture of the tube and where you run it too please cheers Tom Quote Link to comment Share on other sites More sharing options...
H-400 Posted April 5, 2018 Share Posted April 5, 2018 This is the airbox with plastic tubes as they go into the hole next to the radiator. I folded the hole with a pair of plyers (see pic posted in october above) so the tube fits. Still got to finish te air-intake in the front of the bumper. Grts Herman 2 Quote Link to comment Share on other sites More sharing options...
tom child Posted April 6, 2018 Share Posted April 6, 2018 Many thanks nice job now to have a play with mine I'll send pictures when done 👍 Cheers tom Quote Link to comment Share on other sites More sharing options...
®evo03 Posted April 6, 2018 Share Posted April 6, 2018 Nice job, is the air feed from the spoiler? Could a tray be used and funnelled into a similar feed to max the supply! The section below numberplate on GTE spoiler would be a good place, I hear a standard box on mantas and even redtop injections is better than any cone filter, even k&n, if you increase the air supply Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted April 13, 2018 Share Posted April 13, 2018 (edited) Had a bit of time in the garage this evening and spotted an old air box on the shelf. Thinking about Hermans modified example so I decided to have a look, I have a few bits of drainpipe hanging about so I dug these out. Looking at the air box and deciding where to start cutting and how to fit the bits together looked like it could take a while.Instead I thought about heating the drainpipe with a plumbers torch and making it fit. It heats quite quick and becomes soft enough to manipulate, so a bit of heating and sliding onto the air box inlet cutting heating etc I ended up with this. Edited April 13, 2018 by Mickfrad Quote Link to comment Share on other sites More sharing options...
H-400 Posted April 14, 2018 Share Posted April 14, 2018 @Evo: I'm going to connect the tube into the frontspoiler, but want to test it with a exhaust tester while I'm driving cause don't want to take the risk that my mixture is to lean. Think there will be a lot more air supply when the air is forced into the filter cause of the speed. 1 Quote Link to comment Share on other sites More sharing options...
