Sticky Manta
1200bandit
That was a lot easier than l thought (is that the kiss of death)
All the red has gone,so far has not reattached
Dont think l will be painting this weekend
l know what you mean Jess .I Had it all done, left it for 24 hours then started to polish the paint on the bonnet went tits up,
Looking at the front panel spotted a little mark (you whodunnit have found it if you’re not looking)
went tits up , Moral is if it looks ok leave it alone
Edited by 1200bandit
Have put on very dry coats of primer every hour,not rubbing down just more dry coats
So far its looking well , If comes out at 95% right not going to mass with it
Cheers lan . I think l has it sorted , if l have any more mishaps l going to remove a much paint and start again
Have checked the bonnet and looking very good on the primer
lt was to easy 10 minutes with a sander no mapping has not reattached
From this to this in 30 minutes  ?????
Steep learning curve isn’t it.
but glad your getting to grips with it now. The extra 5% as you say, is why we have professional painters. If you get to 95% in all honesty, your are right to leave it be. Let it weather a year and then pay to have it machine polished, then you will get that extra 5% of gloss .
Today didn’t mess about with the paint
l thought l just pop in the garage an have a quick look at the radio
Wiring was a big mess a total f### up
After many hours have now the clock, cig lighter and the radio working
Now need a aerial,but don’t what to start drilling into the body work
Has any one fitted a screen aerial, are they any good
Today flattened the bonnet looking good
After seeing lan work on the inner wings,l made a start on the battery tray which is 100% solid
Give it a few coats of paint, looks good ( this is going to well)
Cleaned the cover behind the battery comes up very good
will give a few more coats of paint
Got some more primer today so have primed the front panel. Might get the front panel painted tomorrow night
then l can get the headlights,front bumper back on
Start cleaning the engine bay up
Has anyone got a cam belt cover for a 1.8 Sri engine
Will find out on Friday
bit of a blow in on the door
Then is the bonnet left to to do
I am going back to the paint shop and get a rattle can to do the inner wings
Was not going to do the inner wings but now the are looking a scruffy
Give the covers for heater motor ect a good clean
Had a quick look at the paint tonight looking good,
l am going to give one more coat of paint
Going to the paint shop tomorrow and getting more paint, harder , thinner
Was going to use a rattle can but going to use proper paint as it covers better
Today painted the inner wings, front panel
put some paint on the o/s door looking like it has not reattached
The inner wings where very easy to do
l don’t think l get any points for masking up
A few hours to mask up ,haft hour to paint
The front panel has a few bits in it but will polish out
I think it will come together when the paper is removed and the covers on the bulk head are clean up , get all the bits on headlights in front bumper on ,spot light wired up then l think l will be getting somewhere
Got to clean that engine as well
Remove the throttle body as the idle adjust was sized (all sort out )
The engine is a 2.0 Sri 130 8 value
It has a coolant hose going to the throttle body but one is blocked off (on the 2.0 chi engine it go’s to a T piece  heater hose )
Put some sound dreading on the bulk head (as the exhaust runs down that side it seams a bit loud)
Flattened polish the front panel it has come up really well
Refitted the headlights, lights all work
Put the front bumper on lt looked bad , l thought the front bumper was ok but put it against the front panel and wings not so good
So after wiring up the spot lights up have to cut the wiring to remove the lights.
made a start on the bumper.Hope to paint in the week
  • Like 6
