IanMc Posted August 17, 2019 Share Posted August 17, 2019 Hi all, This morning I noticed a damp patch on the carpet under the front of the Cav. Upon further investigation, I saw a damp patch at the bottom and the occasional drip from about a third of the way up the core. I have removed the rad to try to get a better look to see if it could be soldered or use Chemical Metal to fix the hole (that so far I can even find...). This wouldn’t be any issue if the car was a manual, as replacement rads are easy to come by and relatively cheap. Remember that my car is an auto though, which has the auto trans cooler connections at the base of the main rad... Lets assume for a moment that I can’t source a replacement rad cheaper than the ones available from Germany at about £240 - any suggestions as to what to do? I wondered about using a rad from a manual car, then trying to connect up a separate oil cooler for the auto trans fluid. Good idea, bad idea, other suggestions? Thanks in advance everyone. Quote Link to comment Share on other sites More sharing options...
hoobby Posted August 17, 2019 Share Posted August 17, 2019 Hi Ian I always used Colchester radiators will re-core and repair old rad. Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 17, 2019 Author Share Posted August 17, 2019 47 minutes ago, hoobby said: Hi Ian I always used Colchester radiators will re-core and repair old rad. Hi Graeme, I did actually look at their website earlier - what sort of money are we talking about? Quote Link to comment Share on other sites More sharing options...
hoobby Posted August 17, 2019 Share Posted August 17, 2019 (edited) It used to be about half the cost of replacement haven't used them for 15 years then you would just exchange you old rad for a recon never had any problems. Edited August 17, 2019 by hoobby 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 17, 2019 Author Share Posted August 17, 2019 Thanks mate, I will give them a call next week and see what they say. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 17, 2019 Share Posted August 17, 2019 Ian, don't be too put off using a STD rad and a coiling loop in front of the rad. These are god enough for cars like my Jag, they are certainly good enough for the manta 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted August 18, 2019 Share Posted August 18, 2019 My radiator will be re-cored and costs me with the thick core of 53mm 180€ (inc. vat) and the normal core 140€. Always had the impression the prices in the UK were cheaper so I would recore it. I fitted an electrical fan from the scrap-yard with some hand-made brackets and no problems in the tropical sun (traffic-jam) of the south of France. 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 18, 2019 Author Share Posted August 18, 2019 Hi Herman, I hope that you are keeping well? Thanks for the info, as always you have been very helpful Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 18, 2019 Author Share Posted August 18, 2019 As the leak was so tiny, I have decided to try the following: - disconnect the heater hoses from the matrix. - join them with a straight connector. - add Barrs leaks (or similar) to the main radiator. - after the leak is fixed (assuming the additive does the job), drain the rad and hoses. - reconnect the heater. Got to be worth a try! Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 18, 2019 Share Posted August 18, 2019 hi ian. wont do any harm especially as you say to avoid getting it in the heater core. pity you couldnt have found the pinhole .it would have soldered up as original rads are copper i beleive not ali. if you are doing this whilst looking for a spare bear in mind an auto rad from a mk1 carlton or rekord 78-83 is also the same unit(2.0 but not 2.2) bar the outer frame which is swappable. or as has been said ,fit a standard 1.9/2.0 rad with a cooing loop or suitable unit. also il keep an eye on ebay .stuff turn up eventually 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 18, 2019 Share Posted August 18, 2019 I always get my radiators reconditioned. I use Applied Radiators in stoke. Last manta rad I had done was £100 recored. They test and paint them too. 1 Quote Link to comment Share on other sites More sharing options...
