spot welding sills
shaunwilli
Spot weld.  In standard positions on the top edge. Interesting if they would accept spot/rose weld on the bottom edge to inner sill.  Would look original though and they probably won’t even notice.
IIRC I’ve done spot/ rose weld on lower edge.  If it’s done properly they won’t fail it.  If it looks shonky they will.
27 minutes ago, shaunwilli said:
It runs half way on the bottom of the b pillar and is attached to the bottom inner section of the A pillar.Would have liked too have past the b pillar but with the shape of the inner sill it would have meant not having it tight on the inner sill for welding it onto.
Thanks for the explanation, that will be very helpful
