project marmite
Christ
  • Replies 142
  • Created
  • Last Reply
Top Posters In This Topic
lightweight flywheel the other end (4.1Kg, old one was 7.6Kg)....
New flywheel requires M8 clutch bolts, rather then the M7 std ones, which I didn't realize until trying to fit it yesterday
If you don't mind me asking, where did you source the lightweight flywheel?
LMF Vauxhall :thumbup
Had a look at several but this one came with integral ring gear which the others didn't.
Looks identical to a std one from the front, all the bulk is missing from the back....
Apart from the fact it didn't come with clutch bolts (emailed them, see if it should have) can't fault it or their service, very quick delivery.
Also used them for the headgaskets.
If ordering from them just remember to check their ebay store as well - vauxhallpartsuk - the flywheel was about £20 cheaper from their website but the HG £10 cheaper from their ebay store :o
that would be telling ;)
oh, and I made this today.....
to replace the cut down 1.8 plastic coolant t-piece behind the water pump, think i might have cracked it tightening the clips up the other day :rolleyes:
Edited by Christ
What are the bits and bob's in the last pick for then?
Put them together with some lengths of CDS tubing and you get door bars......
Foot plates welded to one end....
Bolted through the footwell to another footplate with captive nuts....
And attached the other end to a bracket welded to the existing half cage....
Cage needs removing to get a full seam round the bracket.
Closer fitting exhaust....
  • 1 month later...
Been a while so a quick update then......
While working on the cage I welded in some spreader plates for the main hoop, something I should have done when first fitting it but didn't know (before the days of the internet :unsure: )
Made some brackets to weld to the main hoop which will bolt up to the seatbelt mount on the B-pillar..
More brackets, this time to attach to the cross bar....
Another set of brackets, which clamp round the harness bar to hang the nitrous bottle from...
Time to tackle the bodykit next
Cut down the splitter so it doesn't stick out quite so far and extended the centre section uprights....
Added some aluminium angle to the edges of the sideskirts to square them up a bit to match the rear of the front bumper.....
Ran the angle grinder along the bottom of the rear bumper and dropped the leading edge to tie in with the sideskirts...
The other side to compare...
Also fitted some longer studs in the front hubs so I could use bigger spacers..
In between rubbing down I've been having fun and games with the engine, first off it started running really rough, sounding like it was running on 3 cylinders. Compression test was good, spark seemed good, swapping plugs over had no effect, puling plug leads to see which cylinder wasn't firing yielded this result....
:o
Threw in some new plugs and that sorted it, think the short runs had fouled the old ones too much
Engine was still smoking/breathing heavy though so, as comp test was good decided to replace the valve stem oil seals (henceforth referred to as vsos), didn't want to remove the head again so made a little something (out of scrap) to compress the valve springs with it in place and cord down the bores to hold the valves.
Once I'd sourced some vsos pliers the job went quite well, although if I were to do it again I'd make the compressor lockable to free up another hand to reinstall the collets.
7 out of 16 split vsos...
All back together is seems to have done the trick
You still tinkering with that Chris!?!:thumbup
Still looking good, I reckon you and I should swap once mine is finished!!!:D
Glad to see it evolving again, keep it up.
I could be tempted to take that slow old thing off your hands ;)
Oh my god that thing is awsome! That is so bad-ass! Look like it came out of the set of Mad Max or something, absolutely stunning. Great work !
Thanks :thumbup
Been following the build on RR, you must work on that car every day!
Yea i think the new side looks better than the old, works better with the Mantas sharp edges.
The valve compressor is fantastic :thumbup
BTW i got some hub centric spacers off ebay cheap as they were listed for a Misti Colt, same pcd and similar bore
Edited by Kevin Abbott
Yeah, actually I do try to work on it every day - little and often seems to be doing the trick, my garage isn't at the house so I call in on the way to work in the morning and do an hour and again on the way back for an hour or so more.
Will have to check out ebay spacers......
Edited by Christ
  • 4 weeks later...
Looks absolutely great! The exhaust is not in my taste, would look better with an exhaust goint out of the side just before or after the rear arch but that is just my oppinion, other from that, i still think it is absolutely awsome!! thumbsup.gif
Seemed to go down well with the crowd at retro show this weekend (being the only manta there for some reason).....
behaved itself too, apart from a slight problem with the alternator bracket on the way home :unsure:
Edited by Christ
Damn shame the Retro show was the same weekend as Billing, (I didn't realise this) Good to see a Manta prescence there though Chris :thumbup
Typical of the VBOA to create such a clash though, as I'm sure Billing was normally later in july.
You going to Japfest 2 at Donnington at the weekend? I'm tempted as it is just across the road from me, but cash may be just a tad too tight.
