johno 14 Posted July 16, 2011 Author Share Posted July 16, 2011 Have used ikea pan, should soak some of the heat and not blister the paint on the bonnet... Quote Link to post Share on other sites
johno 14 Posted July 30, 2011 Author Share Posted July 30, 2011 Quote Link to post Share on other sites
johno 14 Posted August 9, 2011 Author Share Posted August 9, 2011 Quote Link to post Share on other sites
johno 14 Posted August 9, 2011 Author Share Posted August 9, 2011 Will be fitting pair of these to volvo axle now theres no torque tube or center bearing to keep axle in place!! will be sorting bigger injectors and fuel pump soon... should be running 10 psi through each turbo will make things interesting.. Gulp Quote Link to post Share on other sites
johno 14 Posted August 25, 2011 Author Share Posted August 25, 2011 Hope if i sculpt enuf foam from underside of back seat will be able to re-fit it??.. Quote Link to post Share on other sites
Kevin Abbott 1,340 Posted August 25, 2011 Share Posted August 25, 2011 (edited) Nice work Are they Rally design boxes for the Atlas axle? Also, now you have 4 linked it do you need the lower spring pan links? seem redundant to me Edited August 25, 2011 by Kevin Abbott Quote Link to post Share on other sites
johno 14 Posted August 25, 2011 Author Share Posted August 25, 2011 Yeah bought from rally design, thinking of fitting stronger springs and bump stops.. Quote Link to post Share on other sites
johno 14 Posted September 24, 2011 Author Share Posted September 24, 2011 Quote Link to post Share on other sites
johno 14 Posted September 24, 2011 Author Share Posted September 24, 2011 Replaced standed actuators with these fully ajustable one,s have set of bigger injectors and should have bespoke plenum end nxt week, still need order new uprated fuel pump and fuel lines... busy working to pay for these but hope find the time have them all bolted up and working at some point?!.. Quote Link to post Share on other sites
gary6303 13 Posted October 7, 2011 Share Posted October 7, 2011 HI JONNO, SO HOW WIDE WAS THE VOLVO AXLE AND HOW WIDE IS IT NOW MATE AS I MAYBE GOING THE SAME ROUTE, IS IT A 1030 AXLE OR THE 1031, 1031 HAS TWO RIBS THAT ARE ON THE SIDE OF THE DIFF CASE AND WHAT VOLVO DID YOU GET IT FROM. Quote Link to post Share on other sites
johno 14 Posted October 8, 2011 Author Share Posted October 8, 2011 Hi gary, cant remember the overall length of volvo axle, if used with big arched 4oo manta then there be no need cut axle.but if like me your running standed body work had to chop 23mm from each side of axle and you would need to cut 15mm from each half shaft spline before you ended up with the same overall length as the manta axle. as regards axle i used 1030 axle from 760 turbo volvo,but i think same axle was also used in the 240 range..there are couple of diffrent diff-lock set up with these axles but i think all are up to the job, you can also change internal diff / half shafts from one axle to another, but as i found you cant interchange half shafts from one axle with diff from another axle. regards johno.. Quote Link to post Share on other sites
johno 14 Posted December 3, 2011 Author Share Posted December 3, 2011 Hi all, after finding out that stretch bolts in heads start to lift at 16psi.. have spent the day changing them for some uprated ones!!.. as im going to run 20psi just to be safe..have had to order bigger pair of turbos for bit more blow-have set of uprated injectors now! but still waiting for new inlet maniifold to arrive? going to make two new link pipes and re-work the turbos to front of engine bay as im not happy with all pipe work as is!! will post some pics soon! Quote Link to post Share on other sites
johno 14 Posted December 7, 2011 Author Share Posted December 7, 2011 These pair of mofo,s turned up to day.. thay are an upgrade from t28,s... have change actuators thay set at 16 psi!! Quote Link to post Share on other sites
Devil Fish 164 Posted December 7, 2011 Share Posted December 7, 2011 Quote Link to post Share on other sites
johno 14 Posted December 20, 2011 Author Share Posted December 20, 2011 part of new exhaust made and wrapped.. Quote Link to post Share on other sites
johno 14 Posted December 21, 2011 Author Share Posted December 21, 2011 Quote Link to post Share on other sites
johno 14 Posted December 23, 2011 Author Share Posted December 23, 2011 started to sort out pipework to intercooler.. Quote Link to post Share on other sites
johno 14 Posted January 3, 2012 Author Share Posted January 3, 2012 Quote Link to post Share on other sites
Kevin Abbott 1,340 Posted January 3, 2012 Share Posted January 3, 2012 Holy huge turbos Batman Love it, great pipework Do you bend those pipes yourself? Quote Link to post Share on other sites
garymanc 643 Posted January 3, 2012 Share Posted January 3, 2012 awesome,going to sound well when the turbo's kick in Quote Link to post Share on other sites
berni 5 Posted January 4, 2012 Share Posted January 4, 2012 how much are parachutes these days!!. lol 2 Quote Link to post Share on other sites
johno 14 Posted January 4, 2012 Author Share Posted January 4, 2012 Been buying tight 90 bends from jetex not cheap but def must to squeeze it all in!.should sound sweet blowing through 3" into 4" pipework? ya get free parachutes with each turbo you order.... :) Quote Link to post Share on other sites
johno 14 Posted January 17, 2012 Author Share Posted January 17, 2012 picked up the new phenum today have a t5 gearbox waiting in the wings im sure it wont be long before it needs bolting in?!! recon i need to re-think the brakes as well... Quote Link to post Share on other sites
johno 14 Posted January 27, 2012 Author Share Posted January 27, 2012 1 Quote Link to post Share on other sites
Sutty2006 597 Posted January 28, 2012 Share Posted January 28, 2012 Thats one hell of a monster!!! You'll need a sticker for the back window "boostin' fer Jesus!" Awesome! Quote Link to post Share on other sites
