New Opel Manta Project (Hopefully)
h0tr0dder_uk
  • 1 month later...
I bought the hubs off TJM. https://mantaclub.org/profile/553-tjm/
Discs and calipers really depends on your setup. I went with 5 stud ford hubs so I could fit the wheels I wanted.  So I got the brake hats and rotors for a 2006 ford mustang.  Calipers are Wilwood Dynalite and I had to make a custom bracket to fir them.
Finally back on the car after a few weeks off following laser vision surgery.
Finished up the offset brake pedals.
https://drive.google.com/file/d/1FzEvCN6gCzd8NygaymLZaQSc75RrJtEc/view?usp=drivesdk
https://drive.google.com/file/d/1FyBdg1NCmbaBvjnjH8CcE39uPr1zguaV/view?usp=drivesdk
Now that they're finally in place I could continue with the firewall build. Last 3 panels still need a little trimming before welding in place.
https://drive.google.com/file/d/1Fx9C8iUgDUIqjnJGpJ_zXCHPzhra6-ZN/view?usp=drivesdk
That firewall move really improves the space in the engine bay by quite a large amount, but from inside does not look like it would cause too much of a constraint. However, those offset pedal would take some getting used to. I find driving cars that have the steering wheel that feels offset to pedals pretty annoying. Hard to judge from picture angle. But this is a different case ofc 😎 Fun factor 100 😂
  • 3 weeks later...
So I had a change of mind and decided to cut the front off my Manta
https://drive.google.com/file/d/1LhdI9zzgW1EyR1m3Irvmp9i-dDBE4Wqc/view?usp=drivesdk
So I had to make some new panels to fill the hole and add back some strength
https://drive.google.com/file/d/1LYNzNP6UeXtQ5AvhuWJbS9dyhxI7uWyF/view?usp=drivesdk
Then I could refit and paint the original turbo front spoiler
https://drive.google.com/file/d/1LZarjW4800gjyI1-dqeAdkWfQkfm5Es-/view?usp=drivesdk
So this means I had to fit a smaller intercooler. Hope it's up to the job
https://drive.google.com/file/d/1LcL9n-eYT9--ELNEUcQhXQXOMfdRhJ4A/view?usp=drivesdk
  • 5 months later...
It's about time for an update. House and yardwork put the Manta on the back burner but I have made some progress.  I finished a full rebuild of the suspension, with all new ball joints, poly bushes, shocks, bump stops etc.
https://drive.google.com/file/d/1GiNezeVyrCGxJmqgzlliO1mLPVA8RqjT/view?usp=drivesdk
https://drive.google.com/file/d/1meRuDS10p09hvPVNz62_bqLFx35dD2hh/view?usp=drivesdk
https://drive.google.com/file/d/19Js7cSneYhVlgn2706OHr6b1mLCjpmZ5/view?usp=drivesdk
https://drive.google.com/file/d/1yzvBZyWXjPWmBGnci2tZGonYyJq9HEky/view?usp=drivesdk
I also finished fully welding in the new firewall and am now working on finishing the transmission tunnel welding.
  • Like 3
Top work. I Need some new arms as I have same issue on my 400 with the early hubs and slightly lower steering rack. I did chop/weld one to get the correct angle, just not around to having it drawn up ready to be machined.
However, those extended ball joint fixing you have look quite sturdy. Not sure how strong they are are overall with knocks etc? They a long term solution you think ?
(added pic so you know what part my rambling is about)
The steering arm extenders were suggested to me by a friend that runs a professional hot rod fabrication shop.  They look really strong but ultimately I might try to get some new steering arms fabricated.
  • Thanks 1
The MantaA/ AsconA and I guess GT stub axles/uprights have bolt on steering arms, so that might help you too?
  • 4 weeks later...
11 hours ago, h0tr0dder_uk said:
Finally got some time in the garage and was able to weld in most of the remaining sheet metal.  Just need a few more pieces to finally make it waterproof.  Then seam weld and seam seal it all before painting it
https://drive.google.com/file/d/1Qvlk-GeZq9hg0VLIwDyXnpvHfTEodM1N/view?usp=sharing
Beautiful 🙌
