penyghent 5 Posted June 29, 2020 Share Posted June 29, 2020 Hi does anyone know the bolt size for connecting front axle extensions to the chassis legs on an A please. Cheers Quote Link to post Share on other sites
rutts 453 Posted June 29, 2020 Share Posted June 29, 2020 M14 iirc Quote Link to post Share on other sites
penyghent 5 Posted June 29, 2020 Author Share Posted June 29, 2020 Cheers, what does iirc stand for please. Quote Link to post Share on other sites
611 399 Posted June 29, 2020 Share Posted June 29, 2020 Not sure but they should have a Castle nut with split pin through them. I might have a spare one if you need one? Andy Quote Link to post Share on other sites
mantasrme 615 Posted June 30, 2020 Share Posted June 30, 2020 9 hours ago, penyghent said: Cheers, what does iirc stand for please. iirc is 'If i remember correctly' They are M14 bolts originaly as Andy says they have a castle nut and split pin end to them. But i normally replace with a straight bolt and nylock nut Quote Link to post Share on other sites
penyghent 5 Posted June 30, 2020 Author Share Posted June 30, 2020 Cheers , needed to check as the hole in my chassis legs is 12mm . Quote Link to post Share on other sites
robah 571 Posted June 30, 2020 Share Posted June 30, 2020 I am sure the bolt should be Grade 10.9 material strength as well Grades of bolts Although this Bolt Grade Calculator doesn't have 14mm diameter, it does show the difference in grades of bolts. Most 10.9 bolts are usually Dark Grey/Black in colour I hope this diagram helps Quote Link to post Share on other sites
penyghent 5 Posted June 30, 2020 Author Share Posted June 30, 2020 Cheers for the diagram very usefull . Quote Link to post Share on other sites
cam.in.head 300 Posted June 30, 2020 Share Posted June 30, 2020 very usefull diagram yes. is that not for a b series thou ? Quote Link to post Share on other sites
Snowy 455 Posted July 1, 2020 Share Posted July 1, 2020 12 hours ago, cam.in.head said: very usefull diagram yes. is that not for a b series thou ? That is definitely B series Quote Link to post Share on other sites
cam.in.head 300 Posted July 1, 2020 Share Posted July 1, 2020 exactly. is the bolt the same on an a series which he was after ? 1 Quote Link to post Share on other sites
penyghent 5 Posted July 1, 2020 Author Share Posted July 1, 2020 Cheers, its meant to be M14 from what i've learnt, but my new chassis leg has a 12 mm hole which i'm reluctant to drill out. So I'm going to get the bushes sleeves made with a 12mm hole, hopefully this will be strong enough. Quote Link to post Share on other sites
611 399 Posted July 1, 2020 Share Posted July 1, 2020 2 hours ago, penyghent said: Cheers, its meant to be M14 from what i've learnt, but my new chassis leg has a 12 mm hole which i'm reluctant to drill out. So I'm going to get the bushes sleeves made with a 12mm hole, hopefully this will be strong enough. Do you want me to look out and measure an A series one? im sure i have one in my box of bolts. The chassis leg should be sleeved to stop it collapsing. Torque nut to 58 ft lbs Here is a pic of the A setup. Andy Quote Link to post Share on other sites
penyghent 5 Posted July 2, 2020 Author Share Posted July 2, 2020 Cheers Andy for the offer and the diagram, for some reason the chassis leg hole is 12mm so I'll get M12 bolts. Quote Link to post Share on other sites
penyghent 5 Posted July 2, 2020 Author Share Posted July 2, 2020 Hi Andy Have you an M14 bolt and nut please I could buy off you. Just reamed the chassis leg hole out so i was wrong about the 12mm hole. Cheers Mark Quote Link to post Share on other sites
611 399 Posted July 2, 2020 Share Posted July 2, 2020 Hey Mark Just picked this up. Let me take a look first thing in the morning for you and let you know. That i had one knocking about, not sure on the nut but will take a look and let you now firsdt thing tomorrow. Andy Quote Link to post Share on other sites
Kinose 0 Posted January 28 Share Posted January 28 Hi, For detail information about bolt types and size you can visit following websites. http://www.oshwin.net/alloy/inconel/inconel-bolts-type-astmf2281-inconel-bolts.html http://www.oshwin.net/alloy/inconel/inconel-nuts-type-astmf2281-inconel-nuts.html http://www.siddhagirimetals.com/inconel-alloy-600-fasteners-supplier-uns-n06600.html http://www.siddhagirimetals.com/monel-alloy-400-fasteners-supplier-uns-n04400.html www.oshwin.net/alloy/inconel/inconel-600-bolts-suppliers-manufacturer-stockist-exporters.html Quote Link to post Share on other sites
