Mickfrad Posted March 9 Share Posted March 9 After getting my exclusive back on the road it suffered with clutch judder pulling away. I had another clutch and friction plate which I sent off to be refurbished. Fitting this refurbished clutch and adjusted up as much as possible I’m barely able to select gear even without the engine running. The refurbed plate is an older type which goes in with the longer side flywheel side. As per the sticker on the refurbed plate. The sticker was put on as it had been previously put in the wrong way round and had worn down some rivets. I’m tempted to put it back in the other way round too see if that works, but thought I’d tap into the experience on here. Could the release bearing be the wrong one are there different thicknesses. refurbished clutch old type compared to the one I took out which is the other version with the circlip. Any advice appreciated Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 9 Share Posted March 9 So nothing looks like it’s been grinding against each other. Have you checked spigot bearing ? Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 The wear was to the refurbished clutch from previous fitting and was sorted on the refurb. The pilot bearing looked ok and I had no noise or issues previously other than judder pulling away when warm. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted March 9 Share Posted March 9 i assume youknow but just just in case. how are you adjusting the clutch ? hopefully not with the cable ! Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 I adjusted the pivot bolt on the box to get the lever in the right place and used all the thread on the cable. Still struggled to select a gear. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted March 9 Share Posted March 9 Is that sticker right? So the raised side of the friction plate goes against flywheel? Are you asking if this needs confirmed? Any pics of the ball adjuster on gearbox, also cable side of fork. You using the same cable? Think all release bearings are different, 1.8, 2.0e, 2.0s etc. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 That was my initial thought but that type of clutch has the raised side against the flywheel which is how I had fitted it. i took the adjuster and fork off to get the release bearing out as I wanted to see if it had any numbers or identification on it. same cable and release bearing that we’re working previously. i have now ordered a new cable and release bearing to rule them out. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted March 9 Share Posted March 9 If I remember correctly, if you put the raised side towards the flywheel (while it’s off) does it even make contact with the flywheel? I’ve tried it before (can’t remember which set up) but the raised side against the flywheel wouldn’t touch. Worth checking. Do the same with the friction plate up against the pressure plate and see which side suits it. Usually the raised bit is pressure plate side. 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted March 9 Share Posted March 9 Think clutch kits usually have all three items, but as you said you got yours lined, can't see it being the release bearing, unless a large section is missing. Any info in the Haynes manual. Quote Link to comment Share on other sites More sharing options...
rutts Posted March 9 Share Posted March 9 If its a 4 speed plate the nose is too long you need to either grind it down or change plate back. No adjustment will sort it. I know I did it. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 It’s one that was in the car when I got it. And worked with no issues I was aware of. But like I said looked like it had been installed back to front at some point and started to wear down some rivets on the clutch. so would have probably got worse over time. How can I tell if it’s the 4 speed one and how much would I need to grind off ? Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 9 Share Posted March 9 1 hour ago, Sutty2006 said: If I remember correctly, if you put the raised side towards the flywheel (while it’s off) does it even make contact with the flywheel? I’ve tried it before (can’t remember which set up) but the raised side against the flywheel wouldn’t touch. Worth checking. Do the same with the friction plate up against the pressure plate and see which side suits it. Usually the raised bit is pressure plate side. The boss would contact first, and that would cause the drag. Hence my thoughts about spigot as something us causing the input shaft still to have some drive when clutch is depressed Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 I had another look at the spigot couldn’t see anything unusual. The pressure plate will sit either way round with over a 5mm gap to flywheel bolts with long side towards flywheel. The other way round puts the rivets on the clutch and the metal that holds the springs very close together but not touching. probably ok for a few thousand miles or so until they make contact. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 9 Share Posted March 9 You put a shaft into spigot to see if it’s rotating full all the time? Also is the plate splines free and smooth on the shaft? Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 No I havn’t tested the spigot to see if it turns ok, but the plate moves freely. This is an issue without the engine running so wouldn’t have thought the bearing would make a difference, Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted March 9 Share Posted March 9 I've never seen a 6 spring 2.0 friction plate. Are you sure it's not too big for the 2.0 flywheel? Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 9 Author Share Posted March 9 Same size as the one I took off and was on the car previously and working. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 9 Share Posted March 9 41 minutes ago, Mickfrad said: No I havn’t tested the spigot to see if it turns ok, but the plate moves freely. This is an issue without the engine running so wouldn’t have thought the bearing would make a difference, Usually when selecting gear without engine running it still needs to rotate the input shaft slightly as it lights up the selector ring mate. If it’s jammed then it would be semi locking the input shaft to the flywheel /crank. You can try this if you take hand brake off and rock the car as you try to engage the gear (working backwards ) Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 10 Author Share Posted March 10 (edited) Checked spigot today turning freely. looks like it’s the wrong plate, that was put in at some time and to get it to work was put in the wrong way round. There is about 1.5-2 mm of clearance before things start touching. so I can put it back in the wrong way round and it will probably last a few years with the minimal mileage that get done. Or send the other one off for refurb, which is probably the sensible option. These are the two plates flywheel side up. And the other side No 1 shows the position of the face of the plate fully on the shaft of the refurbished plate the right way round. No 2 is the other way round and the other plate both ways round. Edited March 10 by Mickfrad 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 10 Share Posted March 10 Interesting Mick, but that overall height not really explaining what was happening. So it could be aFWD plate and the boos length has been the issue all along? Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 10 Author Share Posted March 10 Yea I’m not sure either, will just get the other one done so I can get the car back on the road. 2 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted March 12 Share Posted March 12 What is the diameter of the friction plate. I think GTE are 8.5in diameter. The left plate definitely doesn’t look quite right. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 12 Author Share Posted March 12 Definitely both the same size 8.5in. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted March 12 Share Posted March 12 as mentioned earlier i have checked all my spare discs and none are other than 4 spring type so may have been wrong originally. BUT if it worked before and has simply been relined then it should work now. yes there are a couple of different release bearing designs but they are dimiensionslly identical and interchangeable .the bearing has to fit into the release arm correctly on the flats so it locks into place but that would be obvious if not in right. even as mentioned the discs when new could even be physically fitted the wrong way round and would not rub but you are also correct in that early and laterdiscs are fitted different ways round.something to do with the offset of the central bore. so if the disc worked before and everything else is the same ( and correct) then it must be something to do withthe disc.that seems obvious but what ? final checklist spigot bearing ok and free. disc ok on splines. arm adjusted correct. release bearing located in arm correct disc not refaced too thick pressure plate correct( if replaced) same dimentions/ drive surface to mounting flange level( within range) flywheel not skimmed. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted March 12 Author Share Posted March 12 (edited) I agree it will work if I put it back in the wrong way round as it must have come out that way. The problem arises further down the line when it starts rubbing due to clearance issues. Who knows how long this could take and probably not cause me any issues but now I know and I have the correct one I may as well sort it properly. i did have the flywheel skimmed as it was a bit of a mess. But the outer edge was taken down the same amount as the inner. would be handy if I could find out what the plate was off as it’s a shame to waste it. Edited March 12 by Mickfrad Quote Link to comment Share on other sites More sharing options...
