chipsngravy Posted July 4, 2023 Share Posted July 4, 2023 Afternoon all. Last year we acquired a 2.4 CIH powered Bedford van. It's nearly ready for its mot and I'm looking for a handbook/manual with all the info about the engine. I've seen some Haynes manuals for Mantas but these were only for 1.6-2.0 so not quite sure if 2.4cih is covered. I appreciate I'm not a Manta owner but any help will be much appreciated. Thanks in advance, David Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 4, 2023 Share Posted July 4, 2023 Keep your eyes open for a frontera Haynes manual, I had to buy a frontera manual for the 2.3td engine information as they don’t put it in the 2.3td Carlton manual! 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted July 4, 2023 Share Posted July 4, 2023 Frontera or omega A believe 1 Quote Link to comment Share on other sites More sharing options...
611 Posted July 4, 2023 Share Posted July 4, 2023 Is this what you need? Bought it just for the 2.4 section for mine 🙂 1 Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 4, 2023 Author Share Posted July 4, 2023 Brilliant, thanks chaps. Just purchased Frontera manual for the whole £8. 12 minutes ago, 611 said: Is this what you need? Bought it just for the 2.4 section for mine 🙂 Does it cover fuelling at all ? 2 Quote Link to comment Share on other sites More sharing options...
611 Posted July 4, 2023 Share Posted July 4, 2023 2 hours ago, chipsngravy said: Brilliant, thanks chaps. Just purchased Frontera manual for the whole £8. Does it cover fuelling at all ? When you say fuelling? Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 4, 2023 Author Share Posted July 4, 2023 I mean fuel system, sorry. I hope to see carbs covered in there as mine is efi converted back to carb by the looks of it Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 5, 2023 Share Posted July 5, 2023 Is it definitely a 2.4? Should be cast into the left side of the block. I don’t recall a carb manifold for the 2.4 unless it’s been home brewed. Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 5, 2023 Author Share Posted July 5, 2023 Morning pal. That's what I've been told by the previous owner. It says "2.4 injection" on the valve cover but the lump is running a Weber 32/36. Does that mean all 2.4cih units were injected? Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 5, 2023 Share Posted July 5, 2023 (edited) A 2.4 has got a cilinderhead with inlet ports that are higher, so the combination of the inlet/outlet manifold of a CIH carb set would be difficult to fit. Ofcourse it is possible your 2.4 block has got a 1.9 or 2.0 head. As Sutty wrote look under the alternator, on the block must be 24 cast in. As also the engine number must show it: C24NE.... Edited July 5, 2023 by H-400 Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 5, 2023 Author Share Posted July 5, 2023 34 minutes ago, H-400 said: A 2.4 has got a cilinderhead with inlet ports that are higher, so the combination of the inlet/outlet manifold of a CIH carb set would be difficult to fit. Ofcourse it is possible your 2.4 block has got a 1.9 or 2.0 head. As Sutty wrote look under the alternator, on the block must be 24 cast in. As also the engine number must show it: C24NE.... Brilliant, thanks a lot. I'll have a proper look tonight and take some pics as well Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 5, 2023 Share Posted July 5, 2023 Pic of my 2.4: You can see the 2.4 on the engine block. It is also marked on the other side but difficult to see cause of the manifolds 2 Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 5, 2023 Author Share Posted July 5, 2023 17 minutes ago, H-400 said: Pic of my 2.4: You can see the 2.4 on the engine block. It is also marked on the other side but difficult to see cause of the manifolds Lovely, thanks for that Quote Link to comment Share on other sites More sharing options...
611 Posted July 5, 2023 Share Posted July 5, 2023 2 hours ago, chipsngravy said: Lovely, thanks for that The frontera was just injection and as Herman says they use a higher inlet manifold on the 2.4 as opposed to the 1.6,1.9,2.0. Easy to fit carbs but you need the higher inlet manifold to fit them. You can easily tell if the head is 2.4, see pic below that shows how much higher the inlets are. The other will have the inlet and exhaust at the same level. The carb side of things fueling wise etc.. will be the same as any of the other CIH, it was just the raised ports and slightly bigger valves on the 2.4 and the thermostat housing was slightly different. 1 Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 5, 2023 Author Share Posted July 5, 2023 That's very helpful, thank you. Quote Link to comment Share on other sites More sharing options...
611 Posted July 5, 2023 Share Posted July 5, 2023 2 hours ago, chipsngravy said: That's very helpful, thank you. No problem Lots more pics on here if you need more info https://www.theopelproject.com/ Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted July 5, 2023 Share Posted July 5, 2023 Yes, very easy to ID Frontera 2.4s...actually all CIHs.. Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 5, 2023 Author Share Posted July 5, 2023 I've had a look at the engine, there is a "GM" and "20" cast in on the block, so I can only assume it's a 2.0 lump with a 2.4 rocker cover on. Below is a link to a pic of the block but no idea if it's gonna work. https://www.dropbox.com/s/i9zer72xwtfwrr1/PXL_20230705_164200760.jpg?dl=0 Having problems uploading pictures on here.. I've tried a couple of websites generating urls, still can't upload anything. Bugger Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted July 5, 2023 Share Posted July 5, 2023 Photo added for you Think your right 2.0l with 2.4 cover 1 Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 5, 2023 Author Share Posted July 5, 2023 Thank you kindly. Can I just ask how you generate urls for the pictures please? There's one more I'd like to add Quote Link to comment Share on other sites More sharing options...
paulmanta Posted July 5, 2023 Share Posted July 5, 2023 Look at the engine number, it will say *24* *22* or *20* and then the number of the block if its any of the sizes 2.4, 2.2, or 2litre. 1 Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted July 5, 2023 Share Posted July 5, 2023 (edited) Being a member I just click on add files and then photo library not sure about urls. Edited July 5, 2023 by Mickfrad Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 6, 2023 Author Share Posted July 6, 2023 7 hours ago, Mickfrad said: Being a member I just click on add files and then photo library not sure about urls. Ah, that explains it. I have to upload a picture first, then provide a link to it. Thanks anyway Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 6, 2023 Share Posted July 6, 2023 1 hour ago, chipsngravy said: Ah, that explains it. I have to upload a picture first, then provide a link to it. Thanks anyway Are you using a computer or a phone? Phone is easy, it does it all for you. But it’s pretty much the same on PC. The forum brings the photo up for you and hosts it itself. 👍 Quote Link to comment Share on other sites More sharing options...
chipsngravy Posted July 6, 2023 Author Share Posted July 6, 2023 29 minutes ago, Sutty2006 said: Are you using a computer or a phone? Phone is easy, it does it all for you. But it’s pretty much the same on PC. The forum brings the photo up for you and hosts it itself. 👍 Not in my case im afraid, it doesn't give me the option to upload a file, only to provide an URL 1 Quote Link to comment Share on other sites More sharing options...
