Sutty2006 Posted May 23 Share Posted May 23 I’m slowly getting round to hunting out all the parts for my 76 B1. I’m currently struggling to work out what I need for the front seat belts. I can’t remember if these belts were already disconnected when I bought it back in 2008, but I know that the passenger one is missing. The drivers belt is present, but I’m struggling to attach it to the inner sill. I have a bolt hole, which I assumed was for bolting the rail into, but I can not hook the other end into anything. Has anyone got pictures of an EARLY B1 with this old belt setup? I’ve got two pairs of belt rails you see, and the belt that is left in place, has no metal hook/loop on the end to bolt into the sill. I found this in a box? But also have one of these bolted into the top of the passenger B pillar. if that is the part and it’s correct, I’ve no idea how I can get it into the belt loop Quote Link to comment Share on other sites More sharing options...
mantasrme Posted May 24 Share Posted May 24 Early cars didn't have the chrome rod, their seat belts looked like this. I'll have a look in my stash i have a load of seat belts i think i have some early ones 4 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 24 Author Share Posted May 24 2 hours ago, mantasrme said: Early cars didn't have the chrome rod, their seat belts looked like this. I'll have a look in my stash i have a load of seat belts i think i have some early ones That would be fantastic mate, I’ll need a pair I think as it’s been cut off, definitely never seen that bottom bracket anywhere. If you have 1x early fat buckle aswell then that’s everything I need. Quote Link to comment Share on other sites More sharing options...
Kr1s Posted May 24 Share Posted May 24 If pictures of the ones in my 1980 coupe would help, I can post them later. Cheers Chris 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted May 24 Share Posted May 24 (edited) This is the setup on my B Top looks like it’s back to front until you see it pulled across someone’s shoulder. The clever swivel bit on the end makes it sit nicely. The bottom is spring loaded to lay flat on the floor when it’s not in use. Rear seat passengers are not tripped when getting in or out of the car. Edited May 24 by Jonathan Pounsett 1 1 Quote Link to comment Share on other sites More sharing options...
Ems Posted May 24 Share Posted May 24 Never realised the B type were spring loaded. My old Cavalier Sportshatch didn't have those serrated washers and springs, leaving a trip hazard as mentioned above. Quote Link to comment Share on other sites More sharing options...
Kr1s Posted May 24 Share Posted May 24 I think this is a bit superfluous as it's the same as others have already shown, but as promised this is how mine looks... 1 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 24 Author Share Posted May 24 Thanks guys. Yeah I am missing that bottom piece. Never seen it before so I’m guessing previous owner cut it out in the 90s. Which is annoying as the rest of the belt is there! But I think I do have that serated part! Hopefully David has a set for me 👌 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 24 Share Posted May 24 you will need the complete belt with arm attached as its not removeable ( unless you cut and bend then reweld but obviously not a good idea !) also i did away with the top plastic arms and swivels as they stopped the belt retracting properly ( retract mech gets weaker with age) and doesnt affect their usage by any notable amount . Quote Link to comment Share on other sites More sharing options...
1900SR Posted May 25 Share Posted May 25 10 hours ago, Sutty2006 said: Thanks guys. Yeah I am missing that bottom piece. Never seen it before so I’m guessing previous owner cut it out in the 90s. Which is annoying as the rest of the belt is there! But I think I do have that serated part! Hopefully David has a set for me 👌 I think the belt that you have is one that is designed to go over the chrome bar, from memory the loop in the belt just slides over the bar, so it sounds like it's not the original belt for the car. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 25 Author Share Posted May 25 2 hours ago, 1900SR said: I think the belt that you have is one that is designed to go over the chrome bar, from memory the loop in the belt just slides over the bar, so it sounds like it's not the original belt for the car. This one looks different to the other later ones I have 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 25 Share Posted May 25 5 hours ago, Sutty2006 said: This one looks different to the other later ones I have Was the coupe and Hatch different too ? Quote Link to comment Share on other sites More sharing options...
Vince Posted May 25 Share Posted May 25 Might have some. I'll need to check. 1 Quote Link to comment Share on other sites More sharing options...
Vince Posted May 28 Share Posted May 28 Any use? Foc. I've got the full set. Out of a 76 Cavalier Coupe 1 Quote Link to comment Share on other sites More sharing options...
