SCP Posted January 5, 2014 Author Share Posted January 5, 2014 All the welding done it was time to clean up the underside I decided to sand blast it. I had a long break due to the poor weather in 2012 as I needed the garage door open to let out clouds of dust( lots of it). I sandblasted the underside sections at a time 4 Quote Link to comment Share on other sites More sharing options...
SCP Posted January 5, 2014 Author Share Posted January 5, 2014 (edited) Then I 2k epoxy primed it, I used this as it does not absorb moisture an the project will take me a while Edited January 6, 2014 by SCP 3 Quote Link to comment Share on other sites More sharing options...
SCP Posted January 5, 2014 Author Share Posted January 5, 2014 The next stage was seam sealing 5 Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted January 6, 2014 Share Posted January 6, 2014 Nice work Show us the blaster you used, it looks like it worked really well Quote Link to comment Share on other sites More sharing options...
andyc Posted January 6, 2014 Share Posted January 6, 2014 Nothing better than getting that primer coat and seam sealer on, makes all that metal work worth while Andy 1 Quote Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted January 6, 2014 Share Posted January 6, 2014 Well done mate. Be good to see it back on the road. Happy New Year! Quote Link to comment Share on other sites More sharing options...
SCP Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) Nice work Show us the blaster you used, it looks like it worked really well Hi Kevin work on manta is going ok but taking a bit longer than I hoped Here is the blaster I used which needed two 3HP twin piston compressors to avoid stopping too often, I would recommend one with proper dead man valve rather than mine as the glass grit eats through valve an you get sore hand I have been through a few valves still on same hand lol Edited January 6, 2014 by SCP Quote Link to comment Share on other sites More sharing options...
SCP Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) Every bit of dust an dirt was attracted to the seam sealant so I cleaned it an primed it ready for my winter break from restoration . Edited January 6, 2014 by SCP 2 Quote Link to comment Share on other sites More sharing options...
SCP Posted January 6, 2014 Author Share Posted January 6, 2014 Well done mate. Be good to see it back on the road. Happy New Year! Will be a while before its back on the road Ben I got withdrawal from Manta driving now Nothing better than getting that primer coat and seam sealer on, makes all that metal work worth while Andy Yep had enough of grinding metal an welding Quote Link to comment Share on other sites More sharing options...
SCP Posted July 14, 2014 Author Share Posted July 14, 2014 A little update of progress to my Manta I used 3m Stonegaurd where original coating was Then I epoxy primed and w/w 2k topcoat semigloss over complete underside 3 Quote Link to comment Share on other sites More sharing options...
SCP Posted July 14, 2014 Author Share Posted July 14, 2014 Then same treatment for inside of front wings cleaned off old coating sandblasted any rust epoxy primed 3m stonegaurd another epoxy coat and 2k topcoat 2 Quote Link to comment Share on other sites More sharing options...
parkysmanta Posted July 15, 2014 Share Posted July 15, 2014 Nice work, Good to see another manta owner near me in Devon. Thought I was alone haha 2 Quote Link to comment Share on other sites More sharing options...
Chappers11050 Posted July 15, 2014 Share Posted July 15, 2014 Nice work, Good to see another manta owner near me in Devon. Thought I was alone haha We used to be the South West Reps, and tried organising a few meets and events, but never really gathered much interest. James Sene in Newton Abbot took over from us, would be good to have some local meets if there's a few more mantas back on the road in Devon and South West area, maybe next summer eh Simon? 1 Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted July 16, 2014 Share Posted July 16, 2014 Nice work, Good to see another manta owner near me in Devon. Thought I was alone haha You're not alone in Devon, mine is lurking in my garage near Barnstaple waiting for me to start work on it again. 2 Quote Link to comment Share on other sites More sharing options...
SCP Posted February 22, 2015 Author Share Posted February 22, 2015 (edited) While Manta is away at bodyshop for some paint work I have cleaned up and painted rear axle/suspension and other rear under car parts, front suspension next hopefully all the parts will be ready to bolt back on when car body gets back Edited February 22, 2015 by SCP 1 Quote Link to comment Share on other sites More sharing options...
oldwheels Posted February 22, 2015 Share Posted February 22, 2015 Outstanding work keep it up 1 Quote Link to comment Share on other sites More sharing options...
RECARDO Posted February 22, 2015 Share Posted February 22, 2015 Great work on the car mate looks very neat and tidy. Quote Link to comment Share on other sites More sharing options...
seangteowens Posted March 1, 2015 Share Posted March 1, 2015 On to my sills with rust bulges now ,I cut out rusty double skin area above rear jacking points then a bit larger area to make sure all rust was gone, in between the two skins was well rotten though most of sill is in very good condition then cleaned up the surrounding area welded in a new piece to join inner part to lower middle so I dont have a double skin at the bottom as this had caused my rust problems in the sill, then painted from a new sill panel cut out the section needed adjusted it with a hammer and drilled holes ready for welding, applied weld through primer welded it on ground off high spots and primed Great job I'm at that stage now wit the swan necks what weld tro primer did u use and is it brush-on are aerosol . Quote Link to comment Share on other sites More sharing options...
robah Posted March 1, 2015 Share Posted March 1, 2015 Fantastic work there, attention to detail is out of this world. If your going to do this type of work you do it do it right. Great project thread 2 Quote Link to comment Share on other sites More sharing options...
SCP Posted April 19, 2015 Author Share Posted April 19, 2015 (edited) Now onto front suspension axle sand blast Epoxy primer then black etc should be getting back my shell from bodyshop soon then I can get this lot off the garage floor my spraying is ok for underside but have left the top to professional's Edited April 19, 2015 by SCP 6 Quote Link to comment Share on other sites More sharing options...
SCP Posted April 19, 2015 Author Share Posted April 19, 2015 Hi seangteowens sorry I missed your question I used Bilt Hamber weld through primer spray and brush on zink primer 1 Quote Link to comment Share on other sites More sharing options...
seangteowens Posted April 20, 2015 Share Posted April 20, 2015 Great thanks for getting back 2 me Quote Link to comment Share on other sites More sharing options...
SCP Posted April 27, 2015 Author Share Posted April 27, 2015 I collected my Manta from the bodyshop today its been away a while nice to have it back Now for the rebuild 4 Quote Link to comment Share on other sites More sharing options...
SCP Posted September 23, 2015 Author Share Posted September 23, 2015 A little more progress rear end underside components fitted axle , suspension, fuel an brake lines fuel tank then I thought I better do something that's not under car so fitted rear lights an bumper if you look from back it looks almost like a complete car lol Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 4 Quote Link to comment Share on other sites More sharing options...
SCP Posted September 23, 2015 Author Share Posted September 23, 2015 (edited) I spent over a day fitting back my roof lining bit of fiddle to get right, then some easier bits sunroof all windows upper dash ,speedo an wiring Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited September 23, 2015 by SCP 5 Quote Link to comment Share on other sites More sharing options...
