casper1483 Posted March 30, 2012 Author Share Posted March 30, 2012 Really easy pal, just offered the servo up with the carbs fitted making sure the bonnet would shut and with enough clearance behind the headlight panel and tacked it in place, then got a length of pipe cut to length with a nut on one end and a thread on the other for adjustment and fitted it ensuring it was all in line with the master cylinder at the same angle as it was when fitted to the bulk head, I've since blanked all the unions off and gave it some severe pressure and no problems and it's still only tacked in, Simples... Quote Link to comment Share on other sites More sharing options...
CRAZYDAVE Posted March 31, 2012 Share Posted March 31, 2012 Really easy pal, just offered the servo up with the carbs fitted making sure the bonnet would shut and with enough clearance behind the headlight panel and tacked it in place, then got a length of pipe cut to length with a nut on one end and a thread on the other for adjustment and fitted it ensuring it was all in line with the master cylinder at the same angle as it was when fitted to the bulk head, I've since blanked all the unions off and gave it some severe pressure and no problems and it's still only tacked in, Simples... Ace nicely thought out Quote Link to comment Share on other sites More sharing options...
yorkshirelad Posted March 31, 2012 Share Posted March 31, 2012 Went down to see Hovis, and it's coming along nicely. I had a word with your lass Mick and told her to leave you alone Quote Link to comment Share on other sites More sharing options...
casper1483 Posted April 4, 2012 Author Share Posted April 4, 2012 Cheers for that mate, but I'm now pleased to announce that all the welding is done, I've had a spirt and stuck at it, and to tell the truth I am 100% balled off with eating and breathing welding and grinding dust, getting burnt, kneeling on sharp of off cuts, welding flash, cut fingers, banging my head, noise from the grinder etc etc, but it's DONE !!!!!!!, body prep next, at least filler dust is a different flavour to grinding dust .......... Quote Link to comment Share on other sites More sharing options...
casper1483 Posted April 12, 2012 Author Share Posted April 12, 2012 decided to do the rear axle before the paint prep im using an axle from a 88 gte abit higher ratio im told, refirbed with new pipes, wheel cylinders and shoes, i also found this date stamp, she's a pretty early one, heres to another 37 years............... Quote Link to comment Share on other sites More sharing options...
casper1483 Posted April 19, 2012 Author Share Posted April 19, 2012 (edited) just a few more pics dont know wether to leave it as one colour or go with the black stripe, think it suits the wardance red/ orange, dust is vevery where and ive only done the roof and one rear arch.................. and heres one of my motor bike i did, just wanting a sunny day or two. Edited April 19, 2012 by casper1483 Quote Link to comment Share on other sites More sharing options...
399Road Posted April 24, 2012 Share Posted April 24, 2012 Nice brakepipes Mick, I thought you'd have gone for some of those curlywhirly ones, that take the scenic route to the wheel cylinders! I think that the Black stripe would look better if it covered the whole bonnet and the tops of the wings, scuttle and front panel. Keep up the good work and I'll see you soon Quote Link to comment Share on other sites More sharing options...
opelscott22 Posted April 24, 2012 Share Posted April 24, 2012 looking good! its always amazing how much mess sanding filler makes eh?! Quote Link to comment Share on other sites More sharing options...
StevieH Posted April 26, 2012 Share Posted April 26, 2012 cracking work mate keep it up Quote Link to comment Share on other sites More sharing options...
casper1483 Posted April 27, 2012 Author Share Posted April 27, 2012 (edited) Just thought id put up some more pics, out of the gallon of filler that I have bought, 90% is either on the floor or in my lungs, ive had a dust mast on but it still gets in, my garage is a right tip, you painters who do this all the time, you have my sympathy, unless your mad, Ive been filling and flatting for ages but its not until you put the paint on till you see all the poo par that needs sorting, for a novice though ive not done too bad, although to some it looks like alot of filler, most who have changed large chunks know you need wide areas to get the flat surface back and in places the filler is probably no thicker than a coat of paint, Going to take bonnet, boot and doors off the car to paint, Thought it was poo breathing weld fumes, filler dust comes a close second, :-/.................... Edited April 27, 2012 by casper1483 Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 7, 2012 Author Share Posted May 7, 2012 Reached a turning point in the refurb, the colour is going on,just doing the shut lines etc and under the side skirt, I bought a Rivnut gun as I want the skirts to stop on and self tappers arent up to it, the gun leaves a theaded insert so you can bolt stuff on to sheet steel, not the expensive neither, Just realised how much the paint looks like the colour of a propane cylinder, shame ive spent £44 per litre with hardener, when I could have gone to BOC cant wait to get it painted now ...................... Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 14, 2012 Author Share Posted May 14, 2012 just a few more pics, was only going to do the door shut etc but got carried away. Its very Red/Orange, lots of wet flatting and a second coat, carbon fibre wrap on bonnet and tinted windows should tone it down abit........... Quote Link to comment Share on other sites More sharing options...
stradacab Posted May 14, 2012 Share Posted May 14, 2012 Great work, really good to see. Well done! Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 15, 2012 Author Share Posted May 15, 2012 just a couple more pics, got the other side done and the engine bay primed, im at work the next couple of days so I can leave the paint to go hard so I can wet flat it ready for the next coats, Ive only used a litre plus hardener so far but plan to put another 2 litres on, should get a shine through that lot ................. Quote Link to comment Share on other sites More sharing options...
399Road Posted May 20, 2012 Share Posted May 20, 2012 That Propane cylinder orange looks really good to me Mick, Are you still planning on keeping the Vinyl roof? ...Luke. Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 21, 2012 Author Share Posted May 21, 2012 Hey up Luke, how's you, Vinyl roof has long gone, going for the carbon wrap on the bonnet, legal tint on the doors and blacked out rear quarters and rear window, that should tone it done a bit, trying to get final coats on this week then it's the rebuild, :-) Quote Link to comment Share on other sites More sharing options...
robah Posted May 22, 2012 Share Posted May 22, 2012 Saw this car in the flesh on Sunday, some great work being done on the car Great doing business with you mick, hope to see ya at Billing Rob Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 22, 2012 Author Share Posted May 22, 2012 Cheers mate, Hovis is getting its final coats of paint today / tomoz, my painter mate came round last night and ripped my prep work to bits :-/, so he's going to do some more wet flating etc today then going to paint it, I've made a spray booth in the garage, used polythene to seal roof space and walls etc, so anything that dies from the paint won't land on the roof I hope, Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 28, 2012 Author Share Posted May 28, 2012 Manta Claus came today, carbon wrap bonnet, limo back and rear quarters and legal sides, looks the dogs do dars, final coats of paint tomoz, not putting any more pics on till it's done, Does any body know in south yorks a good old school rolling road cos unless you can plug it in most aren't bothered, 1 Quote Link to comment Share on other sites More sharing options...
doveyte2800 Posted May 28, 2012 Share Posted May 28, 2012 (edited) Mick I used to use one called Torque tune at Boughton camp between ollerton and newark when we needed the TE2800 set up. He just loves playing around with carbs. regards Ian Edited May 28, 2012 by doveyte2800 Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 28, 2012 Author Share Posted May 28, 2012 Sweet, don't suppose you have any contact details, or are they on the tinter net, Quote Link to comment Share on other sites More sharing options...
robah Posted May 28, 2012 Share Posted May 28, 2012 Sweet, don't suppose you have any contact details, or are they on the tinter net, Mick a link to there wesite http://www.torquetune.co.uk/index.php?/Torquetune/home.html Let me know how you get on as I might use them on mine in the near future Rob Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 29, 2012 Author Share Posted May 29, 2012 Cheers Rob I'll contact them, the car runs but it pops and farts abit, but there's lots to do if I'm going to drive it to Billing, :-0 Mick Quote Link to comment Share on other sites More sharing options...
casper1483 Posted May 29, 2012 Author Share Posted May 29, 2012 Wasnt going to put any more pics on till Hovis was done but couldnt resist, Photo bucket is acting daft so ill try this one first if it dunt work ill try later, Yep.... that works, this is what was left of all the paint that i put on when the painter had done, hes since painted it again and is now baking for a day or two then it more wet flatting with 1500 grit ready for 3rd and final coat, hope you like, cos I think its ace............... Quote Link to comment Share on other sites More sharing options...
StevieH Posted May 30, 2012 Share Posted May 30, 2012 Oooooo very nice and shinny Quote Link to comment Share on other sites More sharing options...
