CHEAP DEHUMIDIFIER FOR YOUR MANTA
Just got these for mine,i use these in addition to a quite expensive breathable covers as I don,t have a garage,and the onset of winter etc etc....
An absolute must for your manta,even if you have a garage.You can get them from supermarkets for a pound a go aswell.
You will be amazed at how much water they trap :thumbup
http://www.ebay.co.uk/itm/181855534081?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Edited by evo3000
I use the cheap disposable ones and they work well. There's always a couple in the car when its parked on the drive.
Man they can absorb a load of water from the air in a manta, help a lot in winter as its less likely you find ice on the inside of the window with these in.
from 2 of the reusable ones 250 ml of water collected in about a month and my car has been covered up outside. Whatever type you use it takes a while till they start working so its best to rotate two by refilling or replacing at different times
tbh  gary I was not aware of those refillable ones,but the disposable ones work well and there so cheap,and will last a good few months easy.
Will last the winter out anyway,once the crystals turn to gel they are pretty much done,but I keep an eye on the amount of water there collecting aswell.:thumbup
I have x5 in mine but will use the other 5 like gary  says to rotate or change.
Edited by evo3000
If you buy cat litter (silica based only) and fill up an old sock with it (preferably not w4nked in!) tie the end up and leave it under the car seat, it'll soak up all the moisture too. You can refill the cat litter of course, but the sock may get a bit soggy when the old stuff is 'full'.
