Irmscher Man Posted July 11, 2018 Share Posted July 11, 2018 We had a place years ago where all the useful GM part numbers were saved so I thought we would resurrect this. If you have any part Numbers to add, please post them up and I will edit them down into a single list - to keep it easy to browse. ===================================================================================================== ENGINE & GEARBOX Getrag Transmission Oil - SAE 75W / 85W - Part No 93165290 CIH Oil Filter (1.9 / 2.0 / 2.4) - 93156958 CIH Sump Gasket kit - 08983127 CIH Rocker Cover Gasket - 90002406 1.8 Cam Cover Gasket - 90354545 ===================================================================================================== CHASSIS Opel Manta B Upper Ball Joint - 90093763 ===================================================================================================== Link to comment Share on other sites More sharing options...
Danny D114BCW Posted July 11, 2018 Share Posted July 11, 2018 Great idea, can we move this to the Parts Locator members area though? 1 Link to comment Share on other sites More sharing options...
berni Posted July 11, 2018 Share Posted July 11, 2018 Or you can use.www. Ecat24 gives you the same part numbers as vauxhall catalogue. Berni "Parts advisor vauxhall" 1 Link to comment Share on other sites More sharing options...
Mickfrad Posted July 11, 2018 Share Posted July 11, 2018 Just had a look on ecat24 unfortunately no Manta’s listed http://ecat24.com/opel/catalog/models/1/ Link to comment Share on other sites More sharing options...
Atlantean Posted July 11, 2018 Share Posted July 11, 2018 3 hours ago, Irmscher Man said: ENGINE & GEARBOX Getrag Transmission Oil - SAE 75W / 85W - Part No 93165290 Is that a GL4 or a GL5 oil? Link to comment Share on other sites More sharing options...
cam.in.head Posted July 11, 2018 Share Posted July 11, 2018 I have various bosch part. Numbers for the engine and injection system but not the actual gm numbers if its any help Link to comment Share on other sites More sharing options...
Mike. Posted July 11, 2018 Share Posted July 11, 2018 2.0E CIH Exhaust manifold to downpipe gasket, Part number GM 1#90299361 2.0E CIH Bosch fuel pressure regulator/diaphragm damper, Part numbers GM 90019987 Bosch 0280161006 Link to comment Share on other sites More sharing options...
Chris M Posted July 18, 2018 Share Posted July 18, 2018 Distributor cap. 2.0 GTE 1235522196 Fuel Pump Relay. 2.0 E 90158189 / 90158443 / 90214673 Fuel Filter. 2.0 E 25164435 Brake drum. 230mm diameter suitable for GTE. 90135264 Fan Belt. 2.0 Engine. 90016655 Oil Filter. 2.0 CIH. 93156299 Ignition module. 90008144 Link to comment Share on other sites More sharing options...
spiney_norman Posted July 18, 2018 Share Posted July 18, 2018 Door hinge pins - 11063012 Link to comment Share on other sites More sharing options...
garymanc Posted July 18, 2018 Share Posted July 18, 2018 Link to comment Share on other sites More sharing options...
Irmscher Man Posted July 19, 2018 Author Share Posted July 19, 2018 I knew I had seen this before. Great find from 10 years ago! I’ll do some editing when I’m at my desktop and join this info up. Cheers Gary. I will also move it into the right section now it has got going. 1 Link to comment Share on other sites More sharing options...
Irmscher Man Posted July 25, 2018 Author Share Posted July 25, 2018 On 7/11/2018 at 18:09, Atlantean said: Is that a GL4 or a GL5 oil? I believe that it is a GL4 spec oil. I have some 1 Litre bottles available at the moment priced £14. I have tidied the contents of this thread up and moved it into the Members Only area, under Parts and Suppliers. I have locked this thread for commenting and will delete in a while. New Thread is here (for members only) - 1 Link to comment Share on other sites More sharing options...
