Fitting clips
Mickfrad
1 hour ago, Mickfrad said:
There is definitely no thread on them. Luckily all are still in place so star locks will work. They had already been taken off my car when i got it. So wasn’t sure.
thx
Mine was definitely threaded with 10mm flanged nut on the exclusive
Edited by Jessopia74
It doesn't look like a metric bolt thread, it looks coarse almost like a screw thread. The original nuts almost looks to be pressed from a flat sheet of steel and don't have threads inside all the way down.
From memory they are the same as the nuts holding the heat shield to the floor under a gte
I did think about that Ian but they are quite thin and didn’t want to make them thinner or risk breaking them. I’m thinking maybe some plastic wingnuts may grip enough to any thread they have.
3 hours ago, IanMc said:
I guess you could always run a die down them to create a thread though. That might make for a slightly better fixing long term.
Just a thought.
The reason they aren't threaded properly is when you tighten the pressed nut down it doesn't distort the rear quarter. The pressed nut orientates itself to the rear quarter. A proper threaded nut wouldn't.
