Irish blue
1200bandit
New spray gun arrived today give to inner wing some paint also flatten the rear bumper
Made a complete mass of the inner wing and rear bumper  (not going to post photos it’s that bad)
A completely different gun that l used in the past the old gun was a cheep one as well as the new one
Got to wait for a few days let the paint get hard then do it again
I think l got it working ok now ( hopefully)
Yes very different did get it in the end but to late,but a rub down and all will be fine
Got the washers today (cheers Andy 611) so fitted the front arms,road spring, and hub
Is looking well compared with what l started with
The first photo is of the o/s
  • Like 5
Today carried out repair to the inner wing rub it down and repaint it
The fist photo is the clock up on the fist try
Turned out okay, will be able to refit the shocker new brake pipe,battery ect
Also clean and painted the front wing ( on the inside)
Will underseal then paint the inside of the wing
  • Like 5
The manta is back on 4 wheels,started up fist turn of the key
Under sealed the n/s floor which is solid.the is a little box with 5 wires going to it ,starts up without it plug in ,what is it
Got to do a lot of work on the house.so will only doing bits until the decking is replaced
  • 4 weeks later...
So waiting for the decking boards to arrive (60 boards 4.8 m long)
Removed the N/S front seat checked the condition of the floor
Removed the carpet and found the the floor in excellent condition
Only light rust ,quick rub down and paint on the floor
Has anyone got some floor bungs ( the holes by the rear)
Do l under seal the floor or not
  • Like 4
Is it above kick panel,  passanger side.  Think the wee box is a n energy saver for quad lights. When the car is parked with lights on, car stopped,  it cuts voltage.... Apparently?
Car is looking good, getting round it rightly.
Edited by ®evo03
  • Thanks 1
1 hour ago, 1200bandit said:
Trying to do it right and photos to document was done,but it going slow as life is getting in the way
But l will get there in the end
Better to take your time then rush it mate. Give you time to contemplate 😁
  • Haha 1
  • 4 weeks later...
Had the afternoon off ( as on the road to Cardiff at 5 o,clock)
Painted the inner wing,the inside of the N/S wing , rear bumper,
The finish is not to bad, got to get some gloss lacquer to get shiny
Lucky you! Bet it dried fast today 😎
  • Haha 1
Got some lacquer done the inner wing turn out spot on
The floors are in excellent condition as the the floor bungs where missing
So thinking that any water that leak in drain straight out again
Put a drain on the new bungs l got if water gets in it drained out
  • Like 6
Had some time tonight
Refitted the front wing ( sealed all the joints on the inner wing,B pillar)
Clean, paint the lower chassis,looking good
under seal the floor refit the sound deadening.got to let dry the fit some heat,sound deadening
Then start all over again on the O/S
Edited by 1200bandit
  • Like 5
The stuff l got is a little to thick as it was a bit of a bugger to refit the carpet as it made the carpet to high,but it does feel a lot better under foot
I have a lot of 3 mm thick stuff so will be using that on the O/ S floor
Got to paint the frames on the seat and the N/S front,central floor is done
9 minutes ago, ®evo03 said:
Was thinking about yoga mats or exercise mats,  as dynamat is bloody expensive.  Hopefully leave it a bit quieter.
They may to thick so the carpet will not fit the stuff l used is 8 mm thick and a bit of a #### to fit
14 hours ago, 1200bandit said:
Stupid question time
How remove the gear-lever knob
The wing indicator, where do the wiring go to get it working,as l found the wiring cut and going nowhere, How did pass a MOT
The shaft splits with a clip compressed against a rubber sleeve. It’s done from below and is a pain.  Excuse very crude drawing, currently travelling and best I could do .
good written explanation from Brown here (but no pics, so I made you the diagram lol)
16 hours ago, H-400 said:
Thanks for the info, thought they were glued on the gearstick. The wiring is hidden behind the kickpanels, rather high.You'll find a grommet to the outside.
Thanks Herman
l was looking for where the wiring connect to in the wiring loom
