robah Posted December 19, 2021 Share Posted December 19, 2021 T5 LED Dashboard Light Xenon White 286 Car Bulbs COB 74 73 2721 Wedge Bulb 10pcs Quote Link to comment Share on other sites More sharing options...
®evo03 Posted December 19, 2021 Share Posted December 19, 2021 Three wires, Brown is earth is the switch marked - and + ? Two wires for the spades on switch, other is for light for switch, which you have missing! Think the light wire will be grey. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 3 Author Share Posted January 3 Thanks for In information eveo A new year a new approach to the manta 1 hour after work ( hopefully) Going out today so ask the bride how long to get ready about 2 hours So done a dit to the manta Was feeling a bit worried about removing the bumper as the rear 1/4 panels not in the best condition, so remove the bumper, the the 1/4 on o/s n./ s in excellent condition ( result ) when l removed the bumper found the spacers on the rear 1/4s Now have a spare one . Have fitted the bumper l got Going back to original look sort off. The bumper needs a repaint Hopefully tomorrow night will fit the rear fog lights, will post photos of the fog lights tomorrow Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 7 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 5 Author Share Posted January 5 So started doing a about 1 hour a night Carried out wiring repair to the rear heated screen switch Found the cover for the steering column required attention, repair the cover. The headlights are doing me head in can’t get the adjustment right 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 5 Share Posted January 5 21 minutes ago, 1200bandit said: So started doing a about 1 hour a night Carried out wiring repair to the rear heated screen switch Found the cover for the steering column required attention, repair the cover. The headlights are doing me head in can’t get the adjustment right That's the advantage of at least having at home mate, keep chipping away it will come. I deffinitely would like one of mine in my garage at home at some point in the future for that reason as having to drive across the town to mine is restrictive . Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 5 Author Share Posted January 5 It’s a bit snug in the garage can’t open the door a lot ,so when doing the work in the inside the car getting in and out of the manta can be a bit of a tight. Will do a bit more tomorrow night Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 7 Author Share Posted January 7 Only done about 1/2 tonight. Got the clock,cigarette lighter wire up and working, Got to run the wiring correctly Time for whiskey Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 8 Author Share Posted January 8 Got a bit more done today Wiring for the radio,clock cig lighter done properly Got to get some speaker wiring , To do that will remove the seats,carpet so l can run the wiring proper. The rest of the dashboard back in The tab on the heated rear screen has sapped of and gone missing , So l think this my work. Got no feed to the rear screen. Will check that out later Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 8 Share Posted January 8 Good fix, should work, if you find the tab, make one, or beg,, borrow steal one, think it can be soldered back on, hard to do upsidedown, glass in place. Is ur clock working, never had success with these. Going great guns, getting the wee issues sorted, keep er lit. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 10 Author Share Posted January 10 Yes the clock is working, wiring the clock up to a battery to check for a couple of days. Full of cold so playing in the garage Quote Link to comment Share on other sites More sharing options...
hoobby Posted January 10 Share Posted January 10 On 08/01/2022 at 21:51, ®evo03 said: think it can be soldered back on Be very careful if you choose to do it this way get some heat on the glass (heater fan) before soldering as you could you can shatter the glass (thermal shock) done a tab fix on the cougar used a special tab adhesive from the states. 3 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 10 Share Posted January 10 (edited) 1 hour ago, hoobby said: Be very careful if you choose to do it this way get some heat on the glass (heater fan) before soldering as you could you can shatter the glass (thermal shock) done a tab fix on the cougar used a special tab adhesive from the states. Silver Epoxy, not cheap got mine from Farnells http://uk.farnell.com/jsp/search/productdetail.jsp?CMP=i-ddd7-00001003&sku=2917615 I also bought these to use with the epoxy, might help. They are pretty strong https://www.ebay.co.uk/itm/223527499727 Edited January 10 by Jessopia74 Add tabs 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 10 Author Share Posted January 10 I think that if l glue it on the screen will have to be removed, unless l can figure a way that the connector will not get glued to the screen seal. Maybe put a piece of thin plastic between the connector and the seal. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 10 Author Share Posted January 10 2 hours ago, hoobby said: Be very careful if you choose to do it this way get some heat on the glass (heater fan) before soldering as you could you can shatter the glass (thermal shock) done a tab fix on the cougar used a special tab adhesive from the states. Never used super glue on the screen as it crack,shatter the screen so l am told Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 10 Share Posted January 10 1 hour ago, 1200bandit said: I think that if l glue it on the screen will have to be removed, unless l can figure a way that the connector will not get glued to the screen seal. Maybe put a piece of thin plastic between the connector and the seal. Epoxy will not bond to the seal very well anyway, but if you can carefully wedge the rubber away and smear on some Vaseline it definitely can't Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted January 11 Share Posted January 11 never had any sucess in the past with any of the conductive glues or epoxys. only thing that seemed to work well ( for me anyway !) was self adhesive copper sheet ( must be the type with conductive adhesive) found it on ebay from a music shop .used for guitar screening ! you can then solder to this no problem.but be carefull. localised heat on glass is always a worry. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 18 Author Share Posted January 18 This may be of interest to someone Nissan wipes fit the manta Plastic wipers fit very well Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 18 Share Posted January 18 Ah cool, nice find, what model, something different! The original style of wiper is very dated. We need to make up a thread, Other parts that FITS a manta. A peugeot 405 boot seal, fits, a wee trim, an inch too long. Mk2 golf sunroof seal, Nova brake pads! Mk3 fiesta roof skin to hatch! Supposedly! Only tried and test the seals. 3 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 18 Share Posted January 18 Was it just the blades or the arms too Ian ? Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 18 Author Share Posted January 18 (edited) The wipes are from a Nissan Juke ( l think can check in the next few days) The wiper arms are original just open the the end a tiny bit The qashqai x trail will fit but it’s not as long Is the n/ s wipe that’s fits All so the rear seat release lever on a hatch a Nissan Juke fits well .you can’t tell is of a juke I have also replaced the boot seal but can’t remember what what Renault it was from 25 minutes ago, Jessopia74 said: Was it just the blades or the arms too Ian ? 28 minutes ago, ®evo03 said: Ah cool, nice find, what model, something different! The original style of wiper is very dated. We need to make up a thread, Other parts that FITS a manta. A peugeot 405 boot seal, fits, a wee trim, an inch too long. Mk2 golf sunroof seal, Nova brake pads! Mk3 fiesta roof skin to hatch! Supposedly! Only tried and test the seals. Fog lights from a Ford XR 2 will fit ,l have got 2 to fit Edited January 18 by 1200bandit 3 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted January 22 Author Share Posted January 22 Used all the paint today ( on the front room wall ) So did a few hours on the manta. Wired in the engine cut out , works very well The wiring on the front side lights is 18 inches to long,poor condition on the wiring The wiring now all sorted, all 4 side lights working 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted February 6 Author Share Posted February 6 Had to wait for some plaster to dry so had a hour or so ,had so time on the manta doing the headlight wiring Refited o/ s headlight all working fine,just got to figure out how to put the headlights back together so they adjust correctly Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted February 10 Author Share Posted February 10 (edited) When got this manta the headlights where bounded to the headlight body bit Have cut out the headlights from one side.but can not figure out how the headlight is set up using springs:/ adjustment set up Has anyone got photos information how is set up or where can l get a adjustment kit from Dont know if the headlights are correct They are starting to do my head in Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited February 10 by 1200bandit Quote Link to comment Share on other sites More sharing options...
H-400 Posted February 11 Share Posted February 11 Looks like someone cutted in the plastic to fit those headlights. I'v got in both my Manta's those double but I'v got H1 halogen bulps in all, so the inside two are high beams and the outside two the normal ones and parklights. A link to a webshop that sells them but with a lot of pictures as info: https://opel-shop.com/produkt/neu-orig-irmscher-opel-manta-b-scheinwerfer-rahmen-satz-inkl-doppelscheinwerfer/ Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted February 11 Share Posted February 11 On 06/02/2022 at 18:45, 1200bandit said: Had to wait for some plaster to dry so had a hour or so ,had so time on the manta doing the headlight wiring Refited o/ s headlight all working fine,just got to figure out how to put the headlights back together so they adjust correctly Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. I have heard that this headlight setup is illegal and you may fail the MOT with the side lights illuminating like that. Quote Link to comment Share on other sites More sharing options...
