Broadspeed rep
MantaMad
  • Replies 354
  • Created
  • Last Reply
Top Posters In This Topic
UPK your quite right, could pop in an 1800 dissy at the front but I don't think it will look right.
The coil pack is the other option, sent of an email yesterday to give them the engine spec and get a price on the unit.
Has anyone fitted one of these before, the engine is well tuned and I,m not sure if this is installed wether or not the engine will need tuned again.
If it turned out to be to much hassle I could always do the same as is in my V8 and use an oil cooler and 2 6" kenowles fans for a heater
trumpets on the 40,s would be another is but irt looks like I,m going to mount 2 remote servos in the boot and just fit a master cyliner in the engine bay.
The oil cooler will prob be installed in the front grill in front of the rad.
Engine mounts of the A should do the job but may need modified will have to check this one out later.
Bling hopefully Clive can sort out some parts that I will want to pop in, will know better what we can or cant do when I get a reply [:)]
http://www.mantamagic.com
OMOC N,Ireland Rep
id="blue">
OMOC 5706
No problems with a remote servo that way Pete, once the brakes are blead, the pedal still drives a master cylinder in the normal fashion, that inturn just drives the fluid to the servo, there is no real compression in the fluid, to give a soft pedal or loads of travel the fluid would need to compress.
The brakes on my V8 are nearly to sharp, but at least she stops lol.
OMOC N,Ireland Rep
id="blue">
OMOC 5706
robbie, A type mounts not your best choice, you need the 1800 manta alloy mounts(pair posted on ebay today), will do the job perfectly when used with ford rs2000 engine mount rubbers and some additional spacers. Manta rubbers are two soft.
i also have info somewhere how to use ford fiesta/escort ignition pack and remote coilpack (20-30 quid from scrappy). i,ll see if i can find it as it will work no hassle with the twin carbs. ( the guy who showed me used it on an XE with R1 bodies in a capri).
Cheers that info will be great on the ignition pack, would it need remapped ?, I have 1800 mounts with the engine so if they suit better I can use them instead. Can have a hunt for the rs engine mount rubbers. I take it the spacers go between the rubber and the mount, or from the rubber to the xmember ?.
OMOC N,Ireland Rep
id="blue">
OMOC 5706
I used 3ltr Capri engine mounts when I fitted my XE - I ran standard injection and these gave me enough clearance for the SFI airbox without it fouling the bonnet.
Needed 2 thin shims between the alloy engine mounts (1800 ones) and the top of the rubbers to stop it fouling the crossmember when the car was being driven hard.
I'd love the info about using the Ford ignition too, I'm reshelling the car now and I'd like to avoid hacking the heater box up again!
Carl[:D]
1984 GTE Coupe Red Top 16v - B623RWW
1988 GTE Exclusive Coupe - E862BAO
1981 Cavalier 1.6 GL Sportshatch - RJU 943W
OMOC Member#5937
B623RWW%20Front%20sig.jpgB623RWW%20Rear%20sig.jpgE862BAO%20Front%20sig.JPGE862BAO%20Rearsig.JPGRJU943W%20Front%20Billing%20sig.JPGRJU943W%20rear%20sig.JPG
"Bling hopefully Clive can sort out some parts that I will want to pop in, will know better what we can or cant do when I get a reply"
Yes mate, got your email dated the 4th and replied on 5th. [8D]
Nice to see this old shed shaping up a bit eh Robbie[:)][8D]
Always nice to see the first coats going on as it means most of the work is done, and the car starts taking real shape.
East Midlands area Rep. email opel2000@ntlworld.com
Shiny bits http://www.customsolutions.me.uk
i found it so i hope this helps
1. a crank pulley from a 1.8 sierra lx the one with the 1.8 cvh engine
2. a alloy crank pulley from sbd http://www.sbdev.co.uk/
3.crank sensor off 1.8 sierra or flywheel sensor off escort and fiesta
4. a coil pak off an escort fiesta or mondeo
5.the esc unit(fitted on inner wing on escort or rear bulkhead on fiesta) and wiring off a escort mk4 1.3 or fiesta 1.1 this has a red insert and a vac pipe some fords have a edis 4 unit looks the same as the esc but no red insert and vac pipe has a sticker with edis4 on the plug part
6. a blanking plate for the dizzy hole in the back of the cylinder head
about £12 for qed http://www.qednet.demon.co.uk/
i would say the cost would be pulley £50 blanking plate £12 and scrap yard parts £20
if you want to build a mappable ignition then get the edis 4 and the wiring as it is slightly different
then you also need a megajolt this is the mappable unit to use with the edis 4 heres a link http://www.picasso.org/mjlj/
if you dont want to go down the scapyard route you can buy a mappable ignition system called mbe from sdb for about £450 this plugs on to the xe crank sensor
if your going for throttle bodies then you will need the more epensive mbe the does fueling as well as ignition
here are some pics of my sdb pulley with the sierra trigger wheel fitted
and the sensor bracket
http://img.photobucket.com/albums/v233/ ... 685ebd.jpg
http://img.photobucket.com/albums/v233/ ... f63dbe.jpg
http://img.photobucket.com/albums/v233/ ... a79f08.jpg
Cheers for the info guys will have to get alook into that, still awaiting a price on the dedicated coil pack and control bet it won't be as cheap as the scapies [:(]
Thanks for the reply Clive on the bling will have to add a few of your bits car would not be the same without it [:)] just need to sort whats within the budget.
I can see the shed coming along, once the shell is sprayed it will look a lot better, but us DIY guys can't stop theat damm dust and it takes many many nights to get the car cut down to get a reasonable finish [:)]
lol think I,m beginning to dream project car, it must it must it must be sprayed for the weekend [:D]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Blooming eeeeeeeeeeeeeeekkkkkkkkkkkkkkkkkkk cough splutter, I just got the estimate from SBD motor sport for the dissyless ignition kit, price was for the bare kit and no sensors £637.04id="red">id="size5">.
Somthing makes me thing the scrappie diy job is a lot more appealing [:D]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Heck![:0] that's a stupid price if ever I saw one.
TBH though Robbie I have noticed some absolutely stupid prices for Vauxhall stuff.
For example Courtneys prices for upgrading the LET turbo and the turbo fitted to the VXR's is about double what the Nissan boys are paying for the same bloody turbo.
Also Robbie. For the price of £600 I would be looking at altering the heater box if I were you.
Not the easiest of areas to tackle, but I could possibly make a full modified to clear dizzy stainless steel version for less than £600.
this is the top part I recently done for a customer
lol Mark that would be Clive.
On another shiny note the shell is now sprayed [:D]
Need to get the bonnet, boot etc sorted now, and the car has to be sanded and buffed which takes agesssssssssssssssssss, At this rate of going I,m going to have no fingerprints left, days of water and sandpaper don't go well together .
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Cheers [:)] hopefully the paint work will look better when i get it sanded down and buffed, this part of the restoration does my head in. I'm not the most patient bloke in the world.
Trying at the moment to source all the bits and bobs I need to get the 16V engine in. Picked up a couple of remote servos today so thats another bit of the list. [:)]
Hoping to have another manifold in a week or so, was thinking about getting it ceramic coated and it would be a finished job then. Got a few other parts thanks to Del last night,
Next on the shopping basket is a spal fan for the rad, and some 16V calipers.
OMOC N,Ireland Rep
id="blue">
OMOC 5706
