Manta A Series V8 Supercharged
Paul Barrett
some piccies
other sill now one
DSCF1010.jpg?t=1267296605
had to make new repair panle here too, wasnt happy with what was there
DSCF1011.jpg?t=1267296843
stripped out underseal from arch cut out more rot ready new steel,
DSCF1012.jpg?t=1267296893
new panle about to be welded in
DSCF1013.jpg?t=1267296945
inner repairs done, arch cut out ready for new reapir panel
DSCF1014.jpg?t=1267296983
repair panel prepped and riveted in place ready for welding
DSCF1018.jpg?t=1267297053
got distracted with seam seeling up other joint and then one of the chassis rails
DSCF1019.jpg?t=1267297103
cheers guys, good comments mean a lot.
me and ollie went to VBOA autojumble today, picked up a few bargains,
another indicator in perfect condition £4! i ahve 2 now so sorted, paid like 20 quid for the other which isnt as good
DSCF1022.jpg?t=1267367615
this lot for a fiver! all racetech gauges with a mini loom no sensors but hey at this price, even a real carbon faceplate lol
DSCF1021.jpg?t=1267367700
load of alloy bends etc 2" and 3" measly toatl of £6!
DSCF1020.jpg?t=1267367809
also picked up an airfile, just really to get in the corners of my door shuts where i need to grind down weld where i put in the sills, and some wire wheels for the grinder as getting through them quite fgast with all the rust to clean up!
Braw bargains biggrin.gif I've nah idea wot yur day'ing with the beemer bits blink.giflaugh.gif def interesting thumbsup.gif
basically a way of coverting the manta to an indpendan trear suspension rather than traditional live axle, much easier than trying to find a suitable live axle to take the power of the engine im installing
  • 4 weeks later...
few pics,
got a lot done today, weld weld weld! done a whole chassi leg and the floor pan on the drivers side, really pleased, even with visitors stopping by,
DSCF1042.jpg?t=1269719068
toss welds on this diff hanger member, got new gas now argonshield light i prefer this was with the ****e free pub bottles i picked up
DSCF1041.jpg?t=1269719190
cut shop rebuild
DSCF1043.jpg?t=1269719231
new rail, jacking point, and floor
anyhow, have finished both chassis rails and jacking points now, the car is off the rollover spit for work on the front end and then the rear trailing arms and then the engine mounting etc, then back ont he spit for final weld up and seal for painting etc,
update time, been working of fabricating the front valance, tried to patch it up but wasnt happy, so the sheel is now off the spit to allow me to properly work on it...
DSCF1044.jpg?t=1270923000
one side cut out
DSCF1045.jpg?t=1270923159
difficult angles to reproduce with basic tools, but time and patience, this had lots more work to get the ripples smoothed out
DSCF1048.jpg?t=1270923317
other panel in tis early stages
DSCF1049.jpg?t=1270923364
bit of CArD design for cutting up the new panles to shape
DSCF1050.jpg?t=1270923420
old mank all cut out for the new stuff
DSCF1051.jpg?t=1270923463
new in ready for welding, the ends need fettling to blend in with wings and lower valnce which i have a brand new one
DSCF1052.jpg?t=1270923531
placed IC back in to make sure all is straight and will fit
DSCF1047.jpg?t=1270923590
im hungry!
DSCF1046.jpg?t=1270923231
shot of the inside as it stands, few more patches to weld in the seal
Edited by novashed
finished the fron valance today, tacked up then fully tacked by welding in one spot then another to distribute the heat to prevent it warping too badly out of shape, gave it a good linish with a sanding pad on the grinder and then a skim of filler, also started mocking up the front airdam/splitter, trying something new with muscle car influence.
DSCF1057.jpg?t=1271009255
right side has been ground down flat here
DSCF1058.jpg?t=1271009308
additional plate to hold up the lower valance
DSCF1059.jpg?t=1271009364
not a very clear pic, but plcaed the front bumper back on, and half the new splitter, which may work or it wont, will try my best
well monumental day today, engine in ready for moutns to be made etc!!!!! only spent 4 hours on her as had to screed a floor this morning, but any progress is good, so more chopping ...........
DSCF1074.jpg?t=1271522432
subframe slung back on, block hangin ready
DSCF1075.jpg?t=1271522531
block in, so decided to lop out more metal lol, i knew the trans tunnel would never be big enough so marked up where i wanted to cut and let the sparks fly!
DSCF1076.jpg?t=1271522608
more scrap!
DSCF1077.jpg?t=1271522643
plate for nearside engine mount, nice thick plate steel
DSCF1078.jpg?t=1271522703
omega box in, where ive cut the tunnel out has suited me fine first time, im allowing a little more room for when i eventually build the bellhousing to suite a bmw box in the future
DSCF1079.jpg?t=1271522793
as can be seen im going to have to make up some lowering blocks for the ARB as it fouls the box considerably, handy it being there for now to hold the box up!
DSCF1080.jpg?t=1271522860
fitted first time, made bolt holes slightly larger but more luck than anything
DSCF1081.jpg?t=1271522917
placed the top half of the engine on to check measuremtns for bonnet clearance, its going to be tight, may have to bulge the bonnet or notch out the subfame a touch, as space is tight escpecially for the sump, which is more important than asthetics so if it is easier to just fabricate a bulge in the bonnet then so be it.
DSCF1082-1.jpg?t=1271523059
plenty of room either side, more than i had bargained for hence the tight ramshorn turbo manifold
This build is coming along quickly, good work! And the saab engine is certainly interesting, the swedes manage to get pretty big reliable horsepower out of them motors :thumbup
Whats the torque rating of the omega box? Is it a hydraulic clutch job? most bmw boxes will be hydraulic. maybe a strengthened type 9 and off the shelf bell housing adapter would be an option? it mat surprise you what it can handle, could just be a question of how long it will take it for depending how it gets driven! :D
Great! I love plug and play gearboxes :lol: this saab engine swap is starting to sound interesting, and they must be cheaper than an LET :blink:
A few guys on Migweb are doing/done turbo conversions using the Saab Turbo motor. I've seen prices as low as £350 for a Saab turbo engine. :o
A few guys on Migweb are doing/done turbo conversions using the Saab Turbo motor. I've seen prices as low as £350 for a Saab turbo engine. ohmy.gif
yeah still abundant, well 2ltr ones are finding a 2.3 is a bit harder but price wise compared to LETs and tuning them, no brainer
Are the internals of the Saab engines as good as everyone says (i.e. decent crank, rods, pistons, etc, etc) ?
to update, have positioned the engine now where i want it, or should i say where it will fit. a lot further back than i had anticipated, but this is good for weight distribution, but some serious thoguht and work will need to go into the sump design, as i dont wish to go down the dry sump route for expense sake.
no pics im afraid, butt he mounty are welded up and in primer
