Supercharged Ascona 400R
Retro Power
Well this project has been a little while in the making.
When we built Curt's White Ascona 400 replica we were introduced to his mate Jason who he had known for many years, and who also had a rhd 2 door ascona tucked away in cumbria. Jason asked whether we could do a similar build but with more of a track focus and more power.......of course we said yes!!
Here's what Jason dropped off with us:
Rust in all the usual places:
994356_207386722764608_1403757222_n.jpg?
1374318_207386682764612_279390369_n.jpg?
545919_207386646097949_1713004349_n.jpg?
Oh no, the usual roof butchery!!
So time to get started, strip it all down, wheel it into the blasting room and show it the blaster!
Not much of the front end was any good, so that was completely removed and replaced:
149097_207388019431145_1442426280_n.jpg?
You'll have to pardon the quality of some of the pictures, we've upgraded cameras a few times since these were taken. We now all have our own cameras in the workshop, which are all drop and waterproof and upload wirelessly so we have live updates on work!
1236293_207387932764487_337380213_n.jpg?
1238305_207387859431161_35721199_n.jpg?o
526913_207387829431164_1730668879_n.jpg?
545244_207387536097860_1176606173_n.jpg?
534048_207387469431200_1825946713_n.jpg?
1239447_207389136097700_105993248_n.jpg?
Enough to give a flavour of the work involved. Obviously there were a huge number of small bits that needed attention, but pictures of small repairs get a bit boring!!
Anyway, time to re-blast all the new metalwork to key it up and start the body prep and kit fitting!
960127_236561033180510_1009838421_n.jpg?
1545077_236561003180513_969795718_n.jpg?
1499648_236561316513815_81280033_n.jpg?o
On with the Raptor underneath:
Primer:
1544992_236560886513858_612034671_n.jpg?
1546064_236560946513852_144912445_n.jpg?
And painted! We have a bit of a lack of photos at the painted stage but before assembly!
Then onto the massive job of building the car. There are so many tasks and so many pictures that its hard to know where to start!
The entire engine installation is effectively a prototype as I don't know of anybody else that has done this with an M90 supercharger and proper chargecooler (which is essential for the setup to make decent power)
There are very few Opel parts in the build, and even fewer that are not modified in some way or other.
Lets start with the wiring loom, you'll have to bear with me in terms of other things in the pictures, as these are not in the order that work was actually completed!
The opel loom was raided for a few plugs such as those on the rear lights etc and then thrown where it belongs - in the bin!
After listing up what wiring is needed, for what assembly and in what location, the basic loom is created ready to be clad in flexible waterproof heatshrink with waterproof sealer at all junctions:
10469752_324653361037943_668179147970013
Every wire is labelled at both ends and clear heat shrunk over the labels
15677_324653371037942_607717348390183970
Routing within the car then commences:
10441961_339522859550993_289313712970300
10441029_339526362883976_526888911929114
10670105_339530529550226_588858966213567
10401985_346161132220499_990646507142672
Then onto controls: here are a few examples of the pedal and steering setup:
10612752_324655021037777_528093585070106
10478933_324656977704248_601960943860360
10421609_339530072883605_125749632386561
10514707_339535919549687_240108321604475
10646985_339538836216062_145010387173920
1962707_346158832220729_4116532932550268
Looking at the dash in the pic above seems like a decent place to show a few of making that up!
1601366_346154055554540_3728461966817011
10690236_346154218887857_430768300529724
1910484_346154138887865_5940928549600812
1966771_346154415554504_4781374543627267
Time to flock it - handy having our own setup!
10698428_346154468887832_413496036823045
1422411_346154495554496_5212838310555162
and a panel for the clock console:
10527273_346154535554492_145690198652864
1903999_346157382220874_4575470765569602
7091_346157485554197_8314791540296658063
10733974_346157572220855_682106893251527
10501959_346157598887519_871426802853581
I suppose some pictures of the engine and gearbox won't go amiss!
The gearbox is a Getrag 265 direct top, needs a bit of work to nicely mate with the XE:
Plate milled out:
1901275_274362186067061_1937243752998202
Concentric thrust cylinder mount fitted to Ford type 9 to XE 7 degree bellhousing:
10153980_274362189400394_342853963639360
And all fits!
10177951_274362279400385_388583488208355
10155331_277268342443112_159508369731344
Special starter setup to give us clearance for big blower:
10155078_277268292443117_658656914462651
Fabricating Inlet/chargecooler manifold:
10258311_277269185776361_746900538956844
That makes it look easy! The inlet has a core from a jaguar XJR6 in it fed by water from a seperate cooling circuit.
Fuel feed assembly made up and fitted in boot:
10519590_339540152882597_804813746120911
gearbox x-member made up:
10426826_356566961179916_804296502756428
Oil cooler and chargecooler radiators mounted and piped:
10670144_356584821178130_893436146044835
work on chargecooler pipes starts:
10439369_356584841178128_821779836903511
Looking neat and tidy:
10360763_356585101178102_380031752338770
Oil cooler circuit done, and tensioner for blower belt fitted to O/S engine/blower mount assembly:
10393966_356587531177859_139022183849977
Filler housing for chargecooler circuit
10806289_356587644511181_347747413158217
Throttle body housing fabricated and trial fitted, now you can see why we needed the special starter!
10415546_368952846607994_882337774987306
all just fits, you'd think it might have been designed like that!
10805701_368952883274657_903996084428588
complete blower assembly:
10978543_396503593852919_376949259368141
11042984_403981109771834_268891736024553
Custom crank pulley drawn on CAD, cnc machined and anodised, drives blower and alternator (small vee belt behind the big blower one)
1780852_408501385986473_3537727136025088
bit tight on coolant pipes etc but it fits:
11020219_408507099319235_803086698051827
11026198_408507065985905_771416261240179
Will do a little section on the build of the actual engine, another big chunk of hours on this!
Acid dipped block in primer, old oil and water pumps used to mask off:
Block painted in super tough polyurethane anti corrosion paint:
996739_232711176898829_1408944904_n.jpg?
Block bored, honed and decked then cleaned and new core plugs fitted, ready to start assembly:
1521709_232711233565490_941939065_n.jpg?
acid dipping leaves the block like new inside and out:
1497609_232711316898815_366499222_n.jpg?
assembling steel rods and forged pistons after measuring everything and gapping rings etc:
final double check with plastigauge before installing rods:
10003440_264759533693993_1075318186_n.jp
stretch gauging ARP bolts for correct installation tension:
998925_264759557027324_1437801151_n.jpg?
Bottom end with modified MLS headgasket awaiting cylinder head:
1939789_265570640279549_574653040_n.jpg?
cylinder head stripped, chemical decarbonised, bead blasted, hot washed, new guides, seats recut, skimmed, final hotwash and ready to assemble:
cylinder head assembly time, built a stand as I seem to be doing lots of these!
10007072_265570096946270_1175443059_n.jp
Coming together:
1972367_265570626946217_871485211_n.jpg?
1524933_267233020113311_51439855_n.jpg?o
Edited by Retro Power
Bit more fabrication work now on the supercharger mount which doubles as engine mount:
with BMW aux belt tensioner fitted:
Then need to fabricate the blower air intake/throttle body holder:
10334368_356531001183512_684495050945548
1907877_356531044516841_3322220152159573
boring head lol
1504957_356531074516838_6728816204816127
10624560_356531734516772_223439736709472
10373992_356531741183438_514194032798288
1907883_356531747850104_7416257975808945
10404267_356531824516763_733452417956946
10368207_356531857850093_834359213654152
8956_356531891183423_7854714182964212673
10686967_356531934516752_435421771580719
10435914_356531991183413_393427069231228
my alloy tig welding is improving!!
1464611_356532014516744_3218115911569298
10464356_356533384516607_252660760740072
1907883_356533617849917_2368691929157945
10393581_356534427849836_248967536637165
68163_356534537849825_514594432924106948
63932_356534621183150_224102949559367236
Fabricating inlet:
1507650_232711520232128_431427931_n.jpg?
1499529_232711550232125_477827474_n.jpg?
945827_233689563467657_1118273475_n.jpg?
1510382_233689906800956_368351183_n.jpg?
1609967_356534764516469_6621245421742671
  • Like 4
