1200bandit Posted August 28, 2023 Share Posted August 28, 2023 52 minutes ago, IanMc said: Hi Chris, A recommend direct replacement for the Zoe is the YUASA YBX3012 - how does that equate in terms of size and cranking power to the Cavalier? I think the battery is a 420a 520? Not a 100% best carry out checks Got on my manta is 70a 760 en. I know the battery is a bit big but better over than under Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 28, 2023 Share Posted August 28, 2023 SMF is for Start/Stop application. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 28, 2023 Share Posted August 28, 2023 On a charging battery note, an old fella told me to connect a bulb to one side of the battery whilst charging, so negative charge clip on battery, positive has bulb holder connected between battery and positive terminal, he said it revives a dead battery, why? Not sure, mad science. Great job getting Cav fired up. 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 28, 2023 Author Share Posted August 28, 2023 2 hours ago, Jessopia74 said: SMF is for Start/Stop application. That does make sense. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 28, 2023 Share Posted August 28, 2023 the 3012 is 190mm tall so it may be a tight fit .just be carefull of the positive terminal . the others are 175 high .thats why i said the 100 is good but the 096 is not(too high ?) as regards the start stop style. it should be fine / better than the original but in any case will be better than an old worn out correct battery ! 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 29, 2023 Author Share Posted August 29, 2023 10 hours ago, cam.in.head said: the 3012 is 190mm tall so it may be a tight fit .just be carefull of the positive terminal . the others are 175 high .thats why i said the 100 is good but the 096 is not(too high ?) as regards the start stop style. it should be fine / better than the original but in any case will be better than an old worn out correct battery ! Just checked the clearance above the battery terminals when the bonnet is closed. I can confirm that even with the 3012 YUASA at 190 mm tall, it will have at least 25-30 mm clearance between it and the underside of the bonnet inner skin/framework. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 29, 2023 Share Posted August 29, 2023 excellent . i bet it spins itover a lot better. Quote Link to comment Share on other sites More sharing options...
IanMc Posted August 29, 2023 Author Share Posted August 29, 2023 32 minutes ago, cam.in.head said: excellent . i bet it spins itover a lot better. I haven’t got it yet mate, I should have the new battery in the next few days. Then I will get the one off the Zoe about a week later. Quote Link to comment Share on other sites More sharing options...
IanMc Posted September 27, 2023 Author Share Posted September 27, 2023 I have just fitted the old battery from my Wife’s Renault Zoe (a service related item for that vehicle). It fits very nicely and the Cav has never turned over so fast and started on the second turn of the key, after sitting for around a month. Very happy with that 👍 4 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 28, 2023 Share Posted September 28, 2023 excellent.i thought it might . on a similar subject i have just bought (after watching 'oncedriven forever smitten' on youtube) a kingbolen battery tester. usefull little item that tells you the current cca capacity of a battery along with its state of charge .cheap enough at under £15. after testing all mine it shows my 1 year old yuasa 100 that should be 680 cca is now at 645cca. and another yuasa 100 thats 2 years old is at 570cca.it calculates on internal resistance to get this figure. 4 Quote Link to comment Share on other sites More sharing options...
