1200bandit Posted September 21, 2022 Author Share Posted September 21, 2022 A plastic GTE bumper was removed only got rid because it had big holes in the bumper where it had very big lights on it This is what looked like then l got it( the early photos come out upside down) Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 25, 2022 Author Share Posted September 25, 2022 Had a go at the front bumper again. Bolt on the bumper brackets the to the chassis legs Put studs on the bumper.Got the bumper on sort off the gap is a bit to big between the the front panel and the bumper. The front bumper is jammed on the chassis legs and on the lower panel. If l cut a bit of the bumper where it jammed on the chassis legs,hopefully the bumper will come up a bit more and make the gap smaller. May have to fettle with the chassis brackets Will have to relocate the running lights Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 25, 2022 Share Posted September 25, 2022 also it may look better once the trim strip is on the nose.the gap does look big without it. sorry if im talking silly here ,you have the car in front of you ,im just looking at pictures ! 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 25, 2022 Author Share Posted September 25, 2022 Not being silly, any advice is welcome and much appreciate Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 25, 2022 Share Posted September 25, 2022 (edited) Gap looks about right now without the trim piece. What angle/height do the sides of the front air dam sit? Take a pic of the wing as the angle might be telling. Added a pic of mine on the Berlinetta as I know in this pic it’s factory. Look at the gap, not super clear, but there is one even with trim in place below nose cone/air dam . Project images are available to Club Members Only, Click to become an OMOC Member. Edited September 25, 2022 by Jessopia74 Add pic 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 25, 2022 Share Posted September 25, 2022 That trim, was it fitted to all? Some has it not fitted, or maybe it's another case of Opel, fitting it whilst it was available, maybe supply issues, or someone thought it didn't need it, not necessary, or technical issue, anything that is fixed and could cause injury removed. Who knows? Nice fix Bandit, looks grand, upsidedown🙃 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 30, 2022 Share Posted September 30, 2022 On 25/09/2022 at 18:51, ®evo03 said: That trim, was it fitted to all? Some has it not fitted, or maybe it's another case of Opel, fitting it whilst it was available, maybe supply issues, or someone thought it didn't need it, not necessary, or technical issue, anything that is fixed and could cause injury removed. Who knows? Nice fix Bandit, looks grand, upsidedown🙃 Never seen one without it, unless it was lost or damaged. It’s bloody fragile. But poss they just ran out 💁 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 30, 2022 Author Share Posted September 30, 2022 (edited) Think it has been removed.This manta is quite solid,but it’s been messed about very badly. Its lots of small stuff,best way to describe it ( f##k it that will do)like when l found a lot of body filler around the battery tray,which l though was in good condition Some times is very annoying that someone just cocked it up Edited September 30, 2022 by 1200bandit 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 30, 2022 Author Share Posted September 30, 2022 So in the winter months will be doing some more work on the manta Replace the radio,thermostat,inlet manifold,sort the wiring under the exhaust manifold,rear road springs. Clean ,paint the rear suspension fuel pump housing and what else l find Looking for some headliner just enough to cover the inner sun roof if anyone got a off cut kicking about ( just one more cock up got to correct) Will post some photos of the headliner required to make more clear 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 30, 2022 Share Posted September 30, 2022 2 hours ago, 1200bandit said: Think it has been removed.This manta is quite solid,but it’s been messed about very badly. Its lots of small stuff,best way to describe it ( f##k it that will do)like when l found a lot of body filler around the battery tray,which l though was in good condition Some times is very annoying that someone just cocked it up Same shit, different car. At least you got it out and fixed it with new steel mate. 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 30, 2022 Share Posted September 30, 2022 Never really liked the trim anyway, Think I have a complete sunroof inner roof cloth section..... Need to look? Sometime .. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted September 30, 2022 Author Share Posted September 30, 2022 39 minutes ago, Jessopia74 said: Same shit, different car. At least you got it out and fixed it with new steel mate. I had to check it properly as it did not feel right, so glad that l pulled it apart before using it , will feel a lot better when the rear is checked 34 minutes ago, ®evo03 said: Never really liked the trim anyway, Think I have a complete sunroof inner roof cloth section..... Need to look? Sometime .. When you get the time in rush as got a lot to check and refresh,will post some photos tomorrow just one more thing to sort out 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted October 1, 2022 Author Share Posted October 1, 2022 (edited) This is the inside of the sunroof, did not a photo of this when l was buying it ,note the fixing on the rear , So looking for some lining for this , Of to work now may get a chance to do something later on today Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited October 1, 2022 by 1200bandit 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted October 1, 2022 Share Posted October 1, 2022 Guy on FB does headliner. ‘ Lee ST RS Osborne’ His stuff is top notch. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted October 2, 2022 Author Share Posted October 2, 2022 Only looking for a bit of trim to infill the sun roof.so a bit off cut will do as l thinking of a Clio sunroof in the future 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted October 3, 2022 Share Posted October 3, 2022 3 hours ago, 1200bandit said: Only looking for a bit of trim to infill the sun roof.so a bit off cut will do as l thinking of a Clio sunroof in the future Yes, I think he would prob sell you a bit of the same stuff. He’s a nice guys], so worth asking mate. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted November 25, 2022 Author Share Posted November 25, 2022 (edited) Back on the manta, lost interest in it for a bit ,was even thinking of selling it but the wife said not a chance,so done some cleaning and painting Its very clean underside of the rear ,lubricant the brake shoes ( brake shoes to back plate) adjusted the the shoes probably A few more goodies to get fitted over time ( if l don’t lose interest) The rear road springs are slightly bigger which may clearer the top of the driveway and not catch the exhaust. Not much room to work on the rear sides of it Photos of the N/S before, photos of the O/S clean and painted Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited November 25, 2022 by 1200bandit 4 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted November 25, 2022 Share Posted November 25, 2022 Those rear springs look wrong for GTE. Bet they jack the rear up past original height, rem GTE is lower than std from factory. Seen way too many cars had spring replaced lately looking like a highlux 😂 2 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted November 25, 2022 Author Share Posted November 25, 2022 The springs that come of are progressive springs, and the manta is seating very low. Hopefully it will not be to high as l do need to de higher as the exhaust nearly gets ripped of when getting of the driveway (not that is got of the driveway as yet) Did not start it for 6/7 weeks,turned over slowly and started and run 100% 3 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted November 26, 2022 Share Posted November 26, 2022 rear springs do indeed look physically wrong.but may well be ok once fitted. (at least rear springs can be fitted in 5 mins !) comparing them to non gte stdsprings thou,they had the last coil as half thickness piece as std issue .were std gte springs the same ? ive never ever seen any aftermarket rear springs that are the same. BUT that was always an issue with the original springs even back in the day when they were nearly new.the car would sit level and drive nice with just a driver or 2 people but with 4 in and some luggage the back would become VERY low. thats why i always like the rear end of any car to sit higher at the back when empty. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted November 26, 2022 Author Share Posted November 26, 2022 Just need the exhaust not ripped off when going out of the driveway ( eventually,hopefully,maybe) 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted December 7, 2022 Author Share Posted December 7, 2022 (edited) The paint work on the manta has a bit dull Had a quick go at polishing a bit of paint on the front panel .You can see the difference on the front panel Come up really well, looks like l will polishing it at some time Project images are available to Club Members Only, Click to become an OMOC Member. Edited December 7, 2022 by 1200bandit 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted December 7, 2022 Author Share Posted December 7, 2022 That’s rear axle, shockers clean and painted The new rear springs fitted , don’t know how it will seat on the springs as got to make a exhaust bracket for the rear exhaust box Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted December 7, 2022 Share Posted December 7, 2022 Looking clean, should keep her right for a long time. 👍 1 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted December 7, 2022 Share Posted December 7, 2022 I can do you the bit of headlining you need for the sunroof Also exclusives never had the trim under the grille! 1 Quote Link to comment Share on other sites More sharing options...
