Rick H Posted February 12 Share Posted February 12 (edited) The thing with air is, like most things it expands as it gets warmer. what you want for performance is more oxygen atoms in the cylinder not just volume of air, the more you do to keep the air cool, the more oxygen atoms will be in a certain volume of air. Another thing to remember is we drive Mantas, if you're hose just goes through the hole where the snorkel goes, it's behind the grill, probably in fairly turbulent air which might reduce any available pressure & the crinkles & bends in your air supply tube will reduce flow. You also have a 360° filter which will draw air all the way round it, not just from your hose (sorry to be the bearer of bad news). Luckily the filter is at the front of the engine bay where the air isn't as hot. & as we have CIH engines, anything that can be done to separate the exhaust from the inlet manifold will be a bonus, be that shields, coatings or wraps . Have look at these videos to get an idea of what to do & how to test at home. Edited February 12 by Rick H 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted February 12 Share Posted February 12 the problem i always thoughtwith aftermarket air filters was that they muckup the already correct air/ fuel ratio unless you play with the airflow meter spring and obviously with the engine having no way of knowing this ( ie o2 sensors ) the engine could receive a weaker mixture than intended with the problems this can bring. plus, with a lot of cars the original setup was designed well enough that aftermarket stuff gave no real benefit anyway other than a noise change ? Quote Link to comment Share on other sites More sharing options...
Rick H Posted February 13 Share Posted February 13 That's what the airflow meter is doing, more air in, the meter measures it & adjusts fueling accordingly. Whether it makes a power gain or not is down to, is the filter restricting the engine? In the 1st video I posted, Mr Vizard shows how to test this using a manometer (milk jug, tubing, coloured water & a measuring stick). While a freer flowing filter will only make more power typically at higher revs, once the revs are past the point where the original filter became a restriction, cool air gains power throughout the rev range. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted February 13 Share Posted February 13 cheers that makes sense Quote Link to comment Share on other sites More sharing options...
®evo03 Posted February 13 Share Posted February 13 (edited) On 11/02/2024 at 17:30, 1200bandit said: I think only covered about 250 miles last year,got to use it more And time for a play, you could try experimenting, best time if early morning or late evening, cooler oxygen. Cold air feed? 😉🤔 Project images are available to Club Members Only, Click to become an OMOC Member. Not so cold 🔥🥵 Project images are available to Club Members Only, Click to become an OMOC Member. Standard, The size of that intake, cold air feed from underneath 🫣❄️🥶 Project images are available to Club Members Only, Click to become an OMOC Member. Edited February 13 by ®evo03 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted February 16 Author Share Posted February 16 (edited) Just got full front , rear windscreen inserts trims.one more small thing crossed off the list Edited February 16 by 1200bandit 3 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted March 9 Author Share Posted March 9 The latest update,done nothing 4 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 10 Share Posted March 10 18 hours ago, 1200bandit said: The latest update,done nothing Sounds like mine over last couple of months 🤣 1 Quote Link to comment Share on other sites More sharing options...
TheRealExile Posted March 10 Share Posted March 10 18 hours ago, 1200bandit said: The latest update,done nothing Sounds like my bodyshop 🤣 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 6 Author Share Posted April 6 Backed the manta out the garage,give it a wash,let it dry in the wind back in the garage,cover on ,got to get back into the manta 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 6 Share Posted April 6 3 hours ago, 1200bandit said: Backed the manta out the garage,give it a wash,let it dry in the wind back in the garage,cover on ,got to get back into the manta Nearly warmer 😉 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 7 Author Share Posted April 7 Looking for rear window hinges,the type that goes on 2 sides of the glass. l have got the in the past but can’t remember where from Have tried all types of glue,cleaned the glass,hing not sticking to the glass Quote Link to comment Share on other sites More sharing options...
H-400 Posted April 7 Share Posted April 7 google reprotec, but not cheap. Sometimes Edelschmiede has got them also. 2 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted April 7 Share Posted April 7 30 minutes ago, H-400 said: google reprotec, but not cheap. Sometimes Edelschmiede has got them also. I stuck my reprotec ones on with Araldite Clear. Make sure everything is really clean and mask the glass so glue doesn’t get everywhere. I suggest leaving them clamped in position before refitting the windows. While they are out renew the rubber hinges. 3 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 7 Author Share Posted April 7 this i# what l @m looking for Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted April 7 Share Posted April 7 17 minutes ago, 1200bandit said: this i# what l @m looking for Project images are available to Club Members Only, Click to become an OMOC Member. That’s the ones. I forgot the hinge rubbers were included. This is what I fixed mine with; https://www.toolstation.com/araldite-crystal-tubes-epoxy-adhesive/p60351 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 7 Author Share Posted April 7 Just remembered that l have some Renault glue somewhere which is very strong.Will give a go thi# week 3 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 8 Author Share Posted April 8 19 hours ago, Jonathan Pounsett said: That’s the ones. I forgot the hinge rubbers were included. This is what I fixed mine with; https://www.toolstation.com/araldite-crystal-tubes-epoxy-adhesive/p60351 Did try this glue,removed the windows,glued the hinges,left for 3 days ,refitted the windows popped of next day ,possibly the window seal is setting incorrectly? 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 8 Share Posted April 8 4 hours ago, 1200bandit said: Did try this glue,removed the windows,glued the hinges,left for 3 days ,refitted the windows popped of next day ,possibly the window seal is setting incorrectly? Only stuff I ever used that worked for an extended period was a IV cure glue that car glass co. gave me. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 25 Author Share Posted April 25 Put the first coat of paint on the bonnet yesterday,flatten down and put the second coat of paint on Monday, lts for sale but l still what to work on the manta ( have not lost the love) Project images are available to Club Members Only, Click to become an OMOC Member. 2 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted May 3 Author Share Posted May 3 (edited) Passed the MOT today,clean MOT , Only covered 187 miles last year After the disaster of try to paint the bonnet,it’s gone into my mates body shop , Might be in there for time as it’s getting the roof sorted,will only know when that start digging it out Will be very good finish when done Edited May 3 by 1200bandit 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted May 12 Author Share Posted May 12 The manta has been gone for a week now,no prospects of getting done quickly ( which is okay with me) May be a 4/5 weeks It will be up for sale when l get it back l Am not going to use the manta A good friend has passed away,so going to go to all the places we said we will go.( it brings it into focus) ,so if anyone really interested let me know. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted May 17 Author Share Posted May 17 Manta still in the body shop ,have got a small stone chip in the front screen ,have seen glass repair glue? on eBay ect has anyone tried this and will it work or make it worse. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 17 Share Posted May 17 7 minutes ago, 1200bandit said: Manta still in the body shop ,have got a small stone chip in the front screen ,have seen glass repair glue? on eBay ect has anyone tried this and will it work or make it worse. Get it done by Glass company 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted May 29 Author Share Posted May 29 Quick update,nothing still in the body shop,have not seen it for some time Quote Link to comment Share on other sites More sharing options...
