Broadspeed rep
MantaMad
That looks stunning.
Think I prefer the manta rear lights tho [:P]
I've been pondering whether or not to get vinyl for my roof or not. But can't have it looking too much like yours! [:D] (fat chance of that tho!)
OMOC #5988
hmackay at opel-manta.com
I hae a few guid reasons for drinkin’
And yin juist entered ma heid
If a man canna’ drink while he’s livin’
Hoo the Hell can he drink when he’s deid!
  • Replies 354
  • Created
  • Last Reply
Top Posters In This Topic
h0tr0dder I do know what you mean about the exhaust, thats why I got it futher back in, the pictures seem to make it sit out futher and more noticeable than it actually is not, prob due to me taking them at a low level. The box is behind the valance the only about 3" of the tails actually come past the rear valance, and they stop before the bumper.
Hugh I,m not a big fan of the standard A series lights but on a black car they tend to look fine, I have LED lights in the V8 with smoked lens but they dont suit the black one.
Thanks for the comments its good to have other peoples perceptions [:)]
http://www.mantamagic.com
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Please dont shoot me it,s only an opinion not a demand
Email robbie @ mantamagic.com (without the spaces)
the rims are 15" by 7" tyres are 205 toyo proxies, They are the ones I had one the V8, before I done the rear disc conversion, so they dont want to fit it now, so hunting for something else at the moment.
Cant get those particluar rims with a higher positive offset. [:(]
I think a set of revos are around £800 from memory but cant be sure, prob the best one to ask on that would be TJM.
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Been one of those weeks were most of the manta time was spent hunting for more parts to help conclude the restoration. I needed a new filler neck hose for the A series tank, tried every car dealer locally and one tractor bloke along with a hydraulics guy. [:(] No one had 54mm hose, So ended up after all that on good old flea bay and a bit of over kill, Black Silicone 54mm hose was purchased, but thats another bit got, Work wise I got the petrol tank modified, had to chop 4" of the end of it to let my exhaust back box sit right. that took a bit of work and testing to make sure there were no leaks [:)] Then decided i didnt want any future hassle so I,ve ordered a tank repair kit from frost which is supposed to make a new tank inside the old, has anyone tried these kits?
Front seats are now fitted as well so the inside is almost finished, just waiting on a few clips and have to pop in the org radio at some point and tidy some spare wires i added.
The prop shaft has been shortened as well and hopefully tmw it will get sanded and painted then I can get it back in the car sometime next week [^]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Robbie....the final stages must seem to take for ever, when your waiting or searching for that elusive part.
I used a product call Petseal, years ago on a BSA motorcycle tank. Put a handfull of nuts and bolts plus think it was parafin, into the tank, then gave it a shake for 20mins to clean off any surface rust. Dried the inside of tank with hair dryer, the mixed up and poured in the clear resin(just like fibre glass resin). kept slowly rotating the tank until it was all covered. Can't say if it works, as 20 years latter, the tank has still not seen petrol yet, its one of those to be finish latter projects. Had thoughts about sealing the inside of my Manta A tank, found a product that they say is far better than Petseal, using an aerospace formula....... http://www.tankcareproducts.co.uk
Will Silicone hose be ok to use with petrol, on the filler neck?
Mal.....OMOC #6022 malalsal@aol.com H9OP6tnFJvCgw3kz3xgONVPRv4v9t6WR0060.jpg Start your Manta restoration today........ before it's too late!
Thats something like the frost kit, the kit from frost costs £45
Some of the products you can reuse, like the marine clean and metal ready, I use the metal ready for rust on the car its very similar to jenoite liquid, the jenolite gell i get of ebay at times.
Then the por 15 tank seal is used, the kit also comes with a 1/2 bottle of fuel preserve.
All in all it seems not to bad a price but like doing anything right there always is a cost implication [:(]
The silicone should be fine in the filler neck I ordered FSHL
Fuel Resistant Flourolined Polyster Silicone hopefully thats what they send rather than the normal for breather tubes [:(]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
  • 1 month later...
30th March 2007 this year seems to be flying along and this past few weeks has been spent doing a lot of fiddley time consuming work. The petrol tank had to be shortened to allow the back box to fit, once it had been shortened. I used one of the kits from frost to remake a new tank inside so it would last for a long time to come, tank was then fitted back under the car, The facet silver top comp fuel pump and pre filter was fitted inside the boot beside the Servo and the fuel lines plumbed up and the fuel sender wired up.
With the tank underneath the car still loads of room in the boot for beer [:D]
Petrol tank fitted
With the fuel system finished the interior was the next target to complete the wiring was sorted for the fuel pump and then the coil wiring was completed, the org resistor wire was done away with so that a normal 12V supply would be delivered to the coil and pump on the 3rd position of the ignition key. A few other bits of wiring were sorted, interior light, cig lighter, head unit and speakers. Any other bits of interior trim were sorted like grab handles and then the front seats were bolted down into place and the seat belts fitted.
New Pedals
from the pic you can see the inside looks like it always was, mainly to the gearbox selector rod being shortened allowing the gear selector to come up in the orgional position, this means the console can be used again.
With the inside completed now the engine area was next sort, the clutch cable was fitted and a alloy spacer made up to get the right length of adjustment on the cable. New washer bottle was fitted and a twin washer jet fitted to the bonnet, then piped up.
you can see the alloy spacer just behind the 40,s on the bulkhead.
The trottle cables were adjusted and battery terminals wired, with that out of the road the brakes were blead but the master cylinder turned out to be faulty so a new one was ordered and fitted, then the brakes blead without any futher problems.
Battery wiring and washer bottle
oil and filter sorted and antifreeze , that just left one thing to do , FIRE the beastie up, only took a few mins and the engine fired into life, spluttered a bit and spat .........oops , after a head scratching few mins or 10, 2 of the plug leads had got mixed up this was duely sorted and the car started again, reved a tad high so a fine tune was done on the linkage and once warmed ran sweet as a nut.
Still a few jobs to do , car needs a final go of G10 and then the stripes fitted, also need some wheel nuts for the Revolutions as somehow I lost 2, exhaust manifold has to be done with heat wrap as its close to the tunnel and it will stop the paint burning of, then it will be time to drive the car up the road to see what snags she fires up at me. But the moment she fired into life it made all that work worth while [:D][:D][:D][:D][:D][^]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Must say, this car is looking very nice, must give credit where it is due.
Lovely clean scheme on the outside and very nice engine bay.
Although black A series Mantas have been done to death, with The Broadspeed Turbo and Simon P's 16Valver being the dfinitive Black A series Manta's this is also a very very nice A series.
Not too shoddy a job at all eh Robbie[;)][:)]
Shiny bits http://www.customsolutions.me.uk
Hi Robbie...Am lost for words....A breathtaking restoration, just amazing what can be achieved, given your rebuild skills, mega hours of time, dedication and a shed load of cash.[8D]
You have clearly taken Manta restoration up to another level.[^]
Mal...OMOC #6022 malalsal@aol.com H9OP6tnFJvCgw3kz3xgONVPRv4v9t6WR0060.jpg Start your Manta restoration today........ before it's too late!
Its ok I spose. [:P]
Must be a big advantage having the car at your house and not 170 miles away [:I] when you want to work on it!
Is the centre console standard or did you flock it?
OMOC #5988
Thanks Clive and Mal, [:)] I,m pleased with the way she has turned out, though I know there are bount to be a few snags and things I,ll end up changing once I get it completed for now.
Hugh the centre console is not modified at all, that was one of the reasons I modified the gear selector linkages so the inside would look stock,then I welded the Top of the A series gear selector onto the bottom half of the XXXX one [:D]
Weather is great here today just in for a cuppa been attacking the car with G10 this morning and hmmmmmm going to take me ages cleaning the car now.
Hopefully if i get some time tmw I,ll look at the stripes and maybe get some of them fitted, I never know what way to do stripes wether to damp the car down and fit them or just put them on dry, hard to know which is best. Any suggestions [?]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Works fine in that position, seen quite a few cars in the past with them horizontal rather than vertical which facet suggest. Plus it pulls the juice up from the tank ok, thats what I was worried about initially.
Looks standard Joe [;)] until you lift the bonnet.
OMOC N,Ireland Rep
id="blue">
OMOC 5706
quote:Originally posted by Christ
that's looking quite nice[:P]
id="quote">id="quote">
Wasnt looking as nice when i got finished buffing on Saturday with the car all skitted everywhere with G10. took me most of yesterday getting the car polished again, still got the wheels to clean up and finish of cleaning the engine bay. Really nice working on the cars these days and bright evenings, can't beat some good weather, a bottle of bud. Think we need the BBQ out soon [:)]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Stripes now fitted and that completes the outside [:)] put the stripes on dry and didnt damp the car as I dont want them coming of.
Stripes fitted so that completes the outside of the car. Still waiting on the heat wrap so I can get the car out for a test drive and see how it all feels
The outline stripe on the broadspeed spoiler adds nice definition to the front, the bonnet stripes I decided to leave out for now as I dont want to clutter the outline.
OMOC N,Ireland Rep
id="blue">
OMOC 5706
Turbo?
Should have stuck a LET in. Advertising standards agency will be after you now
I was gonna go with similar stripes on mine.
Was also gonna paint it black and try get hold of a broadspeed spoiler.
A rethink is needed now. Can't have mine looking like THAT [:P]
OMOC #5988
Cheers Devil [:D]
Couldnt find a shinny bling bling let Shug, and its just a Broadspeed rep after all, like the 400 reps [:P] plus the prices calibra engines fetch is just nuts and most need a rebuild and the turbos as well. So its an expensive way to go Unless you have very deep pockets [:(] This one has cost me over 5k to do and 2400hrs.
Once I get this one snagged and the MOT, think I'd better go back to the V8 and make some changes I have in mind [:)] after a few months time of for good behaviour lol
OMOC N,Ireland Rep
id="blue">
OMOC 5706
  • 1 month later...
Hav'nt posted on this topic in ages forgot about it [:(]
Well the car is now 100% road legal, taxed , insured and good old N'Ireland MOT which means they test the Bl0.0dy 5h.it outa the car
Didnt have many snags so far to sort so that was lucky, got a few more shinny bits for the engine bay, pics arnt the best as they were taken inside will try and get some better ones outside [:)]
16v Heat shield and polished stainless tops for the chassis legs
stainless expansion tank and stainless infill strips on wings
new radiator infill panel
not a great pic top left new stainless washer bottle
few more items to come from Clive so room for improvement [:)]
OMOC N,Ireland Rep
id="blue">
OMOC 5706
WARNING. If you do not bring this car to Billing so we can all drool looking at it you will taken to Luton Airport and bundled onto one of Stelios's aircraft back to Ireland to go and fetch it!!!
Having seen this Manta in the flesh before you started I really, really, really want to see it now!!!
I've got piles of all sorts of Manta parts, I might even have something you need!
surplus parts bought,whole cars considerd. M/B 07947 640505
OMOC Member number 2658F
Ian Virco,area rep,Beds Herts and North Bucks.
2400 hours and £5000. That's only £2.08 an hour Robbie. You'll really have to put your prices up.[;)]
So, joking apart, will it be visiting sunny Leicestershire in a few weeks time, or will you be Audi-ing then instead?
Cheers,
Joe.
Please log into this site from the Home page folks. It helps to keep it as the first Manta site listed on Google.
