TJ101 Posted January 8, 2021 Share Posted January 8, 2021 Just acquired this one One Owner from new, showing 40,800 miles, Last taxed 2002, and dry stored since then Will be given it a good look over, then decide whether to 1 Sell as is, ? 2 Get it up running/Mot but then leave as it is, then sell 3 Mot and running, and keep it a while, just as it is 4 Complete restore Guess it all down to what i find ?? Her resting place for the last 19/20 years Project images are available to Club Members Only, Click to become an OMOC Member. Now to make a start ? see what we have Project images are available to Club Members Only, Click to become an OMOC Member. 6 Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 8, 2021 Share Posted January 8, 2021 Very nice indeed! 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 8, 2021 Share Posted January 8, 2021 Problem with a full restoration is getting the money back out of it been a hatch. Think it would be better to get it back on the road with MOT and sell. Kind of a running restoration for someone then, definitely an easy sell imho. 3 Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 9, 2021 Author Share Posted January 9, 2021 (edited) Had a hour this morning Drain most of the fuel, 25lts of fresh added, Full battery, and pulled the king lead, and spun over, Plugs out, clean up and refitted, king back on, and see fires into life Now starts and drives Underside all very good, not sign of rust in floor, sills, inner wings/bulkhead etc Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Edited January 9, 2021 by TJ101 5 Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 9, 2021 Share Posted January 9, 2021 Great news! Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 9, 2021 Share Posted January 9, 2021 Indeed, a Manta that needs no welding on the swan necks! Would go for new tyres, after 20 years... Lost once the tread of a tyre on the highway because they were old. Thought I lost my rear axle! Enjoy the car👍 1 Quote Link to comment Share on other sites More sharing options...
Mike. Posted January 9, 2021 Share Posted January 9, 2021 This looks a superb example, shouldn’t take much to bring it into first class condition since it’s been stored well 👍 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 9, 2021 Share Posted January 9, 2021 👍 Sounds like it should be relatively easy to get through MOT. Personally I would put it through and go off what find with regards to brakes etc, you never know it might fly through Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 9, 2021 Author Share Posted January 9, 2021 3 hours ago, H-400 said: Indeed, a Manta that needs no welding on the swan necks! OK, Swan Necks ? Can someone enlighten me ? Yep, a new set of 5 branded tyres are top of the list Not sure what were OE fit ?? Quote Link to comment Share on other sites More sharing options...
paulmanta Posted January 9, 2021 Share Posted January 9, 2021 Oil and filter change should have happened before you started it really. I'm not picking holes it's great it starts but the oil will be horrible so get it out as fast as possible, stick some cheap oil in (of the correct grade) along with a flush, then run it for a bit and dump it all out again. Then put nice oil in and another new filter. Change that in a few hundred miles. Hopefully the oil ways won't have clogged up with tarry old oil and already be starving the bearings and cam. Cracking car by the way! No sunroof! My favourite. Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted January 9, 2021 Share Posted January 9, 2021 47 minutes ago, TJ101 said: OK, Swan Necks ? Can someone enlighten me ? Yep, a new set of 5 branded tyres are top of the list Not sure what were OE fit ?? The chassis rails that run from the engine bay, down the bulkhead and under the floor. They are prone to serious corrosion around the bolt holes for the front crossmember. Project images are available to Club Members Only, Click to become an OMOC Member. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 9, 2021 Author Share Posted January 9, 2021 Thanks,, Did a search and found out Need to be a Click to become an OMOC Member. to see your picture mind ! Did have a good "Tap" all round, seams very solid ,, Next job is a dam good clean,, 47 minutes ago, paulmanta said: Oil and filter change should have happened before you started it really. I'm not picking holes it's great it starts but the oil will be horrible so get it out as fast as possible, stick some cheap oil in (of the correct grade) along with a flush, then run it for a bit and dump it all out again. Yes Paul, Oil & a couple of filters ordered, for just the reason you mention, and why the king lead was pulled to crank over first Open to any comments/advise, good or bad Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 9, 2021 Share Posted January 9, 2021 Hi Tim, swan neck before: Project images are available to Club Members Only, Click to become an OMOC Member. And after: Project images are available to Club Members Only, Click to become an OMOC Member. Grts, Herman 1 Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted January 12, 2021 Share Posted January 12, 2021 Looks like a great find and very straight and original. Hopefully you keep it and join the club. Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 12, 2021 Share Posted January 12, 2021 @ Tim: Tyres 195/60/14 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 12, 2021 Share Posted January 12, 2021 Best tyres I used at 195/60/14 was some Falken motorsport tyres. Had a very squared off shoulder so the contact area was like a 205 and they was sticky. Can't remember the type as it was back in the 90's but for a 195 tyre they was superb at grip. obviously tyre technology has improved since then so wonder what is a good standard size tyre now, poss Avon? Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted January 12, 2021 Share Posted January 12, 2021 I have had Avons on a Manta and they were shite! the best i had on were Yoko's (C drives) but are no longer made in 195 sizes. So after doing a bit of research I am sticking a set of new Toyos on mine. 3 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 12, 2021 Share Posted January 12, 2021 Worst tyres I had was "road stone". They came with the car when I bought it, they spin when you touched the accelerator and when wet dangerous. The rubber was as their brand, hard as a brick 1 Quote Link to comment Share on other sites More sharing options...
Monaco Blue Posted January 12, 2021 Share Posted January 12, 2021 This is all 'Black Circles' have to offer: https://www.blackcircles.com/order/tyres/search?width=195&profile=60&rim=14 Quote Link to comment Share on other sites More sharing options...
paulmanta Posted January 12, 2021 Share Posted January 12, 2021 The uni royals are pricey but I like them, I have them on my mk4 golf and they are good all rounders. Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 12, 2021 Share Posted January 12, 2021 I have Ditchfinders on the Cavalier - they are round'ish and Black'ish with some funny squiggly lines around them. I'm too scared to try them in the wet in case they live up to their name. I'll get my coat... 3 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 12, 2021 Share Posted January 12, 2021 2 hours ago, IanMc said: I have Ditchfinders on the Cavalier - they are round'ish and Black'ish with some funny squiggly lines around them. I'm too scared to try them in the wet in case they live up to their name. I'll get my coat... Ditch finders lol Nanyang NS2 are good rubber, got them after Zi read some track reviews on a couple of my daily cars in the past. BTW I have used https://www.camskill.co.uk for years, and get local tyre company to fit for me. Never had an issue with getting rubber delivered direct to the tyre shop, they just call me when they arrive. Depending on size of tyre expect £10 to £15 each. Quote Link to comment Share on other sites More sharing options...
Monaco Blue Posted January 14, 2021 Share Posted January 14, 2021 On 08/01/2021 at 22:24, TJ101 said: Just acquired this one One Owner from new, showing 40,800 miles, Last taxed 2002, and dry stored since then Will be given it a good look over, then decide whether to 1 Sell as is, ? 2 Get it up running/Mot but then leave as it is, then sell 3 Mot and running, and keep it a while, just as it is 4 Complete restore Guess it all down to what i find ?? Her resting place for the last 19/20 years Project images are available to Club Members Only, Click to become an OMOC Member. Now to make a start ? see what we have Project images are available to Club Members Only, Click to become an OMOC Member. I Noticed on Facebook you are still considering what to do with it. As was mentioned, get it MOT'd, take lots of photos of the known trouble spots, and post them up. If it's as solid as you reckon it is, and given the exterior paintwork & interior looks very tidy, £7500 could be a good ballpark figure. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 22, 2021 Author Share Posted January 22, 2021 Sorry gentlemen , been a tad busy, and not had a lot of time to look here, or even at the Manta, Yes Martin, though i would ask a few question there as well Recon i will slowly do what's needed for the Mot,plus a bit more to interim preserve then if we are allowed out, used it a bit in spring time Set of tyres, hopefully something period branded , Pirelli, Goodyear, ? What did they fit from the factory ? Fluids (Brake, Box and Diff, Coolant etc) Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 22, 2021 Share Posted January 22, 2021 I believe they was Goodyear Quote Link to comment Share on other sites More sharing options...
