Irish blue
1200bandit
54 minutes ago, 1200bandit said:
When giving a wash, spotted a very slight water leak from the rear window
The window opening type, the clip the goes into the “B” post is insecure
What glue is best to use.
One step forward 2 steps back
You need to use the UV cure stuff for best results. Can be done with a uv lamp or a nice sunny day. And preparation is key to getting a good bond Mate, needs all crap taking off and a good clean up.
Edited by Jessopia74
Was hopefully going to use this in the summer, but it not going to happen.
It’s all the little jobs that are adding up
So l have decided to look at summer 2023 (12/14 months) before it’s back on the road. That way ( hopefully) l will get it right.
Will post the little things that get done ( May be a bit boring)
Here’s a boring bit,So last night found some paint,it has ant rust?.but go’s on ok
Will,paint the inner wing (top and bottom) in Monaco blue
On 27/03/2022 at 17:24, 1200bandit said:
That has to be 1 of the nicest rear ends, (manta)  that I've seen!
Now doing go spoiling it with a number plate!
It's a shame that numberplate are so ugly, no matter what you do with em.
About time they became invisible,  QR code tech,  could take care of that. Doesn't even need to be on display.
Perfect balance anyway, fogs, rear infill, irmscher graphic, back box, height.
Deserves a photo shoot. Soon.....
  • Thanks 1
Careful what you wish for! What you have described there is a black box of sorts in every car, with automatic debited fines or your biometrics no longer functioning to drive the car if you are banned.
I for one are looking forwards to welcoming illustrious AI overlords 😂
  • Thanks 1
Has been raining,so some time to play with the manta
Removed the battery and the trim on the bulk head
The battery tray in excellent condition, even has the original paint there
Removed the shocker give a good clean,What colour should it be,yellow,red ,black
Fitted bonnet struts work well
Time to replace the brake fluid as it is black
I did think long and hard about the fog lights, So l though just get it done,lt did longer to get it right.l think it looks really good, the exhaust is loud ,but as loud as the bandit was
Edited by 1200bandit
  • Like 3
I really should not go poking about, l think l was a keen on the battery tray post
So tonight was having a look at the xs sealer on the battery tray
Had a poke about and one thing lead to another, and all this is what happens.
But on the plus side,the wing is off ,xs to the inner wing,battery tray is brilliant,looks like a easy repair
Going to flush out the old brake fluid 500 mm per corner
Also going to fit lower, top ball joints, drop links,track rod ends .
Going to remove the road springs clean, paint,same colour as the shocks
Can anyone tell me what height the standard road springs are on the front
The is lowered springs on the rear ??
  • Confused 1
  • Sad 3
Well them holes go a bit bigger
Went to do so work outside.started to rain, so in to play with the manta
Cut back to solid metal , Stop raining so back outside
Made some plates and welded 2 of 3 plates in
Turned out well so far
it had quite a bit of body filler in there,don’t understand why you do this as the welding has been done in 2 hours so far.
  • Like 4
Some ppl are just stupid Wayne and will put filler everywhere they can. At least it’s not stuffed full of cardboard like cars in the 80s 😀 I remember my mate buying an XR3 that had more cardboard and filler in sills than steel, poor Sod wasted so much on that car. But he would not be told to walk away from it by our very competent mutual friend that was a car dealer 🤔
  • Haha 1
Got all this from eBay the cost is about £60/70
This is the first time ( serious attempt at welding) as l was going to get someone else to do it
All though the N/S inner wing,battery tray is in reasonable condition, was not expecting the body filler l found, but that is all gone and solid metal will be welded in and sealed.Hopefully Will not need the welding wire
Did find it hard to welded with this welder but l think l have got it sorted
Its a cheep welder was not expecting much but it works ok
Yes great effort on the welding,  it is difficult to get the hang of, had to buy a smaller welder as I was borrowing on and had to basically turn it off to stop it burning holes.
Sorted now, but only good for up to 5mm plate. Can't weld without gas, tried it,  and no not for me.
As I say to anyone, practice is key, prob best to clean up two strips and weld em on the floor, butt weld.
Also help to have metal as clean as possible! Run one of those sanding pads over it, makes a major difference.
Any way,  great guns,  works going well, getting better by the day,  and most important saving another one for the road.
Tip, a welders magnetic angle will find filler, just don't try welding it, the heat will create fumes, that will.... Prob be the worst fumes ever experienced.
Today was raining first thing,so played with the manta
ALL THE WELDING DONE ON THE N/S at last
Sealed the welding as the was very small holes when l put a light on the inside of the manta (they were very very small but water will get in)
Going to fit a plastic tray under the battery and run a breather pipe from the battery to somewhere
If l get a chance tomorrow will paint and under seal inside and the wheel arch.
Then stripped the upper and lower suspension arms off anit roll bar
The drop links come off very easy was expected to be sized
Going to replace the ball joints weld some plates in the lower arms
A very positive day for a change
No have try to join up the welds most are seamless, but did not wish to blow holes bigger ,cut out all the thin,corrosion bits
But l am very pleased with the results
Now getting on with the stuff which l know about as l do most days
Yeah sounds like best way. Your right, it’s difficult with mig on some panels, especially on the shockingly thin steel used on the later shells
Is this the standard height of a front road springs
Had a look on Google not very clear on height
The wooden blocks are solid
Remove the suspension on Monday,
put the 2 washers from the suspension arm in a safe place
Yes you guessed it,l can’t find them
Has any one got them kicking about and post to Liverpool
Need them ASAP as l have to get back moving
